Old 11th August 2010, 02:45   #1421  |  Link
8ternity
8ternity's Avatar
4 Movies crashed in audio conversion.
<2010-08-10 20:45:35>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: TOUT_UN_PAPA
DVD Menu: No Menu
Output Folder: E:\DVD-TEMP
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
AVS Source Filter: DirectShowSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline36Resize
Video Resolution: 0
Video BitRate Min: 3000
Video BitRate Level 1: 8500
Video Profile Level 2: 8500
Video BitRate Max: 9000
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
PAL SpeedUp: 0
DVD Audio Format: 0
DVD Audio BitRate: 448
Keep DVD Compliant Audio: 1
Normalize Audio: 0
DVD Audio Language: FR - French
DVD Subs Language: FR - French
DVD Subs Font: Tahoma 18pt Bold
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: F: HL-DT-ST DVDRAM GH22NS50 TN02
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Save General Settings: 0
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: E:\BLURAY\Wolrds Greatest Dad FRENCH AC3 720P DVD5.AVCHD\BDMV\STREAM\00000.m2ts
Info: AVC - 5606 kbps - 1280x720 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 1:38:40 hours - 141959 frames
Audio 1: E:\BLURAY\Wolrds Greatest Dad FRENCH AC3 720P DVD5.AVCHD\BDMV\STREAM\00000.m2ts
Info: AC3 - 384 kbps - CBR - 6ch - 48000Hz - 1:38:32 hours - Internal
Subs:
[MediaInfoLib - v0.7.32]
AVISYNTH SCRIPT
Video = DirectShowSource("E:\BLURAY\Wolrds Greatest Dad FRENCH AC3 720P DVD5.AVCHD\BDMV\STREAM\00000.m2ts", fps=23.976, audio=false)
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = DirectShowSource("E:\BLURAY\Wolrds Greatest Dad FRENCH AC3 720P DVD5.AVCHD\BDMV\STREAM\00000.m2ts", video=false)
Video = Video.ConvertToYV12
#Using DGPulldown/HCenc to upsize FPS
Video = Video.Spline36Resize(720,480)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 4083.3 MB
HCenc Parameters: -ini "E:\Temp\TOUT_UN_PAPA_4_TOUT_UN_PAPA.HCenc.ini"
HCenc ini file:
*INFILE E:\Temp\TOUT_UN_PAPA_4_TOUT_UN_PAPA_1.avs
*AVSRELOAD
*OUTFILE E:\DVD-TEMP\TOUT_UN_PAPA_4_TOUT_UN_PAPA.m2v
*LOGFILE E:\Temp\TOUT_UN_PAPA_4_TOUT_UN_PAPA.HCenc.log
*MAXBITRATE 9000
*BITRATE 5785
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 60
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<2010-08-10 21:33:59>
END VIDEO ENCODING OPERATIONS
Created File: E:\DVD-TEMP\TOUT_UN_PAPA_4_TOUT_UN_PAPA.m2v (4083.6 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5827 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 1:38:40 hours - 141958 frames
START AUDIO DEMUXING OPERATIONS (Track 1)
FFmpeg Parameters: -i "E:\BLURAY\Wolrds Greatest Dad FRENCH AC3 720P DVD5.AVCHD\BDMV\STREAM\00000.m2ts" -acodec copy "E:\DVD-TEMP\TOUT_UN_PAPA_4_TOUT_UN_PAPA_1.ToFix.ac3"
<2010-08-10 21:34:00>
Problems encountered during Title 1 AUDIO encoding operations.
START (BACKUP) AUDIO ENCODING OPERATIONS (Track 1)
FFmpeg Parameters: -i "E:\BLURAY\Wolrds Greatest Dad FRENCH AC3 720P DVD5.AVCHD\BDMV\STREAM\00000.m2ts" -map 0:1 -y -vn -ac 6 -ar 48000 -ab 384k "E:\DVD-TEMP\TOUT_UN_PAPA_4_TOUT_UN_PAPA_1.ac3"
<2010-08-10 21:42:54>
PROCESS ABORTED DURING TITLE 1 AUDIO (TRACK 1) ENCODING OPERATIONS.
CHECK LOG FILE <E:\DVD-TEMP\TOUT_UN_PAPA_4.LOG> FOR MORE INFO.
Log file created by AVStoDVD Release 2.3.1
<2010-08-10 14:17:29>
START PROCESS
PROJECT SETTINGS
DVD Label: THIRST
DVD Menu: No Menu
PREFERENCES
Video Resolution: 0
Video BitRate Min: 2500
Video Profile Level 2: 4000
Video BitRate Max: 8500
PAL SpeedUp: 0
DVD Audio Format: 0
Normalize Audio: 0
DVD Burning Drive: F: SONY DVD RW DRU-V200S 1.60
Save Log file: 1
Video: E:\BLURAY\Thrist FRENCH DTS 720P F DVD9.AVCHD\BDMV\STREAM\00000.m2ts
Info: AVC - 6600 kbps - 1280x720 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 2:14:06 hours - 192930 frames
Audio 1: E:\BLURAY\Thrist FRENCH DTS 720P F DVD9.AVCHD\BDMV\STREAM\00000.m2ts
Info: DTS - 1536 kbps - CBR - 6ch - 48000Hz - 24bit - 2:14:06 hours - Internal
Subs:
AVISYNTH SCRIPT
Video = DirectShowSource("E:\BLURAY\Thrist FRENCH DTS 720P F DVD9.AVCHD\BDMV\STREAM\00000.m2ts", fps=23.976, audio=false)
Audio = DirectShowSource("E:\BLURAY\Thrist FRENCH DTS 720P F DVD9.AVCHD\BDMV\STREAM\00000.m2ts", video=false)
Encoding Profile: HCenc VBR 1-pass
Target Video FileSize: 3898.5 MB
HCenc Parameters: -ini "E:\Temp\THIRST_0_THIRST.HCenc.ini"
HCenc ini file:
*INFILE E:\Temp\THIRST_0_THIRST_1.avs
*AVSRELOAD
*OUTFILE E:\DVD-TEMP\THIRST_0_THIRST.m2v
*LOGFILE E:\Temp\THIRST_0_THIRST.HCenc.log
*MAXBITRATE 9000
*1PASS
*BITRATE 4064
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 40
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<2010-08-10 15:45:30>
Created File: E:\DVD-TEMP\THIRST_0_THIRST.m2v (3909.7 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 4102 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 2:14:06 hours - 192929 frames
START AUDIO ENCODING OPERATIONS (Track 1)
Wavi+Aften Parameters: "E:\Temp\THIRST_0_THIRST_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 448 -pad 0 -dynrng 5 -bwfilter 0 - "E:\DVD-TEMP\THIRST_0_THIRST_1.ac3"
<2010-08-10 17:48:54>
QuEnc (AC3) Parameters: -i "E:\Temp\THIRST_0_THIRST_1.avs" -o "E:\DVD-TEMP\THIRST_0_THIRST_1.ac3" -priority 5 -1 -nohq -novbr -mpeg2mux novideo -audiocodec ac3 -audiobitrate 448 -auto -close
<2010-08-10 18:05:50>
END AUDIO ENCODING OPERATIONS (Track 1)
Created File: E:\DVD-TEMP\THIRST_0_THIRST_1.ac3 (429.7 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6ch - 48000Hz - 2:14:06 hours
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "E:\Temp\THIRST_0_BatchMux.ini"
BatchMux ini file:
-d "E:\DVD-TEMP\THIRST_0\VIDEO_TS"
-mxp "E:\Temp\THIRST_0_MuxMan.mxp"
-l "E:\Temp\THIRST_0_MuxMan.log"
-muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
-prio LOW
-v "E:\DVD-TEMP\THIRST_0_THIRST.m2v"
-vidmode LB
-a1 "E:\DVD-TEMP\THIRST_0_THIRST_1.ac3"
-a1lang fr
-cellfr "E:\Temp\THIRST_0_THIRST_MuxMan.txt"
-progfr "E:\Temp\THIRST_0_THIRST_MuxMan.txt"
-chapfr "E:\Temp\THIRST_0_THIRST_MuxMan.txt"
<2010-08-10 18:13:18>
CHECK DVD SIZE
DVD Folder (actual) Size: 4438.1 MB
vs Estimated Size: 4450 MB -> 0.3% undersize
vs Assets Size: 4339.5 MB -> OK
END DVD AUTHORING OPERATIONS
Created Folder: E:\DVD-TEMP\THIRST_0 (4438.1 MB)
<2010-08-10 18:13:19>
Edit:One of them is resolved. I uncheck "uncompliant dvd audio"!
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating.
8ternity is offline   Reply With Quote
Old 11th August 2010, 10:07   #1422  |  Link
Mr. Monte
Is there a setting to "copy audio" instead of re-encoding..or is that not possible due to the fact we are splitting it up in 1 gig VOB files?
Mr. Monte is offline   Reply With Quote
Old 11th August 2010, 12:46   #1423  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
But log files are 2... and only first has failed...
BTW in the first one project, FFmpeg has both refused to demux the AC3 track and to encode it (as backup routine). I would suggest to run the m2ts thru TsRemux and fix it or extract the required video/audio streams.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
MrC is offline   Reply With Quote
Old 11th August 2010, 12:47   #1424  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
If the audio is DVD compliant, it is already copied (demuxed, not re-encoded). For more details, see the Help section.
Bye
MrC
AVStoDVD Homepage
Old 11th August 2010, 13:47   #1425  |  Link
Mr. Monte
Not following..sorry for the ignorance. I'm converting a MKV with 5.1 DTS audio. I'm pretty sure DTS is allowed (compliant) . Iv'e checked and unchecked the box for adjust ffdshow mixer, but it still takes my 6 channel down to 2 channel.
Old 11th August 2010, 16:44   #1426  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
1. Not all DTS tracks are DVD compliant. I.e. 24 bit resolution DTS tracks are not DVD compliant (thus AVStoDVD re-encodes it).
2. Mixer: have you installed AC3Filter too, other than ffdshow? If yes, uninstall it.
3. What is your operating system? If W7, than install Preferred Filter Tweaker and select ffdshow as AC3 decoder.
4. Post the project log file
Bye
MrC
AVStoDVD Homepage
Old 11th August 2010, 16:57   #1427  |  Link
Mr. Monte
thanks..that solves that mystery..yes my DTS was 24 bit
Yes, do I have to uninstall it..since I use if for other SW..os there a way to make your interface ignore it?
Windows 7..I will look for the tweaker program (if I do this, can I not unistall AC3filter?
Bye
Thanks!
Old 11th August 2010, 17:19   #1428  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Windows 7..I will look for the tweaker program (if I do this, can I not unistall AC3filter?)
Yes, that's the best solution
Bye
MrC
AVStoDVD Homepage
Old 11th August 2010, 17:25   #1429  |  Link
Mr. Monte
O.k...found Filter Tweaker 3.0
I ran it, but see no AC3 option
ffdshow is selected for all others except WMV1,2,3 and WMVA
Again..i see no AC3
Thanks
Old 11th August 2010, 19:41   #1430  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Thus the remaining option is to setup both AC3Filter and ffdshow mixer as 5+1 output.
(I have no W7 system, so I can only quote other AVStoDVD+W7 users experience in this thread or outside Doom9).
Bye
MrC
AVStoDVD Homepage
Old 12th August 2010, 22:33   #1431  |  Link
8ternity
8ternity's Avatar
Bye
I Know, i have erased the first 2 conversions. I was thinking about configurations i've mist to set in the settings..
How does we fix an m2ts? Did txmuserGUI has a settings to check for errors?
Thanks!
Old 13th August 2010, 12:31   #1432  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Just open TsRemux, load your m2ts file, select the streams you want to keep and then remux to output file.
Bye
MrC
AVStoDVD Homepage
Old 13th August 2010, 16:39   #1433  |  Link
Mr. Monte
Could someone please assist me in getting 6 channel audio from a 6 channel audio source?
I've tried the Win7Tweaker, no AC3 option.
I have AC3 installed, but have watched the toolbar during the audio encoding phase (FFMpeg) and AC3 is not loaded
I have went into FDSHOW Audio Encoder, mixer and tried same as input and 3/0/2 option..still 2 channel. Also, after the AVSto DVD process, if I go BACK and check FFDSHOW audio encoder options..it's back to 2/0/0 in the mixer option...even after changing it prior.
A screenshot of what I'm supposed to do would help.
I'm running Win7
TIA
Old 13th August 2010, 21:28   #1434  |  Link
ggtop
AVStoDVD crashing
Hi MrC,
I don't know if it has been reported earlier but version 2.31 crashes on my W7 64bit when I enable the checkbox "Use External player" on the Paths tab in preferences I get an error Run-Time Error '5': Invalid procedure call or argument.
BTW Works fine on my other machine with XP SP3
ggtop
ggtop is offline   Reply With Quote
Old 14th August 2010, 12:42   #1435  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
I'm running Win7
TIA
If you have left on the 'Preferences'/'Misc'/'Adjust ffdshow Mixer Output at runtime' (default is on), then AVStoDVD will change mixer accordingly to project settings.
Please follow these steps:
- Uninstall AC3Filter and any other AC3 directshow decoder other than ffdshow
- Open AVStoDVD
- Make sure that 'Preferences'/'Misc'/'Adjust ffdshow Mixer Output at runtime' is on
- Setup your AVStoDVD project
- Make sure that 'Title Edit'/'Audio'/'Channels Mode' is '5.1' (it should be, if input title has 5+1 audio)
- Run the project
- Copy and paste here the project log file
Bye
MrC
AVStoDVD Homepage
Old 14th August 2010, 12:52   #1436  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Originally Posted by ggtop View Post
Hi MrC,
ggtop
Thanks for the W7 bug report. I must force myself to install W7... and add W7 to the supported OS list...
That routine checks if the reg key:
HKEY_LOCAL_MACHINE\SOFTWARE\Gabest\Media Player Classic\ExePath
is present and has a value. If not, it checks the reg key:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\AVIFile\shell\open\command
probably W7 default avi player reg key is a bit different...
Bye
MrC
AVStoDVD Homepage
Old 14th August 2010, 13:04   #1437  |  Link
ggtop
Value of HKEY_LOCAL_MACHINE\SOFTWARE\Gabest\Media Player Classic\ExePath is C:\Program Files\Media Player Classic - Home Cinema\mpc-hc64.exe.
Is there an .ini file I could manually set this value?
ggtop
Old 14th August 2010, 14:46   #1438  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
No ini file, but there is a reg key for AVStoDVD as well
HKEY_LOCAL_MACHINE\SOFTWARE\AVStoDVD
and you can edit (create new if it does not exist) the string 'PreviewerPathName'
Or you can simply select the 'Previewer Player Path' using the form 'Preferences'/'Paths' and then 'Save current Preferences as default'
Bye
P.S. your HKEY_LOCAL_MACHINE\SOFTWARE\Gabest\Media Player Classic\ExePath string is with or without ""?
MrC
AVStoDVD Homepage
Old 14th August 2010, 17:36   #1439  |  Link
Mr. Monte
Bye
Where is that stored?
If you talking about the Operations log..no real data there
Old 14th August 2010, 21:00   #1440  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
In the output folder there is a .log file.
Bye
MrC
AVStoDVD Homepage
[IMG] code is Off
