Old 15th July 2010, 04:04   #1381  |  Link
8ternity
8ternity's Avatar
Originally Posted by MrC View Post
@8ternity
Could you please post the 2.3.1 project log file of 'Le Missionnaire FRENCH AC3 DVD9'? I mean the output log file not the input one.
Bye
And here the log
'22:57:21' AVStoDVD Release 2.3.1 loaded!
'22:57:21' AviSynth 2.5.8 is installed.
'22:57:21' ImgBurn is installed ("C:\Program Files (x86)\ImgBurn\ImgBurn.exe").
'22:57:21' MKVExtract is installed ("C:\Program Files (x86)\MKVtoolnix\mkvextract.exe").
'22:57:21' New AVStoDVD Project started!
'22:58:34' Current Preferences saved as default.
'22:58:37' New AVStoDVD Project started!
'22:58:59' MediaInfoLib - v0.7.32 initialized.
'22:58:59' Title 1 "E:\BLURAY\Le Missionnaire FRENCH AC3 DVD9.AVCHD\BDMV\STREAM\00000.m2ts" added.
'22:59:08' AVStoDVD Project started.
'22:59:08' Process aborted during 'Generate AviSynth script file' Section. Error code: 0
'22:59:19' New AVStoDVD Project started!
'23:00:20' MediaInfoLib - v0.7.32 initialized.
'23:00:20' Title 1 "E:\BLURAY\Le Missionnaire FRENCH AC3 DVD9.AVCHD\BDMV\STREAM\00000.m2ts" added.
'23:00:34' AVStoDVD Project started.
'23:00:34' Process aborted during 'Generate AviSynth script file' Section. Error code: 0
Complete log:
<2010-07-14 22:59:08>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: LE_MISSIONNAIRE
DVD Menu: No Menu
Output Folder: E:\DVD-TEMP
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
PAL SpeedUp: False
DVD Audio Format: 0
DVD Audio BitRate: 448
Keep DVD Compliant Audio: 1
Normalize Audio: 0
DVD Audio Language: FR - French
DVD Subs Language: FR - French
DVD Subs Font: Tahoma 18pt Bold
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: F: HL-DT-ST BD-RE  WH08LS20 2.00
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Save General Settings: 0
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: E:\BLURAY\Le Missionnaire FRENCH AC3 DVD9.AVCHD\BDMV\STREAM\00000.m2ts
Info: AVC - 11627 kbps - 1920x1080 - DAR 1,778 - 24 fps (CFR) - Progressive - 1:29:55 hours - 129487 frames
Audio 1: E:\BLURAY\Le Missionnaire FRENCH AC3 DVD9.AVCHD\BDMV\STREAM\00000.m2ts
Info: AC3 - 448 kbps - CBR - 6ch - 48000Hz - 1:29:55 hours - Internal
Subs:
[MediaInfoLib - v0.7.32]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("E:\BLURAY\Le Missionnaire FRENCH AC3 DVD9.AVCHD\BDMV\STREAM\00000.m2ts", CacheFolder="E:\Temp", VFR=false)
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = A2DAudioSource("E:\BLURAY\Le Missionnaire FRENCH AC3 DVD9.AVCHD\BDMV\STREAM\00000.m2ts", CacheFolder="E:\Temp")
Video = Video.ConvertToYV12
#Using DGPulldown/HCenc to upsize FPS
Video = Video.Spline64Resize(720,480)
AudioDub(Video, Audio)
ERROR DURING OPERATIONS ('Generate AviSynth script file' Section): 0 -
PROCESS ABORTED.
Log file created by AVStoDVD Release 2.3.1
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating.
8ternity is offline   Reply With Quote
Old 15th July 2010, 10:04   #1382  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@8ternity
just a quick try: go to Win International Settings and put "." as decimal separator instead of ",".
Let me know
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
MrC is offline   Reply With Quote
Old 15th July 2010, 17:57   #1383  |  Link
8ternity
8ternity's Avatar
@8ternity
Let me know
Bye
You know what? At my work my programmation company ask me to set that international setting decimal for a dot in both tab configs. My compagny paid and get programmed a software for selling auto parts a complete solutions programmed with .Net framework.
So for your recommandation, it has resolved my issue. I've can think before to try this...
and and again!
EDIT: I have an problem with ripbot264 while i change the setting for decimal to ".". I will try something to change to English (United-States) instead of French (Canada) to see if both are ok and let you know.
Old 15th July 2010, 20:15   #1384  |  Link
8ternity
8ternity's Avatar
Hi Mrc,
After complete conversion, exported output has only 4minutes. When the remux step start it ask me if i want to continue even if 4 minutes of movie, i check YES for every questions to have the log.
Here the log:
<15/07/2010 1:30:57 PM>
START PROCESS
PROJECT SETTINGS
DVD Menu: No Menu
PREFERENCES
Video Resolution: 0
PAL SpeedUp: 0
DVD Audio Format: 0
Normalize Audio: 0
Save Log file: 1
Info: AVC - 11627 kbps - 1920x1080 - DAR 1.778 - 24 fps (CFR) - Progressive - 1:29:55 hours - 129487 frames
Subs:
AVISYNTH SCRIPT
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 1-pass
Target Video FileSize: 4073 MB
HCenc Parameters: -ini "E:\Temp\LE_MISSIONNAIRE_6_00000.HCenc.ini"
HCenc ini file:
*INFILE E:\Temp\LE_MISSIONNAIRE_6_00000_1.avs
*AVSRELOAD
*OUTFILE E:\DVD-TEMP\LE_MISSIONNAIRE_6_00000.m2v
*LOGFILE E:\Temp\LE_MISSIONNAIRE_6_00000.HCenc.log
*MAXBITRATE 9000
*1PASS
*BITRATE 6333
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 60
*DC_PREC 10
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<15/07/2010 2:49:28 PM>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: DirectShowSource
Created File: E:\DVD-TEMP\LE_MISSIONNAIRE_6_00000.m2v (4126.6 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 6462 kbps - 720x480 - DAR 1.778 - 24 fps (CFR) - Progressive (TFF) - 1:29:55 hours - 129489 frames
START TRANSCODING OPERATIONS
ReJig Parameters: -size 4072 -o "E:\DVD-TEMP\LE_MISSIONNAIRE_6_00000.ReJig.m2v" -i "E:\DVD-TEMP\LE_MISSIONNAIRE_6_00000.m2v" -auto -close -quiet
<15/07/2010 2:49:32 PM>
END TRANSCODING OPERATIONS
Transcoding executed on File: E:\DVD-TEMP\LE_MISSIONNAIRE_6_00000.m2v (187.2 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 6164 kbps - 720x480 - DAR 1.778 - 24 fps (CFR) - Progressive (TFF) - 4:16 minutes - 6158 frames
START PULLDOWN OPERATIONS
DGPulldown Parameters: "E:\DVD-TEMP\LE_MISSIONNAIRE_6_00000.m2v" -srcfps 24.000 -destfps 29.97 -inplace -tff
<15/07/2010 2:49:38 PM>
END PULLDOWN OPERATIONS
DGPulldown executed on File: E:\DVD-TEMP\LE_MISSIONNAIRE_6_00000.m2v (187.2 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 6166 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 4:16 minutes - 6150 frames
<15/07/2010 3:07:27 PM>
START AUDIO DEMUXING OPERATIONS (Track 1)
FFmpeg Parameters: -i "E:\BLURAY\Le Missionnaire FRENCH AC3 DVD9.AVCHD\BDMV\STREAM\00000.m2ts" -acodec copy "E:\DVD-TEMP\LE_MISSIONNAIRE_6_00000_1.ToFix.ac3"
<15/07/2010 3:09:42 PM>
END AUDIO ENCODING OPERATIONS (Track 1)
Created File: E:\DVD-TEMP\LE_MISSIONNAIRE_6_00000_1.ac3 (288.1 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 6ch - 48000Hz - 1:29:55 hours
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "E:\Temp\LE_MISSIONNAIRE_6_BatchMux.ini"
BatchMux ini file:
-d "E:\DVD-TEMP\LE_MISSIONNAIRE_6\VIDEO_TS"
-mxp "E:\Temp\LE_MISSIONNAIRE_6_MuxMan.mxp"
-l "E:\Temp\LE_MISSIONNAIRE_6_MuxMan.log"
-muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
-prio LOW
-v "E:\DVD-TEMP\LE_MISSIONNAIRE_6_00000.m2v"
-vidmode LB
-a1 "E:\DVD-TEMP\LE_MISSIONNAIRE_6_00000_1.ac3"
-a1lang fr
<15/07/2010 3:09:50 PM>
CHECK DVD SIZE
DVD Folder (actual) Size: 204.6 MB
vs Estimated Size: 4450 MB -> 95.4% undersize
vs Assets Size: 4414.8 MB -> Warning!
END DVD AUTHORING OPERATIONS
Created Folder: E:\DVD-TEMP\LE_MISSIONNAIRE_6 (204.6 MB)
Saved log:
'13:30:47' AVStoDVD Release 2.3.1 loaded!
'13:30:47' AviSynth 2.5.8 is installed.
'13:30:47' ImgBurn is installed ("C:\Program Files (x86)\ImgBurn\ImgBurn.exe").
'13:30:47' MKVExtract is installed ("C:\Program Files (x86)\MKVtoolnix\mkvextract.exe").
'13:30:47' New AVStoDVD Project started!
'13:30:51' MediaInfoLib - v0.7.32 initialized.
'13:30:51' Title 1 "E:\BLURAY\Le Missionnaire FRENCH AC3 DVD9.AVCHD\BDMV\STREAM\00000.m2ts" added.
'13:30:57' AVStoDVD Project started.
'13:30:57' Title 1 video encoding operations started.
'15:07:27' Title 1 video encoding operations ended successfully.
'15:07:27' Title 1 audio encoding operations started.
'15:09:42' Title 1 audio (Track 1) encoding operations ended successfully.
'15:09:42' DVD authoring operations started.
'15:09:47' Warning! DVD Folder filesize (204.6 MB) is much lower than the total Assets filesize (4414.8 MB).
'15:09:50' DVD authoring operations ended successfully.
'15:09:50' AVStoDVD Project ended successfully.
Old 15th July 2010, 21:42   #1385  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
For some reason ReJig (a requantizer software used to shrink a oversized mpeg2 elementary stream) failed and probably crashed before ending its job.
I would suggest you to go to 'Preferences'/'Encoding' and select 'HCenc VBR 2-pass' and then select 'Lock video profile'. Then restart your project from scratch. 2-pass profile should be more bitrate accurate, with no need to invoke ReJig.
Bye
MrC
AVStoDVD Homepage
Old 15th July 2010, 22:52   #1386  |  Link
8ternity
8ternity's Avatar
Bye
I've made a test, i just finish the conversion with theses changes: change for HEnc VBR 1 Pass but with DirectShow encoder and the project has been sucessfully done. I have 4,37GB file size, its look good.
Can this help you?
Also: Thanks for your helping solutions, it's appreciated.
8ternity
Old 16th July 2010, 23:12   #1387  |  Link
8ternity
8ternity's Avatar
I've convert a movie with HCenc 2pass;
2012 took from my bluray bd9 ripp to dvd;
crashed here the log:
<15/07/2010 11:57:31 PM>
START PROCESS
PROJECT SETTINGS
DVD Size: 8100/8100 MB (100%)
DVD Output Setup: Burn DVD
DVD Label: 2012
DVD Menu: No Menu
PREFERENCES
AVS Source Filter: DirectShowSource
Video Resolution: 0
Video BitRate Level 1: 8500
Video Profile Level 2: 8500
PAL SpeedUp: 0
DVD Audio Format: 0
Normalize Audio: 0
Save Log file: 1
Video: E:\DVD\2012.m2ts
Info: AVC - 5371 kbps - 1920x1080 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 2:37:49 hours - 227037 frames
Audio 1: E:\DVD\2012.m2ts
Info: DTS - 1536 kbps - CBR - 6ch - 48000Hz - 16bit - 2:37:49 hours - Internal
Subs:
AVISYNTH SCRIPT
Video = DirectShowSource("E:\DVD\2012.m2ts", fps=23.976, audio=false)
Audio = DirectShowSource("E:\DVD\2012.m2ts", video=false)
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 6112.4 MB
HCenc Parameters: -ini "E:\Temp\2012_0_2012.HCenc.ini"
HCenc ini file:
*INFILE E:\Temp\2012_0_2012_1.avs
*AVSRELOAD
*OUTFILE E:\DVD-TEMP\2012_0_2012.m2v
*LOGFILE E:\Temp\2012_0_2012.HCenc.log
*MAXBITRATE 9000
*BITRATE 5415
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 50
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<16/07/2010 2:41:14 AM>
Created File: E:\DVD-TEMP\2012_0_2012.m2v (6087.3 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5430 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 2:37:49 hours - 227037 frames
FFmpeg Parameters: -i "E:\DVD\2012.m2ts" -acodec copy "E:\DVD-TEMP\2012_0_2012_1.ToFix.dts"
<16/07/2010 2:43:55 AM>
Created File: E:\DVD-TEMP\2012_0_2012_1.dts (1703.4 MB)
OUTPUT AUDIO INFO: DTS - 1536 kbps - CBR - 6ch - 48000Hz - 16bit - 2:37:44 hours
BatchMux Parameters: -arglist "E:\Temp\2012_0_BatchMux.ini"
BatchMux ini file:
-d "E:\DVD-TEMP\2012_0\VIDEO_TS"
-mxp "E:\Temp\2012_0_MuxMan.mxp"
-l "E:\Temp\2012_0_MuxMan.log"
-prio LOW
-v "E:\DVD-TEMP\2012_0_2012.m2v"
-vidmode LB
-a1 "E:\DVD-TEMP\2012_0_2012_1.dts"
-a1lang fr
-cellfr "E:\Temp\2012_0_2012_MuxMan.txt"
-progfr "E:\Temp\2012_0_2012_MuxMan.txt"
-chapfr "E:\Temp\2012_0_2012_MuxMan.txt"
<16/07/2010 7:58:46 AM>
CHECK DVD SIZE
DVD Folder (actual) Size: 6212.3 MB
vs Estimated Size: 8100 MB -> 23.3% undersize
vs Assets Size: 7790.8 MB -> Warning!
<16/07/2010 7:58:54 AM>
Created Folder: E:\DVD-TEMP\2012_0 (6212.3 MB)
START DVD BURNING OPERATIONS
ImgBurn (DVD) Parameters: /mode isobuild /buildmode device /src "E:\DVD-TEMP\2012_0\VIDEO_TS" /dest F: /volumelabel "2012" /speed 4x /erase /testmode no /verify no /noimagedetails /start /waitformedia /close
<16/07/2010 8:13:53 AM>
PROCESS ABORTED DURING DVD BURNING OPERATIONS.
CHECK LOG FILE <E:\DVD-TEMP\2012_0.LOG> FOR MORE INFO.
Old 20th July 2010, 03:20   #1388  |  Link
whiskey
Drunken munky
I have a small question why sometimes when I try to re encode mkv file with 2 pass HCenc somehow program starts with 1pass Quenc and constant bitrate ?
whiskey is offline   Reply With Quote
Old 24th July 2010, 03:03   #1389  |  Link
8ternity
8ternity's Avatar
Hello Mrc!
I've got an video speed up when i convert some m2ts video files with dts audio. The output projects video is speed up, like in fast foward. It's not super high fast foward but you can see difference and know the movie is not properly converted.
What i can do to get this resolved?
I have checked Lanczos resized. Did its that filter changes the speed? Did this filter is the best or which one is the best for quality?
Old 24th July 2010, 05:50   #1390  |  Link
flebber
Practising Schemer
Lancosresize doesn't change speed, quality is subjective but my preference is spline36resize or blackmanresize
flebber is offline   Reply With Quote
Old 24th July 2010, 11:20   #1391  |  Link
simonb1975uk
Is there a limit to the size of the .m2ts file that avstodvd can handle? I'm trying to convert the blu-ray of Transformers 2 to DVD and every time I open the .m2ts file I get an error that says 'Error 9 then on the following line it says 'subscript out of range'. The blu-ray was ripped to my pc using anydvd.
simonb1975uk is offline   Reply With Quote
Old 24th July 2010, 15:06   #1392  |  Link
8ternity
8ternity's Avatar
Perfect. I will try and add theses filters to AVStoDVD ans convert it back.
EDIT: i've convert and add the filter Spline36Resize and the quailty is better. All the most artifacts compression is gone and the quality is verry good.
Thanks you!
Old 25th July 2010, 02:50   #1393  |  Link
8ternity
8ternity's Avatar
No audio output on that project:
I think it's a DTS-HD source like we talk in that post:
http://forum.doom9.org/showthread.ph...90#post1417490
How can i resolve this?
<2010-07-24 20:36:34>
START PROCESS
PROJECT SETTINGS
DVD Label: LEON_MAC
DVD Menu: No Menu
PREFERENCES
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline36Resize
Video Resolution: 0
Video Profile Level 2: 4000
PAL SpeedUp: False
DVD Audio Format: 0
Normalize Audio: 0
DVD Burning Drive: F: SONY DVD RW DRU-V200S 1.60
Save Log file: 1
<2010-07-24 20:36:35>
Video: E:\DVD_PENDING\LEON MAC.m2ts
Info: AVC - 4999 kbps - 1280x720 - DAR 1.778 - 24 fps (CFR) - Progressive - 1:32:12 hours - 132776 frames
Audio 1: E:\DVD_PENDING\LEON MAC.m2ts
Info: DTS - 1536 kbps - CBR - 6ch - 48000Hz - 16bit - 1:32:12 hours - Internal
Subs:
AVISYNTH SCRIPT
Video = DirectShowSource("E:\DVD_PENDING\LEON MAC.m2ts", fps=24, audio=false)
Audio = DirectShowSource("E:\DVD_PENDING\LEON MAC.m2ts", video=false)
Video = Video.Spline36Resize(720,480)
Target Video FileSize: 3346.1 MB
HCenc Parameters: -ini "E:\Temp\LEON_MAC_0_LEON MAC.HCenc.ini"
HCenc ini file:
*INFILE E:\Temp\LEON_MAC_0_LEON MAC_1.avs
*AVSRELOAD
*OUTFILE E:\DVD-TEMP\LEON_MAC_0_LEON MAC.m2v
*LOGFILE E:\Temp\LEON_MAC_0_LEON MAC.HCenc.log
*MAXBITRATE 9000
*1PASS
*BITRATE 5074
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 50
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<2010-07-24 21:06:33>
Created File: E:\DVD-TEMP\LEON_MAC_0_LEON MAC.m2v (3349.5 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5114 kbps - 720x480 - DAR 1.778 - 24 fps (CFR) - Progressive (TFF) - 1:32:12 hours - 132777 frames
DGPulldown Parameters: "E:\DVD-TEMP\LEON_MAC_0_LEON MAC.m2v" -srcfps 24.000 -destfps 29.97 -inplace -tff
<2010-07-24 21:15:01>
DGPulldown executed on File: E:\DVD-TEMP\LEON_MAC_0_LEON MAC.m2v (3349.5 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5114 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 1:32:12 hours - 132642 frames
FFmpeg Parameters: -i "E:\DVD_PENDING\LEON MAC.m2ts" -acodec copy "E:\DVD-TEMP\LEON_MAC_0_LEON MAC_1.ToFix.dts"
<2010-07-24 21:24:33>
Created File: E:\DVD-TEMP\LEON_MAC_0_LEON MAC_1.dts (995.2 MB)
OUTPUT AUDIO INFO: DTS - 1536 kbps - CBR - 6ch - 48000Hz - 16bit - 1:32:09 hours
BatchMux Parameters: -arglist "E:\Temp\LEON_MAC_0_BatchMux.ini"
BatchMux ini file:
-d "E:\DVD-TEMP\LEON_MAC_0\VIDEO_TS"
-mxp "E:\Temp\LEON_MAC_0_MuxMan.mxp"
-l "E:\Temp\LEON_MAC_0_MuxMan.log"
-prio LOW
-v "E:\DVD-TEMP\LEON_MAC_0_LEON MAC.m2v"
-vidmode LB
-a1 "E:\DVD-TEMP\LEON_MAC_0_LEON MAC_1.dts"
-a1lang fr
-cellfr "E:\Temp\LEON_MAC_0_LEON MAC_MuxMan.txt"
-progfr "E:\Temp\LEON_MAC_0_LEON MAC_MuxMan.txt"
-chapfr "E:\Temp\LEON_MAC_0_LEON MAC_MuxMan.txt"
<2010-07-24 21:44:30>
CHECK DVD SIZE
DVD Folder (actual) Size: 3414.9 MB
vs Estimated Size: 4450 MB -> 23.3% undersize
vs Assets Size: 4344.7 MB -> Warning!
Created Folder: E:\DVD-TEMP\LEON_MAC_0 (3414.9 MB)
<2010-07-24 21:44:31>
Old 26th July 2010, 14:26   #1394  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Friends (mainly 8ternity), I'm currently on vacation until next week. I'm just having a quick look in a internet cafè. Please, do wait few days for troubleshooting and continue to explore the problems (and the help section) by yourself.
Bye
MrC
AVStoDVD Homepage
Old 28th July 2010, 15:41   #1395  |  Link
Mr. Monte
Mr.C
I see in the beginning of this thread someone asked if CCE could be implemented.
Any idea if you are planning to and if so, could you look at the new CCE SP3?
TIA
Mr. Monte is offline   Reply With Quote
Old 28th July 2010, 23:56   #1396  |  Link
nevragain
I believe that support for CCE was dropped some time in the past. I think that the author stated that he wised to only support free software.
nevragain is offline   Reply With Quote
Old 1st August 2010, 20:55   #1397  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
START PROCESS
PROJECT SETTINGS
DVD Label: 2012
DVD Menu: No Menu
PREFERENCES
Video Resolution: 0
PAL SpeedUp: 0
DVD Audio Format: 0
Normalize Audio: 0
Save Log file: 1
Subs:
AVISYNTH SCRIPT
HCenc ini file:
*AVSRELOAD
*MAXBITRATE 9000
*BITRATE 5415
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 50
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
BatchMux ini file:
-prio LOW
-vidmode LB
-a1lang fr
CHECK DVD SIZE
Some order:
1.
DVD folder structure were created, then ImgBurn failed to burn the DVD. There could be a lot of reasons: poor disc, DVD burner KO, buffer underrun, etc. BTW issue should be not addressed to A2D
2.
DVD folder structure does not have the audio track. MuxMan has rejected the DTS track. Try to reconvert it to AC3.
Bye
MrC
AVStoDVD Homepage
Old 1st August 2010, 20:57   #1398  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Hello Mrc!
Video can only be speeded up if you are converting from NTSC-film to PAL and you have toggled on the new feat 'Preferences'/'Encoding'/'NTSC->PAL speedup' (default is off). Have you? if not, please post the project log file.
Bye
MrC
AVStoDVD Homepage
Old 1st August 2010, 21:01   #1399  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
START PROCESS
PROJECT SETTINGS
DVD Label: LEON_MAC
DVD Menu: No Menu
PREFERENCES
Video Resolution: 0
PAL SpeedUp: False
DVD Audio Format: 0
Normalize Audio: 0
Save Log file: 1
Subs:
AVISYNTH SCRIPT
HCenc ini file:
*AVSRELOAD
*MAXBITRATE 9000
*1PASS
*BITRATE 5074
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 50
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
BatchMux ini file:
-prio LOW
-vidmode LB
-a1lang fr
CHECK DVD SIZE
As previous project, MuxMan has rejected the DTS track. Try to force AC3 re-encode.
I'm thinking of removing DTS tracks retention... really to many issues with new DTS-HD tracks...
Bye
MrC
AVStoDVD Homepage
Old 1st August 2010, 21:04   #1400  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Originally Posted by Mr. Monte View Post
Mr.C
TIA
Hi, there, Mr. Monte.
No way to reintroduce CCE support. More info at Help/FAQ/Video/Q3.7 (thanks nevragain).
Bye
MrC
AVStoDVD Homepage
[IMG] code is Off
