Old 8th March 2010, 22:55   #1201  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Originally Posted by eon_designs View Post
Just been using the latest download of AVStoDVD - when I add an M2TS file along with subs. As soon as I hit start the HCenc window opens and then just hangs. When I view taskmanager it says that the application is not responding.
Running win 7 64 bit.
Does the 'Preview Clip' works?
You can find some troubleshooting items at Help/FAQ/Video section.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
MrC is offline   Reply With Quote
Old 9th March 2010, 05:57   #1202  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
Okay, I have added everything except for "lock video profile" as your program specifically says "NOT recommended". What does this option do?
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 9th March 2010, 10:37   #1203  |  Link
eon_designs
Bye
Nope - Clip preview just shows a completely white box
eon_designs is offline   Reply With Quote
Old 9th March 2010, 13:43   #1204  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
And what about the FAQ?
Bye
MrC
AVStoDVD Homepage
Old 9th March 2010, 17:25   #1205  |  Link
eon_designs
Hello - looked through the FAQ's
none of them helped. I did, however, check that ffdshow was correctly set (it was) - still unable to get past the not responding part?
Not to worry - just un-installed everything (Avisynth, AVStoDVD and Haali) and reinstalled them all again - seems to be working again?
Old 9th March 2010, 19:03   #1206  |  Link
Adub
Adub's Avatar
In the future, try creating your own script with the M2TS file as a source, and then load the script into something like Media Player Classic. If there is a problem in the decoding chain, it should be displayed when you try to play the script.
Site:Adubvideo
Old 11th March 2010, 19:47   #1207  |  Link
davidcw
Color Matrix change
Originally Posted by Adub View Post
Hey, Mr.C, remember how I was encoding a bunch of Blurays with AVStoDVD? Well, I finally had the time to write a guide here: Convert Blurays to DVD with AVStoDVD.
If I made any mistakes, or gave incorrect information, please let me know and I'll fix it.
Thanks for the wonderful little program!
Adub
When converting Blu-Ray disc or HD cameras files to standard definition I add the ColorMatrix.dll to
the AVS script to correct for the different color matrix used.
To quote from the ColorMatrix v2.3 Manual "It will cause a slight color distortion, which looks like a change in brightness (it's not really a change in brightness, the colors are just slightly off)."
I add the following plugin at the start of the AVS script:
LoadPlugin("c:\Program Files\AviSynth 2.5\plugins\ColorMatrix.dll")
And add after: Video = Video.ConvertToYV12
Video = Video.ColorMatrix(mode="Rec.709->Rec.601")
davidcw
davidcw is offline   Reply With Quote
Old 11th March 2010, 20:08   #1208  |  Link
Adub
Adub's Avatar
@davidcw
Hmm...You may have a point there. The funny thing is, I did not do this, and I could have sworn that my output was just fine. I will have to check my DVD's when I get back home.
There does seem to be some debate about colorspaces. I read a thread once that detailed it quite well. Let me see if I can find it.
Site:Adubvideo
Old 13th March 2010, 02:18   #1209  |  Link
archaeo
scribe
archaeo's Avatar
I'm getting an error when using Avs2Dvd 2.26, coming through HCenc and Avisynth, that states:
"Error: GetChannel: Attempted to request a channel that doesn't exist"
I can't seem to find the problem. Any idea on what it is about? audio, video?
archaeo is offline   Reply With Quote
Old 13th March 2010, 06:20   #1210  |  Link
Adub
Adub's Avatar
My guess is actually audio. What's your source?
Site:Adubvideo
Old 13th March 2010, 15:28   #1211  |  Link
archaeo
scribe
archaeo's Avatar
It's 'the Descent', bluray. The primary video stream is approx 21GB. The audio (as reported by tsmuxer) is a choice of either AC3 640kbps 6 channel, or LPCM 6144kbps, 7.1 channel
Quick question, maybe related?: I had Haali and avisynth already installed through another program folder (BDRebuilder), so I opted not to reinstall those programs when installing AVStoDVD. I didn't want to possibly mess up those working programs. So all I installed was the AVStoDVD package and the activeX controls... Was this the correct choice, since I already had avisynth and haali installed? I didn't want to install avisynth over a previous version...
EDIT: I have avisynth v 2.57 installed.. This should be OK?
Old 13th March 2010, 17:00   #1212  |  Link
8ternity
8ternity's Avatar
Hello,
I have version 2.2.6 installed on a Windows 7 x86 edition and i have ffmpeg crashed during the conversion after the Henc 2-pass.
I have ffdshow clsid 3615 version installed, avisynth 2.5.8 stable, etc.
I convert an m2ts (dts audio french, 720p and 1080p movies) i try to convert in a dvd.
settings are henc 2pass, avs source: Tried (A2Dsource, DirectshowSource) and AC3 option (Wavi+Aften).
can someone help me please?
edit: i try right now update for the ffmpeg 0.5.1 version and try if it's ffmpeg crashed is due to an old version.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating.
8ternity is offline   Reply With Quote
Old 13th March 2010, 20:05   #1213  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@archaeo
about audio issue, do select AC3 6 channels track because 8 channels are not supported. The avisynth error message is caused by the directshow audio filter that must be properly configured (mixer out settings: 3/0/2+LFE) to decode the 6 channels track. If you install ffdshow, then AVStoDVD will do the "dirty" job for you, but if you are using other AC3 decoders (like AC3Filter), you have to setup it by yourself.
You do not have to reinstall avisynth and haali, if they are already found on your system.
@8ternity
please post the log file, because I cannot exactly understand where's the problem. Audio demuxing step, I guess. Have you tried to force audio encoding (toggle off 'Keep dvd compliant audio')?
Bye
MrC
AVStoDVD Homepage
Old 13th March 2010, 21:19   #1214  |  Link
Adub
Adub's Avatar
Actually, that sounds very similar to an issue that I had while processing Blurays and demuxing. The way that I solved it (as Mr. C suggested) was to use Quenc for my audio processing. Again, I cover this in my guide.
Site:Adubvideo
Old 14th March 2010, 03:44   #1215  |  Link
archaeo
scribe
archaeo's Avatar
OK, success - thanks.
...but for some reason whenever I select HCencoder, it always goes to Quenc for the video encoding
So, to force it to go to HCenc, I removed Quenc from the folder, and voila - it went to HCenc, and it is now encoding!
Kind of weird though, how it kept defaulting to Quenc...
Old 14th March 2010, 04:35   #1216  |  Link
8ternity
8ternity's Avatar
@archaeo
@8ternity
Bye
- For the toggle off "Keep dvd compliant audio" not i have not try but i will right now.
Question about ffmpeg, did it's okay that i have upgrade the ffmpeg version? Did i can cause another issue when install a newer version?
Here some logs file of my latest conversion that i have no audio converted.
Movie #1, Try #1
<2010-03-13 01:09:07>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: DE_PERE_EN_FLIC
DVD Menu: No Menu
Output Folder: E:
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
AVS Source Filter: DirectShowSource
AVS Resize Filter: Lanczos4Resize
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6000
Video Profile Level 2: 6000
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
DVD Audio Format: 0
DVD Audio BitRate: 448
Keep DVD Compliat Audio: 1
Normalize Audio: 0
DVD Audio Language: FR - French
DVD Subs Language: FR - French
Chapthers Interval: 5
Use Source Chapters: 1
DVD Burning Drive: M: SONY DVD RW DRU-V200S 1.60
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: E:\DVD\DE_PERE_EN_FLIC.m2ts
Info: AVC - 9775 kbps - 1920x1080 - DAR 1,778 - 23,976 fps (CFR) - Progressive - 1:46:48 hours - 153651 frames
Audio: E:\DVD\DE_PERE_EN_FLIC.m2ts
Info: AC3 - 448 kbps - CBR - 48000Hz - 6ch - 1:46:48 hours
Subs:
[MediaInfoLib - v0.7.26]
AVISYNTH SCRIPT
Video = DirectShowSource("E:\DVD\DE_PERE_EN_FLIC.m2ts", convertfps=true, audio=false)
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = DirectShowSource("E:\DVD\DE_PERE_EN_FLIC.m2ts", video=false)
#Using DGPulldown to upsize FPS
Video = Video.Lanczos4Resize(720,480)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 4005,7 MB
HCenc Parameters: -ini "D:\Temp\DE_PERE_EN_FLIC_0_DE_PERE_EN_FLIC.HCenc.ini"
HCenc ini file:
*INFILE D:\Temp\DE_PERE_EN_FLIC_0_DE_PERE_EN_FLIC.avs
*AVSRELOAD
*OUTFILE E:\DE_PERE_EN_FLIC_0_DE_PERE_EN_FLIC.m2v
*LOGFILE D:\Temp\DE_PERE_EN_FLIC_0_DE_PERE_EN_FLIC.HCenc.log
*MAXBITRATE 9000
*BITRATE 5243
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 50
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<2010-03-13 01:10:10>
PROCESS ABORTED DURING TITLE 1 VIDEO ENCODING OPERATIONS.
CHECK LOG FILE <E:\DE_PERE_EN_FLIC_0.LOG> FOR MORE INFO.
Log file created by AVStoDVD Release 2.2.6
Process has been aborder due to ffmpeg crashed. I will try another conversion with the things to unchecked, but can you follow up about if my update of ffmpeg can cause error or it's okay.
Thank you for your answer and help.
8ternity
Old 14th March 2010, 17:29   #1217  |  Link
8ternity
8ternity's Avatar
HI,
Here the second try log.
<2010-03-13 22:40:33>
START PROCESS
PROJECT SETTINGS
DVD Label: 2012
DVD Menu: No Menu
Output Folder: G:
PREFERENCES
AVS Source Filter: A2DSource
Video Resolution: 0
AC3 Audio Encoder: 1
DVD Audio Format: 0
Keep DVD Compliat Audio: 0
Normalize Audio: 0
Save Log file: 1
Video: E:\DVD\2012.m2ts
Info: AVC - 5371 kbps - 1920x1080 - DAR 1,778 - 23,976 fps (CFR) - Progressive - 2:37:49 hours - 227037 frames
Audio: E:\DVD\2012.m2ts
Info: DTS - 1536 kbps - CBR - 48000Hz - 6ch - 2:37:49 hours
Subs:
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("E:\DVD\2012.m2ts", CacheFolder = "G:\TEMP")
Audio = A2DAudioSource("E:\DVD\2012.m2ts", CacheFolder = "G:\TEMP")
Target Video FileSize: 3804 MB
HCenc Parameters: -ini "G:\TEMP\2012_1_2012.HCenc.ini"
HCenc ini file:
*INFILE G:\TEMP\2012_1_2012.avs
*AVSRELOAD
*OUTFILE G:\2012_1_2012.m2v
*LOGFILE G:\TEMP\2012_1_2012.HCenc.log
*MAXBITRATE 9000
*BITRATE 3370
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<2010-03-14 01:21:33>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: DirectShowSource
Created File: G:\2012_1_2012.m2v (3805,9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3396 kbps - 720x480 - DAR 1,778 - 23,976 fps (CFR) - Progressive - 2:37:39 hours - 226812 frames
START PULLDOWN OPERATIONS
DGPulldown Parameters: "G:\2012_1_2012.m2v" -srcfps 23.976 -destfps 29.97 -inplace -bff
<2010-03-14 01:37:32>
END PULLDOWN OPERATIONS
DGPulldown executed on File: G:\2012_1_2012.m2v (3805,9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3392 kbps - 720x480 - DAR 1,778 - 23,976 fps (CFR) - Progressive (2:3 Pulldown) - 2:37:49 hours - 227038 frames
START AUDIO ENCODING OPERATIONS
FFmpeg (WAV) Parameters: -i "G:\TEMP\2012_1_2012.avs" "G:\TEMP\2012_1_2012.wav"
Aften (AC3) Parameters: -b 448 -pad 0 -dynrng 5 -bwfilter 0 "G:\TEMP\2012_1_2012.wav" "G:\2012_1_2012.ac3"
<2010-03-14 04:02:22>
END AUDIO ENCODING OPERATIONS
A2DAudioSource: DirectShowSource
Created File: G:\2012_1_2012.ac3 (107,2 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 48000Hz - 6ch - 33:28 minutes
<2010-03-14 09:42:11>
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "G:\TEMP\2012_1_BatchMux.ini"
BatchMux ini file:
-d "G:\2012_1\VIDEO_TS"
-mxp "G:\TEMP\2012_1_MuxMan.mxp"
-l "G:\TEMP\2012_1_MuxMan.log"
-muxman "C:\Program Files\AVStoDVD\MuxMan"
-prio LOW
-v "G:\2012_1_2012.m2v"
-vidmode LB
-a1 "G:\2012_1_2012.ac3"
-a1lang fr
-cellfr "G:\TEMP\2012_1_2012_MuxMan.txt"
-progfr "G:\TEMP\2012_1_2012_MuxMan.txt"
-chapfr "G:\TEMP\2012_1_2012_MuxMan.txt"
<2010-03-14 09:48:50>
END DVD AUTHORING OPERATIONS
Created Folder: G:\2012_1 (4013,9 MB)
The audio was missing on the project. It have pass and not have been crashed with ffmpeg, probably due to my update for the latest version of ffmpeg.
I was having a warning that audio lench is like 30min, and movie was more than 2hours. i click ok to continue for having a complete log.
Old 14th March 2010, 20:18   #1218  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Originally Posted by archaeo View Post
...but for some reason whenever I select HCencoder, it always goes to Quenc for the video encoding ...
That's an old old story. Have a look at Help/FAQ/Video/Q3.5
Bye
MrC
AVStoDVD Homepage
Old 14th March 2010, 20:31   #1219  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@8ternity
Let's try to make some order.
About FFmpeg update. You can. But results can be unpredictable: I usually test the updated sw for a while before releasing them into AVStoDVD.
Movie #1 Try #1: from the log file, FFmpeg did not crash, because FFmpeg was not used. There's a problem in decoding video source. Have you installed Haali and ffdshow?
Movie #2 Try #1: yes, ffmpeg+aften had a problem in encoding audio track. Why have you changed from default wavi+aften to ffmpeg+aften as AC3 encoder? If also wavi+aften fails you can try with QuEnc. Many users had success in converting blu-ray audio using QuEnc (right Adub ).
Bye
MrC
AVStoDVD Homepage
Old 14th March 2010, 21:02   #1220  |  Link
archaeo
scribe
archaeo's Avatar
Bye
ah yes.... thank you. Should read FAQ first
One more question related to encoders, please: Is it possible to choose a custom matrix in either Quenc or HCenc? I've tried to modify the matrix choices in both, but it keeps defaulting back to the MPEG std.
thanks!
[IMG] code is Off
