Old 8th June 2010, 17:18   #10101  |  Link
DoomBot
Spiderman 2 is a seamless branching disc, as far as I remember. If you demux/extract the THD data first and convert it to WAVs or FLAC later, you'll get a "lossless check failed" warning for every seamless branch. That is to be expected. You should have gotten a warning from eac3to, though, when extracting the THD track in the first place. It's not a good idea to extract THD tracks from seamless branching Blu-Rays. Audio and video will drift out of sync, because eac3to can't fix the audio overlaps with THD tracks, when demuxing them. You should convert to THD/WAVs directly from the original Blu-Ray structure. Then those "lossless check failed" warnings should go away and audio and video will stay in sync.
I thought eac3to will let you know if there is audio overlaps with THD tracks even if it can't fix the overlap or is it just a gap it warns you about? Even i did Spider-man 2 keeping the Truehd track and not converting to PCM because i thought there wasn't any overlap since eac3to didn't tell me there was. Can i just convert the truehd from the original blu-ray to pcm or just a WAV and not WAVs? Say if i convert to WAVs should eac3to tell me there was overlaps to fix?
DoomBot is offline
Old 8th June 2010, 19:09   #10102  |  Link
Laurent
Originally Posted by SomeJoe View Post
Ideally, eac3to should produce an OGG chapter format file with this conversion already done, since the OGG chapter format file is supposed to use wall-clock time, not an NDF timecode expressed in fractional seconds.
SomeJoe, thank you a lot for you full explanation.
If eac3to is producing NDF timecode expressed in fractional seconds, I should convert these values to wall-clock time using this formula:
Wall-clock time (seconds) = NDF timecode (fractional seconds) * 1001 / 1000
I make a try immediately and come back after.
Laurent is offline
Old 8th June 2010, 22:01   #10103  |  Link
Laurent
Result of the test: that is now perfect
SomeJoe, As you said, eac3to should ideally produce the correct values. This discussion might give the idea to madshi to add an option to apply a coef 1001/1000 to chapter timestamps ?
If not, that means a little tool should be written to apply this correction, taking one OGG chapter file as input and producing a corrected OGG chapter file as output. If this tool does not exist, I will develop one myself, that should not be very hard to do.
Laurent is offline
Old 8th June 2010, 22:42   #10104  |  Link
Snowknight26
Small bug I've come across every now and then with eac3to and NeroAacEnc:
When converting/(de)muxing multiple tracks from a random source, one instance of NeroAacEnc doesn't seem to exit, making eac3to hang at the last progress bar. Ending that hung instance of NeroAacEnc causes eac3to to flood the command prompt with
a09 [NeroAacEnc] Processed x seconds...
until it it gets to
Aborted at file position x.
where x is the size of the file (so the end of it).
I've never seen this happen when doing single audio conversions to AAC, so I suspect it's something to do with eac3to not continuing to feed that hung instance of NeroAacEnc even after all other track operations had finished. Or maybe not.. who knows. Redoing the same command usually fixes it, suggesting that it happens randomly.
Snowknight26 is offline
Old 8th June 2010, 23:34   #10105  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
@madshi
I did a small test (ArcSoft DTS Decoder installed and working, source is .m2ts)
DTSMA -> .w64
and
DTSMA -> .wav -> .w64
Somehow those two file are not identical
Atak_Snajpera is offline
Old 9th June 2010, 00:55   #10106  |  Link
SomeJoe
Yes, I was actually thinking of developing a similar tool myself.
Such tools already exist for subtitles files, since this type of conversion (and many others, like 23.976 NTSC -> 25.000 PAL) are frequently required. But no such tool as yet exists for OGG chapter format files.
- SomeJoe
SomeJoe is offline
Old 9th June 2010, 02:00   #10107  |  Link
TinTime
I knocked up a python script a while ago to do this if you and Laurent are interested. It's pretty basic but does the job for me.
TinTime is offline
Old 9th June 2010, 05:01   #10108  |  Link
Frank K Abbott
I hope this isn't the wrong thread but I tried to use eac3to to encode from .wav to .mp3 but looks like it doesn't support that type of conversion? What is the best software that I can use for MP3 encoding? Command line is preferred as long as it is the latest. I went to the LAME website but I can't find the command line encoder of it anywhere
Frank K Abbott is offline
Old 9th June 2010, 05:13   #10109  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Try this:
http://www.rarewares.org/mp3-lame-bundle.php
HTH.
Midzuki is offline
Old 9th June 2010, 05:15   #10110  |  Link
Frank K Abbott
Wow, thanks Midzuki! This is exactly what I was looking for!
Old 9th June 2010, 18:04   #10111  |  Link
Laurent
I am using a xcalc sheet to convert values + CSV format (":" as separator). My input and output file is not in OGG chapter format but only the list of values (exactly what is required by multiAVCHD). So this requires few steps to achieve the job.
I have started the update of my AVCHD compilation changing chapters for 3 titles. I will check the result later.
By the way, I am interested by your python script (especially if nothing special is required to run it).
Laurent is offline
Old 9th June 2010, 20:18   #10112  |  Link
TinTime
Well, you'd need to install Python 3.1.2, but you can just install it and forget it.
Script and instructions are here.
Script chapters.py outputs an OGG chapter file. Script chapters2.py is the same but with a couple of lines removed so it just outputs the timecodes (it sounds like that would be more useful for you).
Note - it's pretty rough and ready so if you input something other than a standard OGG chapter file it's going to fail with a not very user friendly error message!
TinTime is offline
Old 9th June 2010, 22:31   #10113  |  Link
Laurent
Thank you, I will check that.
Before using your script, I have to run eac3to to generate again the OGG chapter file from my AVCHD compilation. Easy.
Laurent is offline
Old 9th June 2010, 22:55   #10114  |  Link
Laurent
TinTime, I just tried your two Python scripts. Very usefull and (of course) easier in comparison to my previous method.
Laurent is offline
Old 10th June 2010, 07:47   #10115  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
@SomeJoe, Laurent try my ChapterGen tool http://forum.doom9.org/showthread.ph...ght=chaptergen, it have OGG Input/output, and conversion between rates. For HDDVD you need to alter from 24->23.976 to get exact chapters.
shon3i is offline
Old 10th June 2010, 09:15   #10116  |  Link
krohm
krohm's Avatar
@madshi
DTSMA -> .w64
and
this will do a lossless conversion of dts to wav right...??
i have arcsoft totalmedia extreme and theatre, will this have the decoder in it?
what command line would i use to get a dts audio file to be decoded with eac3to to lossless wavs so i can load it into a video editor...
krohm is offline
Old 10th June 2010, 18:49   #10117  |  Link
ramicio
Banned
@madshi
DTSMA -> .w64
and
how long is the audio?
ramicio is offline
Old 10th June 2010, 19:32   #10118  |  Link
Atak_Snajpera
Both files have identical size
however mediainfo shows something interesting
General
Complete name                    : C:\temp\audio.w64
Format                           : Wave64
File size                        : 5.20 GiB
Duration                         : 37mn 25s
Overall bit rate                 : 19.9 Mbps
Audio
Format                           : PCM
Format settings, Endianness      : Little
Format settings, Sign            : Unsigned
Codec ID                         : 00001000-0000-0100-8000-00AA00389B71
Codec ID/Hint                    : Microsoft
Duration                         : 37mn 25s
Bit rate mode                    : Constant
Bit rate                         : 4 608 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Sampling rate                    : 48.0 KHz
Stream size                      : 1.20 GiB (23%)
General
Complete name                    : C:\temp\audio_wav_to.w64
Format                           : Wave64
Duration                         : 2h 41mn
Overall bit rate                 : 4 608 Kbps
Audio
Format                           : PCM
Duration                         : 2h 41mn
Stream size                      : 5.20 GiB (100%)
Old 11th June 2010, 02:03   #10119  |  Link
tebasuna51
tebasuna51's Avatar
@Atak_Snajpera
I can confirm the eac3to bug when write the w64 header (work fine with wav input).
The fields RiffLength and DataLength are truncated to 32 bits instead the full 64 bits value (4 GB limit).
Tested decoding standard DTS (I don't have big DTS-MA) with ArcSoft or libav
tebasuna51 is offline
Old 12th June 2010, 10:15   #10120  |  Link
alfixdvd
With movie Van Helsing Arcsoft Total Media Teather show me 37 subtitles, but eac3to only list 32 subtitles, 5 last ones are absent.
How can I extract them ?
Perhaps anything is wrong ?
alfixdvd is offline
eac3to
