Old 2nd February 2010, 19:29   #61  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Atak_Snajpera
be it a small gain it's still a gain no matter how you look at it
MuLTiTaSK is offline   Reply With Quote
Old 2nd February 2010, 19:33   #62  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Atak_Snajpera
is the software decoder your using dxva capable?
Old 2nd February 2010, 19:35   #63  |  Link
_hawk_
BluRip author
Originally Posted by MuLTiTaSK View Post
DGDecNVManuals.7z
frame accurate decoding is the most important benefit more fps is just a bonus
I think ffmpegsource is frame accurate, too. Same as DirectShowSource with CoreAvc. I have about 1% cpu usage with coreavc on a 1080p movie.
BluRip : 1-Click BluRay/m2ts to h264 mkv converter
http://code.google.com/p/blurip/
_hawk_ is offline   Reply With Quote
Old 2nd February 2010, 20:24   #64  |  Link
stax76
stax76's Avatar
Rather if DSS is frame accurate must also be a splitter matter, maybe frame accuracy would need some communication between splitter and decoder which might not be possible with dshow. Only a dshow developer can give a accurate answer on this.
Old 2nd February 2010, 20:28   #65  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
You cannot use DXVA decoding in AviSynth. Decoded picture cannot be returned to avisynth. Also DXVA needs NV12 instead of YV12 colorspace! I use old good ffdshow (ffmpeg-mt)
Old 2nd February 2010, 20:40   #66  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
StaxRip's feature rich cutting/trimming abilities combined with DGIndexNV frame accurate decoding i remove ad's and all other nonsense from my HD PVR recordings with no problems
Old 2nd February 2010, 20:42   #67  |  Link
Atak_Snajpera
well .... but I was thinking about blu-ray movies ...
Old 2nd February 2010, 21:27   #68  |  Link
_hawk_
BluRip author
@MuLTiTaSK
Maybe you can encode some frames and compare speed using different avs files with directshow, ffvideosrc and dgavcdec.
Then I can decide if its worth the effort
Old 2nd February 2010, 21:37   #69  |  Link
stax76
stax76's Avatar
Cutting is needed for Blu-ray too, mostly at chapter points so cuttings might be done prior AviSynth, while ripping for instance but I don't know which software is capable of doing this.
Old 2nd February 2010, 22:00   #70  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk_
DGDecNV has no problems decoding Blu-ray streams (AVC/MPG/VC1) and does not require users to tweak registry to use DSS or have any decoders installed just simple worry free frame accurate indexing->frameserving->encoding->muxing
DSS, FMS2 also work with many streams but fail with some that DGDecNV handles with no problems introducing issues for the end user and more headaches for you trying to solve them
a quick look around these forums and you will see what i mean
if you dont think that DGDecNV can supplement BluRip no worries
Old 2nd February 2010, 22:15   #71  |  Link
_hawk_
BluRip author
@_hawk_
Thx for the info. I used the non Nvidia version of DGavcindex when I started with bluray stuff. This version isn't under develpment any longer is it?
Atm I have no points left on my list for blurip So maybe I'll do the DGavcdecNV stuff next. I guess 50% of BluRip users could use it..
Old 2nd February 2010, 22:27   #72  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk_
DGAVCIndex is no longer being developed DGIndexNV has replaced or better yet surpassed it
being able to save projects adding batch support to BluRip would be another killer feature to have
Old 3rd February 2010, 04:16   #73  |  Link
mackworth
I will second what someone else said, maybe queue support might be worth something to add. Might be worth it more than nvidia support.
Either way, I just purchased a ATI 5670 to try these mkv files that I have made from blurays. Hopefully this bitstreaming stuff works.
Thanks for the great software!
mackworth is offline   Reply With Quote
Old 3rd February 2010, 08:45   #74  |  Link
_hawk_
BluRip author
I will think about how a queue system could fit into my program concept. Guess it will go hand in hand with save/load projects.
DGIndexNV will only work with Nvidia cards? Or does it have a software mode?
Old 3rd February 2010, 21:33   #75  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk_
DGDecNV is a decoder/frameserver for AVC, MPEG2, and VC1 streams that runs on the GPU of Nvidia graphics cards that support CUDA video decoding. That means the card must have a VP2 or greater engine. VP1 is not supported!
You can check which engine your card has here:Table of Nvidia GPUs
Old 3rd February 2010, 21:52   #76  |  Link
_hawk_
BluRip author
The features of DGDecNv sound good.
I'm thinking about adding a cheap NVIDIA card to my pc..
Anyway I added queue support. Will be included in next release.
Old 3rd February 2010, 22:33   #77  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk_
awesome cant wait to test it out
sometimes i encode main titles to .flac and commentary tracks to .ogg with UsEac3to: a different GUI for eac3to
add more eac3to audio switches, profiles maybe?
Old 3rd February 2010, 22:45   #78  |  Link
_hawk_
BluRip author
If I have a good idea how to integrate this - maybe. Guess it will be more complicated then adding the queue system...
Old 3rd February 2010, 23:04   #79  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@_hawk_
i love how BluRip is lightweight and it does'nt write anything outside of it's containing folder to the registry or anything a really big plus in encoding software
but can you make it support relative paths for the tools used so it can be completely portable so i can use it on my usb drive?
also i create .avs scripts with indexed source outside of BluRip it would be nice to import it in BluRip so i can skip indexing, cropping
oh yeah Drag&Drop support like UsEac3to: a different GUI for eac3to has would also be killer
i'am brain storming
keep up the great coding
Old 3rd February 2010, 23:18   #80  |  Link
_hawk_
BluRip author
i'am brain storming
Thx It's nice to get some feedback..
I think relative paths will be easy..
But if you demux, index & crop outside BluRip why use it at all?
Anyway I wanted to add some basic editing functions for the streamlist so it doesn't have to be done with a text editor.
If you take a look at the streamlist.xml, you'll see how it works to add a .avs by hand..
blu-ray, blurip, eac3to, ffms2, mkv, mkvtoolnix, x264
