Old 15th December 2008, 02:07   #7361  |  Link
rica
Man, i like your revolutions.
rica is offline
Old 15th December 2008, 02:57   #7362  |  Link
rica
eac3to v2.81
command line: eac3to\eac3to  E: 1) 4: C:\HD\audio.dtshd -8000MB
M2TS, 1 video track, 2 audio tracks, 20 subtitle tracks, 2:17:13
1: Chapters, 20 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: TrueHD/AC3, English, 5.1 channels, 48khz
   (embedded: AC3, 5.1 channels, 448kbps, 48khz)
4: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz
   (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz)
5: Subtitle (PGS), English
[a04] Extracting audio track number 4...
[a04] Creating file "C:\HD\audio.dtshd"...
[a04] Audio overlaps for 7ms at playtime 0:23:06.
[a04] Audio overlaps for 6ms at playtime 0:26:06.
[a04] Audio overlaps for 11ms at playtime 0:30:37.
[a04] Starting 2nd pass...
[a04] Realizing DTS gaps...
eac3to processing took 15 minutes, 37 seconds.
Done.
rica is offline
Old 15th December 2008, 08:27   #7363  |  Link
mrr19121970
@madshi
Thanks for all the hard work man. It's appreciated.
I've a feature request concering the -demux switch and the order the titles are presented... Currently the longest title is presented 1st, and generally correct. However in Clone-Wars and a couple of others - this is not the case. The SD 'bonus feature' has a longer duration than the HD 'main feature'. My request is can HD content take priority over SD content before length of feature ?
Thanks. Mike.
mrr19121970 is offline
Old 15th December 2008, 09:19   #7364  |  Link
madshi
Originally Posted by Thunderbolt8 View Post
which might be the situations itll be better not to correct video gaps?
Generally if there are video gaps/overlaps reported I'd recommend to first not fix them and mux everything to the final target container (e.g. MKV or m2ts). Then check the runtime where eac3to reported video gaps/overlaps and check whether audio sync is lost at that runtime or not. If you don't notice anything weird, just leave things as they are and don't fix the reported video gaps/overlaps. Let eac3to fix that only if you notice that audio goes out of sync at the reported runtime.
Sometimes eac3to reports video gaps or overlaps for every second of runtime throughout the whole movie. In that case there are most probably no gaps/overlaps, but instead eac3to detected the movie's FPS incorrectly.
Yes, that makes sense. Will add that to my to do list.
madshi is offline
Old 15th December 2008, 12:13   #7365  |  Link
Momber
option "-shutdown" shuts the PC down automatically after processing is done
You beauty
Thanks so much!
Momber is offline
Old 15th December 2008, 13:35   #7366  |  Link
Greif
Originally Posted by rica View Post
eac3to v2.81
Is that setting a target size of 800MB for the DTS-HD track? I didn't know you could do that.
Greif is offline
Old 15th December 2008, 14:25   #7367  |  Link
nautilus7
nautilus7's Avatar
Actually it's 8000MB, not 800MB. And it refers to the source file. It should read the source file till it reaches 8000MB. The output file size will be unknown.
Am i the only one that have troubles with v2.81? I can't do anything with it. It won't even display the file properties if i do eac3to input.file. I have tried with ac3 and flac. I tried also a conversion, but nothing. It simply does nothing, no progress bar, nothing.
nautilus7 is offline
Old 15th December 2008, 14:29   #7368  |  Link
madshi
Please try downloading again. Maybe something went corrupt? Does the v2.80 exe in the v2.81 zip work for you?
madshi is offline
Old 15th December 2008, 15:05   #7369  |  Link
nautilus7
nautilus7's Avatar
I have already downloaded again. Both times same result. And v2.80 from the same zip works fine.
Old 15th December 2008, 15:12   #7370  |  Link
Chumbo
Chumbo's Avatar
I'm having the same issue. I just tested it on a vob and a ts file and nothing. You can't even ctrl-c to exit. I had to kill the eac3to process with task manager.
The included 2.80 works fine. If you run 2.81 without parameters, it does show the help stuff, but doesn't seem to work with any switches. I don't think the zip file is corrupt or we couldn't unzip it successfully.
Chumbo
Chumbo is offline
Old 15th December 2008, 15:21   #7371  |  Link
nautilus7
nautilus7's Avatar
Exact same issues. I couldn't stop it with ctrl+c when used a flac file for input (just it), but i can stop it with ac3 input. But other symptoms are the same.
Old 15th December 2008, 15:43   #7372  |  Link
madshi
Weird. Does "eac3to -test" work? How about "eac3to nonExistingFile"? Please download this:
http://madshi.net/madTraceProcess.zip
And then run it and try to create a report for the stuck eac3to process. If you succeed getting a report, please post it here. Thanks!
madshi is offline
Old 15th December 2008, 15:57   #7373  |  Link
nautilus7
nautilus7's Avatar
-test works. And using a non existing file works as it should. It also works with (m2)ts container and normal commands related to it (track extraction etc).
This is from an existing file:
removed as it contains personal data
Old 15th December 2008, 16:13   #7374  |  Link
madshi
eac3to v2.82 released
http://madshi.net/eac3to.zip
* fixed: sometimes eac3to stalled before processing (introduced in v2.81)
madshi is offline
Old 15th December 2008, 16:19   #7375  |  Link
nautilus7
nautilus7's Avatar
Thanks! You're the best!
(PS: others who will get it make sure that you get v2.82.)
Old 15th December 2008, 22:45   #7376  |  Link
Thunderbolt8
is there actually a possibility to get rid of short fps spikes for video stream when rewriting the fps? when I slow down a movie which has these short spikes, the fps rate still increases a little at those points and therefore any external audio I'd try to sync to it goes oos from that point then. the internal audio from the .ts seems to spike as well then, as it stays in sync.
Thunderbolt8 is offline
Old 15th December 2008, 23:19   #7377  |  Link
madshi
I've just tried the new version; where are the overlaps?
The first time you had used -8000MB and not -800MB.
What kind of fps spikes to you mean? The only times I've seen video played sped up is when the audio track is a mixture of 5.1 and 2.0. In that case the audio decoder gets confused and reports funny timecodes and that results in video fps getting confused, as well. If that's the problem you're seeing then there's nothing that can (and should!) be done with video muxing, cause it's already correct. Just fetch a proper AC3 track from a DVD and mux that with the video.
madshi is offline
Old 15th December 2008, 23:22   #7378  |  Link
rica
Please read again the previous post; it was 800MB.
rica is offline
Old 15th December 2008, 23:30   #7379  |  Link
madshi
Please read again your own v2.81 log.
madshi is offline
Old 15th December 2008, 23:42   #7380  |  Link
rica
Yes, i read the original log as well; i must admit you're right.
And 8000MB includes four m2ts files so this is why i selected 8000.
By mistake i remembered it as 800.
Sorry for the inconvenience.
@all, forget it.
Edit: Previous post has been deleted by myself.... False info...
Btw, this has been deleted in the same post as well: (restored back)
No, this is the first part of the whole m2ts' cut lenght. (8000MB)
Nobody knows what lenght audio will be, as nautilus said.
I used this cut option to see the result immediately. (this lenght has been selected since it included four m2ts files so as to see the gaps/overlaps)
rica is offline
eac3to
