1st December 2011, 09:15 | #602 | Link |
I got no clue, what is causing the problem.
May be your source is somehow not proper and it helps to open it and save it again under another name with mkvmerge so that the container will be rewritten,... Cu Selur |
3rd December 2011, 21:32 | #603 | Link |
Hi Selur,
Just playing around with Hybrid for the first time today. I was just wondering what the purpose of the explicitly named switches in the command line are for? I thought for progressive blu ray encoding all that was needed in the command line was the --preset and --bluray-compat, plus --level --keyint --vbv-maxrate --vbv-bufsize --sar 1:1 and --slices 4 switches, plus --open-gop if preferred and maybe --pic-struct if required for verification. Are any of the explicitly named switches in the default command line different from the presets? Also when I input a 24/1001 1080p BD, the default command line had a --keyint setting of 48, despite having a maxrate and bufsize setting greater than 15mpbs? |
4th December 2011, 01:14 | #604 | Link | ||
int gopMax = model->intValue("gopMaximum"); int max; if (hardware == QObject::tr("Blu-ray/AVCHD")) { if (bitrate <= 15000) { max = (2 * gopMax < 1) ? 1 : 2 * int(model->doubleValue("videoFramerate") + 0.5); } else { max = (gopMax < 1) ? 1 : int(model->doubleValue("videoFramerate") + 0.5); } } else { max = 10000; } this->doSet(model, "gopMaximum", "maximum", QVariant(max));[/code] you might be right that this might cause a problem with crf, but iirc. 'bluray-compat' should overwrite this,.. Quote:
Cu Selur |
4th December 2011, 01:40 | #605 | Link | |
Is there any way to just use the x264 defaults for a given preset? |
4th December 2011, 01:51 | #606 | Link | |
1. Hybrid got it's own defaults that to not match with any x264 preset 2. If you call a preset (very slow, slow,...) in Hybrid, the preset should match the x264 presets as far as the preset covers all the settings (and unless I made a mistake) If you for example start Hybrid and trigger preset->medium->apply Hybrid will set the settings to the x264 defaults. (profile, level, lookahead, vbv, etc. will still show up in the command line since, Hybrid will always enforce a profile&level combination unless you select none&unrestricted) Cu Selur |
4th December 2011, 01:59 | #607 | Link | |
Great stuff, can't believe I've only just discovered Hybrid! |
21st December 2011, 07:57 | #608 | Link |
Hello, i really like your program, but some suggestions:
1) Simplify the interface. I mean, make it more immediate. I come from AsxGUI and you can do all settings in a few seconds. With yours i end up forgetting something. Too many menus, submenus, filters. Also the way the log is working is confusing a bit. 2) Maybe it would be better if Hybrid's default settings were x264's official ones? For example preset default? In any case, very thorough program, thank you. |
21st December 2011, 08:07 | #609 | Link |
regarding 1.: Hybrid is not ment as a one click tool and since it has a lot of settings it needs a lot of menus or a long wizard like GUI. Personally I create myself a few profiles and limit the amount of clicks to a minimum.
regarding 2.: maybe, but personally I prefer my own. If you want Hybrid to start with the default x264 defaults: set the x264 Restriction Settings to None/unrestricted, apply the default preset, go to Config->Defaults->Save select x264Model and press selected. This way you change the default x264 settings to you liking. Cu Selur |
21st December 2011, 08:16 | #610 | Link | ||
23rd December 2011, 08:39 | #611 | Link |
Hybrid rev 2011.12.23.1:
*fixed*
-> downloads: http://www.selur.de/downloads Cu Selur |
23rd December 2011, 09:01 | #612 | Link |
Practising Schemer
is dcaenc for linux only?
Hadn't heard of it until you posted these updates and found this page http://aepatrakov.narod.ru/dcaenc/ |
23rd December 2011, 09:05 | #613 | Link |
Nope, the hybrid installer (and win32 package) includes a window build (thx to LorD_MuldeR for that), for addition infos regarding dcaenc, also see: http://forum.doom9.org/showthread.php?t=163526 (there's also a download link to the win32 binary)
Cu Selur |
23rd December 2011, 20:08 | #615 | Link |
I have one trouble with previous 32-bit Windows version of Hybrid. It crushed on the last stage of the process.
Fragment of the log: "deleted C:\VIDEOS\temp\City.Lights_21_35_11_421_04.stats deleted C:\VIDEOS\temp\City.Lights_21_35_11_421_04.stats.mbtree Starting Main@10:35:03.785: "C:\Program Files\Hybrid\MP4Box.exe" -fps 25 -add "C:\VIDEOS\temp\City.Lights_21_35_11_421_05.264"#videoar=1/1 -brand avc1 -add "C:\VIDEOS\temp\City.Lights_ru_aid_1__21_35_11_421_02.ac3"#audio -tmp "C:\VIDEOS\temp" -new "C:\VIDEOS\Movies\City.Lights.mp4" QProcess::FailedToStart" |
23rd December 2011, 21:02 | #616 | Link |
MP4Box call looks fine, and the temp files should all be still there, so you could just try to call:
"C:\Program Files\Hybrid\MP4Box.exe" -fps 25 -add "C:\VIDEOS\temp\City.Lights_21_35_11_421_05.264"#video:par=1/1 -brand avc1 -add "C:\VIDEOS\temp\City.Lights_ru_aid_1__21_35_11_421_02.ac3"#audio -tmp "C:\VIDEOS\temp" -new "C:\VIDEOS\Movies\City.Lights.mp4" Cu Selur |
23rd December 2011, 22:42 | #618 | Link |
Can't fix anything in Hybrid unless I know what's going wrong and unless you are willing to run the call in the console I'm forced to just ignore the problem since I can't reproduce it here.
Cu Selur |
24th December 2011, 00:38 | #619 | Link |
I tried to call in the console, but mp4box crushed, because it didn't find libraries libeay32.dll and ssleay32.dll. I found their in the my Filezilla (???), copied their into hybrid folder and run mp4box in the console again. Mp4box worked properly. I got mp4-file. Here's a mystique.
