30th October 2007, 11:52 | #1241 | Link |
This post may prove of use to some of you that keep on getting this audio raw expected file size error. I had the problem once when I was doing EVO to WMV with 5.1. Now I will assume that the people having these errors are doing it with 5.1 audio. The way I got around this problem was making sure that EAC3TO, SOX and WAVAVIMUX was installed to the same folder as your audio and video sources that you are transcoding from. I was using Nero 7.10.0.1 with the BluRay HD DVD Plugin aswell which is crucial. Make sure that the file name of the audio file that it is you are trying to transcode is not a long file name and change it to something small and simple if you can.
But remember DO NOT INSTALL WAVAVIMUX to the Windows Media Encoder components folder and instead to the folder you are working from along with all your other files. |
30th October 2007, 12:32 | #1242 | Link | |
And eac3to refers to it's own subfolders to sox or aften when needed right? |
30th October 2007, 13:13 | #1243 | Link |
I am not too sure about the runnings and how it all connects but whatever 5.1 audio file I am doing with EACH3TO all I do is make sure that EAC3TO, EAC3TO GUI, SOX and WAVAVIMUX is all based in the same folder as the files im working on. I am not saying this method may nesscarily work for you but it did for me when I got that error. Also make sure you have the Nero BluRay HD DVD plugin (must be geniune) Also please note that EAC3TO does not work or function properly with Nero 8.
30th October 2007, 14:09 | #1244 | Link |
So i kinda gave up on nero, i just can't get it to work, showtime plays HD content fine tho. And yes it's a legit version.
using -orbitlee -sonic is working now, but as mentioned in startpost it automagically applies DRC to the track which is catastrophic ofcourse. I found this site: http://codec.kiev.ua/mpeg2.htm somewhere near the bottom : Nero Suite ShowTime v.5.2.1.0 CE Would this be usable? (and free!) |
30th October 2007, 16:21 | #1246 | Link | |
No, it's not usable. And I don't think that that site is legal. |
30th October 2007, 17:20 | #1249 | Link |
Unfortunately not. You do have to purchase the BluRay HD DVD Plugin seperately and it comes in the form of a serial that you enter at NeroProductSetup. The PlugIn cost me £14.99 when I purchased it and that was 2 months ago. You will have to purchase it.
30th October 2007, 18:06 | #1250 | Link | |
The must be Nero HDDVD/Bluray Plugin When its not there ...youve no Plugin installed Yes, it never come with a standard Ultra/premium Version. You must by it seperatly |
31st October 2007, 09:04 | #1252 | Link |
I don't know exactly what Nero ShowTime will or will not be able to do. I'm only using the Nero Audio Decoder. But I'm planning to (still didn't find the time to do so) release a little tweak that allows using the Nero Audio Decoder inside of Media Player Classic and ZoomPlayer etc with DRC turned off. This tweak will only work for Nero 7, though.
1st November 2007, 21:40 | #1254 | Link |
@ Madshi
I don't understand why the trueHD track has to muxed into an .evo container before converted to wav/flac. I know that the initial .evo has to demuxed in order to remove the dialog norm, but i don't get why it has to muxed again. Thanks! |
2nd November 2007, 01:10 | #1257 | Link |
These pics are from the "Letters from Iwo Jima" HD DVD.
It contains an eac3 and a trueHD track. I demuxed both with latest version of eac3to using nero filters. eac3 track trueHD track How do you explain that eac3 has higher picks than trueHD? Is this random (has to do with the specific movie)? About calculating the delay: Have you ever find an eac3 track that needs to be delayed? Last edited by nautilus7; 2nd November 2007 at 01:15. |
2nd November 2007, 10:13 | #1258 | Link | ||
2nd November 2007, 18:59 | #1260 | Link |
what is actually needed for TrueHD 7.1 support for eac3to ?
does eac3to actually differentiate between dts-hd hr and MA and that 16-bit downsampling applies only to HR, or does it apply to both? Last edited by Thunderbolt8; 2nd November 2007 at 19:45. |
eac3to |
