Old 26th April 2012, 06:39   #19401  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by Biggiesized View Post
Now the interline twitter is gone, but it's still playing at 30 fps.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline
Old 26th April 2012, 10:02   #19402  |  Link
Mercury_22
@Aleksoid Can you guys make the "Menu Bar" go directly from "Hide Menu" to "Show Caption&Menu" without going through all the other steps : "Hide Menu" -> "Frame Only" -> "Hide Borders" -> "Show Caption&Menu" like all the other bars are behaving = JUST Show or Hide the bar ?
Even better can you make this behavior = JUST "Sow" or "Hide" for all the current options = "Frame" and "Borders" and "Menu" ?
Intel UHD Graphics 750; Win 10 22H2
Mercury_22 is offline
Old 26th April 2012, 10:36   #19403  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
Please DO NOT hijack this thread with your MPC-BE stuff.
This is NOT thread for MPC-BE but for MPC-HC! ...
Again you're violating GPL license with removal of access to your source. NOT good.
@Aleksoid I've expected that your level of seriousness is a bit more respectable. Thank you for all you've done in past.
MPC-HC Links: official nightlies | Trac | GitHub | git log | IRC | Twitter | Facebook
vBm is offline
Old 26th April 2012, 11:11   #19404  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
did you try this : svn co svn://svn.code.sf.net/p/mpcbe/code/trunk mpcbe-code
Kurtnoise is offline
Old 26th April 2012, 11:20   #19405  |  Link
nevcairiel
You can browse the source here:
https://sourceforge.net/p/mpcbe/code/
nevcairiel is online now
Old 26th April 2012, 11:33   #19406  |  Link
Aleksoid1978
I don't understand - what i do wrong ???
Old 26th April 2012, 11:46   #19407  |  Link
vBm
MPC-HC Helper xD
vBm's Avatar
Nothing, I'm just thanking you for all the stuff that you DID do good in past.
Like everyone said, not just once, if it wasn't for you, v0lt and XhmikosR, MPC-HC would be dead.
It's just said that you've decided to part your way and start a fork. But you think that's the best for you. Well, good luck to you and your crew sir.
And wow, how convenient, source is available again, while it wasn't when I've checked it this morning.
And coming to public, with all the drama trying to MPC-HC be bad guys is just hilarious. Well, it takes two for proper dance
And let's just stick to the topic ... which is MPC-HC and not mpc-be.
vBm is offline
Old 26th April 2012, 12:44   #19408  |  Link
wanezhiling
@Aleksoid1978
http://www.mediafire.com/?le43868vokmccb4
The file stoped at the beginning, LAV Splitter is ok.
wanezhiling is offline
Old 26th April 2012, 13:11   #19409  |  Link
Aleksoid1978
Originally Posted by wanezhiling View Post
@Aleksoid1978
Play fine all file.
P.S. - try this build http://rghost.ru/37778655
Old 26th April 2012, 13:27   #19410  |  Link
wanezhiling
Play fine all file.
Same result.
The file stoped at the beginning, you must manually seek it then it can work fine.
Old 26th April 2012, 13:42   #19411  |  Link
Aleksoid1978
Same result.
what filter use - i test only on internal splitter & decoder and all play fine at the begin;
Old 26th April 2012, 13:43   #19412  |  Link
wanezhiling
http://www.mediafire.com/?xr7ynkl2fg59g1c
http://i.imgur.com/JTpa9.png
mpc-hc dxva, a green horizontal stripe at the top of the file.
http://i.imgur.com/V07cu.png
While lav native dxva is ok.
PS: this only happens on ATI card(I'm sure.), NVIDIA is fine.
Old 26th April 2012, 13:45   #19413  |  Link
wanezhiling
Default setting, can anyone reproduce?
Old 26th April 2012, 14:03   #19414  |  Link
Mercury_22
Edit: My bad yes with internal DXVA there is "a green horizontal stripe at the top" (MPC-BE rev.66) sorry
Old 26th April 2012, 14:08   #19415  |  Link
wanezhiling
Ok, something seemed to be wrong on my system, not a big deal.
Old 26th April 2012, 21:33   #19416  |  Link
Biggiesized
Biggiesized's Avatar
I never doubted you.
It's clearly something wrong with my computer.
Biggiesized is offline
Old 26th April 2012, 21:52   #19417  |  Link
ceb
Originally Posted by ceb View Post
I have a small problem with selecting automatically the right subtitles.
My .mkv file has 2 English subtitles, I would like to choose the second but no matter what I tried it always chooses the first which is the default one.
I tried eng, eng2, etc. but none worked.
This is a screenshot of the subtitles selection in case it may help:
Any help?
ceb is offline
Old 26th April 2012, 23:02   #19418  |  Link
Tanuki
Any help?
I'm almost 100% sure there isn't any solution to your problem, except to stop watching releases from often mediocre rip groups that think people prefer to watch their anime dubbed in english, so they put the complete subs in second place.
Tanuki is offline
Old 27th April 2012, 01:47   #19419  |  Link
Superb
http://mpc-hc.svn.sourceforge.net/vi...ss?view=markup
AppName should be VSFilter.
DirectVobSub is the old name, isn't it?
Superb is offline
Old 27th April 2012, 22:56   #19420  |  Link
Superb
I wonder... am I the only one who finds Custom EVR completely unusable when showing on a secondary monitor (a 42" led tv; 23.976Hz)?
I find myself unable to use MPC-HC w/o madVR. :/
Now, for me it's great and all... But for users w/ low-end cards this must suck.
The frame timing code ("playback smoothness") in Custom EVR needs a rewrite IMHO.
Superb is offline
dxva, h264, home cinema, media player classic, mpc-hc
