26th February 2010, 12:58 | #12021 | Link | |
I don't know if it is possible to use AVIVO instead of video renderer to control levels. I still haven't understood the relationship between video renderer and video card, probably the renderer developers on this forum (beliyaal, ar-jar, madshi) have a clear vison of that. As for PDVD9, I don't know it enough. |
26th February 2010, 13:10 | #12022 | Link | |
1) you set DR to 16-235 to instruct ATI to expand 16-235 to 0-255 2) use EVR and enable DXVA in MPC Do you still see banding? |
26th February 2010, 13:35 | #12023 | Link | |
2) there is banding. |
26th February 2010, 17:33 | #12024 | Link |
I find a problem with subtitles. Some subtitles are cut in fullscreen
In windowed mode subtitles are displayed https://sourceforge.net/apps/trac/mpc-hc/ticket/314 |
26th February 2010, 18:25 | #12026 | Link | ||
what's this for?
hey thank you guys... both of you
as I said, my question was out of interest as I'm not into video stuff that much anymore but at least was curious why I couldn't "solve this little problem". As mentioned above, I wasn't aware of it.
latest mix sets: http://soundcloud.com/sill |
26th February 2010, 19:01 | #12027 | Link |
4:2:0 hater
Guys, I really dislike the change made in r1696:
Change : Go to the next/previous file in the directory on the user's click on "skip back"/"skip forward"; At least make it optional, because those buttons are usually used for navigate between chapters or tracks, not completely different files. If the current video/playlist doesn't have chapters and the user has disabled this option they should be greyed out IMO. EDIT: Not to mention that when you accidentally press the key associated with them in your remote or keyboard you change the file too... crazy. Last edited by STaRGaZeR; 26th February 2010 at 19:07. |
26th February 2010, 19:44 | #12028 | Link |
2 STaRGaZeR
Did you try this option? Go to the next/previous file in the directory on the user's click on "skip back"/"skip forward" works when only one file in playlist. Otherwise, they are working with playlist, as before. If the current video have chapters "skip back"/"skip forward" works with chapters, as before. Previously, if in the playlist was only one file, then "skip back"/"skip forward" was disabled. Last edited by X-Dron; 26th February 2010 at 19:51. |
26th February 2010, 21:59 | #12029 | Link |
You don't see the right subtitle. You see the 5th subs. I speak about subs one, two and three above the subs number 5. See for example for the sub number 1 (at the top of the screen): the subs complete is: "RSPK syndrome is the conditionwhere in an esper loses control over themselves, causing a subconscious and uncontrllable outburst of power" in sub cut it lacks "control over" and "outburst of power" |
26th February 2010, 23:18 | #12030 | Link |
Otaku
@ikarad
Check "Position subtitles relative to the video frame". Wait, If you look properly they are both out of the "video frame" because the frame ends at the blue corners of the video. Windowed mode added those black borders that don't make part of the video. if you disable free window resize and then resize the video the subs will now show like the fullscreen screenshot. the fansubbers missaligned the subtitles.
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
27th February 2010, 02:18 | #12032 | Link | |
4:2:0 hater
I understand this may be useful for folders containing audio files, but for those containing video files is awful IMO. If you guys plan to keep it this way, an option to disable it would be great. |
27th February 2010, 06:49 | #12035 | Link | |
Ok, I'll do it customizable. I need guru's help. I almost finished a customizable OSD size. It would be great if a test OSD message displays on change setting. How to call m_OSD.DisplayMessage from MainFrm in CPPageTweaks.cpp? Code:
void CPPageTweaks::OnHScroll(UINT nSBCode, UINT nPos, CScrollBar* pScrollBar) { if(*pScrollBar == m_OSD_SizeSlider) { m_OSD.DisplayMessage(OSD_TOPLEFT, _T("Test")); } SetModified(); __super::OnHScroll(nSBCode, nPos, pScrollBar); } Last edited by X-Dron; 27th February 2010 at 07:48. |
27th February 2010, 08:53 | #12036 | Link | |
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
27th February 2010, 09:16 | #12037 | Link | |
Is it possible to make it? |
27th February 2010, 10:53 | #12040 | Link |
subtitle load order
Is there a way to set the subtitle load order to prefer external file above the internal subs?
If not, maybe it could be implemented as a "ext" language which would mean external file without language flag? Or maybe just a checkbox "prefer external"? |
