25th February 2010, 00:09 | #12001 | Link |
I didn't read all 600 pages
is there a way to skip 10 seconds forward like in some other players? will that be added in the fture it's great for skipping some boring part of the video or to quickly find what you're looking foe. |
25th February 2010, 03:38 | #12003 | Link |
I got some strange behaviour with the latest svn revisions. While playing DVD videos with enabled internal audio switcher, sometimes i wont get any sound in the menus. When starting the movie or jumping manually to the title or main menu, the sound "magically" reappears.
Strangely enough, this wont happen very often while using the system default audio renderer (DirectSound => Asus Xonar DX). But it happens most of the time while using ReClock as audio renderer (tested with v1.8.6.2 & v1.8.6.3). It doesn't matter which audio decoder i use - it's always the same. And it only happens with video DVDs. Disabling the audio switcher helps - but it's very annoying, cause i need the audio switcher to set a negative delay, ensuring audio/video synchronicity on my TV. Till svn 1613 there was no problem at all. Sadly the whole mess started with svn 1623... an no change up to svn 1694 . |
25th February 2010, 07:59 | #12004 | Link |
MPC-BE DEV
Media Player Classic HomeCinema (x86/x64), svn 1697
Supported languages: BR, BY, CN, CZ, DE, EN, ES, FR, HU, IT, KR, PL, RU, SE, SK, TR, UA Changes log Changes (1695-1697):
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. |
25th February 2010, 17:40 | #12006 | Link |
48khz mono 24 bit m2ts (l)pcm bug
Hi Casimir666,
There seems to be a long standing bug in the mpc hc m2ts splitter, which affects almost all criterion blu rays (they mostly use mono): I made a small 5 sec sample, where you can hear the bug pretty clearly. Interestingly the video ends after 5 seconds and the audio is still playing another 5 seconds with mpc hc + ffdshow(as a audio decoder) at half speed: http://www.mediafire.com/file/omtnmdnjiyy/sample.m2ts tal.aloni, debugged this in ffdshow and found that the sample works fine with the haali splitter, so the bug must be in the m2ts splitter of mpc hc. If you find the time, could you please look at this, it seems easy to fix! |
25th February 2010, 18:39 | #12007 | Link |
what's this for?
hey guys,
I'd like to know why I'm unable to get the internal mpeg2 dxva to work... my setup: - win7 home premium - graphic card: latest available OEM driver: - mpc hc output: EVR sync (though EVR/ EVR cp won't work either) ... when I choose mpeg-dxva via mpc hc it won't get used but another mpeg2 decoder is used (for example, for testing purposes I've installed CyberLink's PowerDVD9 MPEG-2 decoder v8.4.0.1014 et voilą with the above mentioned settings dxva is working and even the internal microsoft mpeg2 decoder - it's called DTV if I re-call correct - will use dxva for decoding) but no luck with mpc's mpeg dxva decoding... for VC-1 and h.264 ffdshow's respectively mpc-hc's dxva works flawless but no luck with the internal mpeg2 dxva decoding... it doesn't bug me that much but I'm interested why I can't get to work... maybe someone can help to track it down to false setting I've done or whatever... thanks in advance edit: dxva checker...
latest mix sets: http://soundcloud.com/sill Last edited by sillKotscha; 25th February 2010 at 18:48. |
25th February 2010, 20:32 | #12010 | Link | |
MPC-HC Project Manager
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
25th February 2010, 20:42 | #12011 | Link |
tetsuo55, now that you're opening threads for reporting splitter issues, maybe you could open one up for the internal ASF splitter. The "Use WM ASF Reader" option in "Tweaks" doesn't seem affect which splitter is used, and whether the box is checked or not, I consistently get 20-30 dropped initial frames on WMV1/2/3/VC-1 in ASF content when using MPC-HC. The same does not appear to happen when using WMP11 on Vista x64. In each case, I am using the WMVideo Decoder DMO and WMAudio DMO for the actual decoding. Using ffdshow as a wrapper for the WMV9 decoder or not doesn't make a difference. Thanks.
25th February 2010, 21:01 | #12013 | Link | |
25th February 2010, 21:03 | #12014 | Link |
both our splitter and haali's have exactly oposite problems. so it depends on your file
26th February 2010, 00:02 | #12015 | Link |
Video must support mode - MPEG2_VLD.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
26th February 2010, 02:29 | #12016 | Link | |
This might help Microsoft page on making application high dpi aware http://msdn.microsoft.com/en-us/libr...8VS.85%29.aspx |
26th February 2010, 07:22 | #12017 | Link |
what's this for?
and that means?
because as I said... I get mpeg2 dxva decoding to work with every other decoder but not with build in one ...
latest mix sets: http://soundcloud.com/sill |
26th February 2010, 08:05 | #12018 | Link | |
But MpcVideoDecoder support only ModeMPEG2_VLD for MPEG2+DXVA.
26th February 2010, 09:11 | #12019 | Link |
A longer explanation (maybe can be useful for others too):
The decoding process is actually made up of several phases: - Reverse Entropy - IDCT (Inverse Discrete Cosine Transform) - MoComp (Motion Compensation) - Deblocking A video card can support DXVA for one or more of the phases. You can see which using DXVA Checker. The name of the mode indicates which phase is supported. VLD (Variable Length Decoder) means the decoding process is supported as a whole: alla phases are supported, a mode known also as bitstream. You video card (as any recent ATI) supports VLD mode for H.264 and VC1, but not for MPEG2, where only IDCT is supported. Commercial players (like TMT, PDVD, etc...) support IDCT DXVA and thus you have DXVA with them. MPC-HC supports only bitstream (VLD) and thus you have DXVA for H.264 and VC1 only, not for MPEG2. This is not considered a big problem, though, becuase MPEG2 decoding in software is generally not a big burden for modern CPU. |
26th February 2010, 12:38 | #12020 | Link | |
Regarding the banding issue we discussed in AVS, I'd like to ask if it's possible for MPC-HC DXVA decoder to use dynamic range settings in CCC? I suddenly have the idea of using AVIVO to do luma expansion instead of EVR (to avoid banding). PowerDVD seems to work well to address the banding issue, and do you know what technique do they use? Thanks a lot! |
