Old 12th August 2018, 15:36   #1741  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Originally Posted by jorX View Post
In my XP - SP3 install, any version following the 2.84 doesn't works;
It says: "process exited with error code: -1073741511" without further explanation(s).
Any hints?
Thank you
-1073741511 == 0xC0000139 == STATUS_ENTRYPOINT_NOT_FOUND
The procedure entry point %hs could not be located in the dynamic link library %hs.
I suppose you see that in that log inside of Simple x264 Launcher?
It would indicate that whatever encoder (x264? x265?) you are trying to use is missing a required function from one of its required DLLs.
Probably means that Windows XP is no longer supported by the effected encoder.
(Which wouldn't be much of a surprise, considering that Windows XP has reached "end of life" more than four years ago)
[UPDATE]
Indeed, current "x264.exe" imports various functions from KERNEL32.DLL that have not been available on Windows XP yet:
https://i.imgur.com/LtNswSW.png
(Also imports some functions from BCRYPT.DLL, which is missing entirely on Windows XP)
Old 12th August 2018, 16:00   #1742  |  Link
LoRd_MuldeR
Software Developer
-1073741511 is hex 0x3ffffec7
It actually is 0xC0000139, equal to STATUS_ENTRYPOINT_NOT_FOUND, if you interpret it as 32-Bit unsigned integer, which I think is the right thing to do here.
NT_STATUS codes are defined as DWORDs, which are 32-Bit unsigned integer values, but will be typecasted to 32-Bit signed integer values when returned as a process' exit code.
(Hence, if the original unsigned value had its most significant bit set, the signed value will have negative sign)
#include <stdint.h>
int main()
    const uint32_t code = (uint32_t)(-1073741511);
    printf("0x%X\n", code);
    return 0;
Output:
0xC0000139
Old 13th August 2018, 20:11   #1743  |  Link
LoRd_MuldeR
Software Developer
Simple x264 Launcher v2.88
https://github.com/lordmulder/Simple...ases/tag/v2.88
Version 2.88 [2018-08-11]
* Updated x264 to revision 2932 (API v157)
* Updated x265 to version 2.8+57
Old 11th October 2018, 19:19   #1744  |  Link
vehf263
Exact installation paths of Avisynth and Vapoursynth needed
I installed Simple Launcher using .exe setup and extracting from .zip.
In both cases Launcher says it has no Vapoursynth installed.
I tried to do so according your readme.html. No luck.
InstallPath\
├─ x264_launcher_portable.exe
└─ extra\
└─ Avisynth\
├─ x86\
│ ├─ avisynth.dll <32-Bit>
│ ├─ devil.dll <32-Bit>
│ └─ etc…
└─ x64\
├─ avisynth.dll <64-Bit>
├─ devil.dll <64-Bit>
└─ etc…
It's your path to install both Vapoursynth and Avisynth from your readme.html.
The path you provide is not enough clear or is not actual.
Please I need a today's path to install both Vapoursynth and Avisynth.
Thank you.
vehf263 is offline   Reply With Quote
Old 11th October 2018, 20:02   #1745  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by vehf263 View Post
InstallPath\
└─ extra\
└─ Avisynth\
├─ x86\
│ └─ etc…
└─ x64\
└─ etc…
Thank you.
If you want to use Avisynth and/or VapourSynth in "portable" mode, you need to follow the install instructions exactly:
http://muldersoft.com/docs/x264_laun...#portable-mode
Also note that the files need to be arranged exactly as depicted in the README file. And especially note the remark about "embeddable Python", if you want to use VapourSynth portable!
Last but not least, you can launch "x264_launcher.exe" with option "--console" to get more details about Avisynth/VaopurSynth detection...
Old 12th October 2018, 02:00   #1746  |  Link
videoh
Useful n00b
Minor cosmetic issue:
Thanks for this great program.
Old 12th October 2018, 11:20   #1747  |  Link
vehf263
Avisynth script execution
Thank you for your patience.
One more question.
How can I execute some particular Avisynth scripts while using Simple x264 Launcher?
Thank you.
Old 12th October 2018, 22:35   #1748  |  Link
LoRd_MuldeR
Software Developer
Should be somewhat better in new version.
One more question.
Uhm?
You "execute" an Avisynth script simply by selecting as the source file for your encoding job, and then launching that job – if that was the question.
Old 12th October 2018, 22:36   #1749  |  Link
LoRd_MuldeR
Software Developer
Simple x264 Launcher v2.89
https://github.com/lordmulder/Simple...ases/tag/v2.89
Version 2.89 [2018-10-12]
* Updated x264 to revision 2935 (API v157)
* Updated x265 to version 2.9+1
* Improved initial window size on the "High DPI" screen
* Updated build environment to Visual Studio 2017 with Update-8
Old 13th October 2018, 15:29   #1750  |  Link
vehf263
Hmm
Will such a script of three actually working string work without any error?
#LoadPlugin("C:\Program Files\MeGUI\tools\ffms\ffms2.dll")
#FFVideoSource("D:\Temp00\StatusQuo.video.mkv", fpsnum=30000, fpsden=1001, threads=1)
selectTotal1=framecount()/100
selectTotal2=selectTotal1*2
selectrangeevery(selectTotal2,50)
you generate an index file by your internals, so there is no needs to generate it in this tiny script.
Old 13th October 2018, 15:33   #1751  |  Link
videoh
Useful n00b
Your script must have a source filter, otherwise it does not provide a clip.
Old 13th October 2018, 22:50   #1752  |  Link
vehf263
Yup, I got it myself but thank you anyway.
loadplugin("C:\Program Files\MeGUI\tools\AviSynth\plugins\DirectShowSource.dll")
clip=DirectShowSource("D:\Temp00\StatusQuo.video.mkv", convertfps=true)
selectTotal1=framecount(clip)/100
#selectrangeevery(selectTotal2, 50, 0, false)
selectrangeevery(clip)
Old 14th October 2018, 19:01   #1753  |  Link
videoh
Useful n00b
Trust, but verify.
Old 31st October 2018, 18:17   #1754  |  Link
tormento
Acid fr0g
tormento's Avatar
@LoRd_MuldeR
Would you please add unicode support to log, both window and saved one?
@turment on Telegram
Old 31st October 2018, 20:08   #1755  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by tormento View Post
@LoRd_MuldeR
In what sense?
The "main" application is fully Unicode-aware. The output stream produced by the encoder will be interpreted as UTF-8 and will be displayed as proper Unicode.
However, be aware that some of the tools we use may not support Unicode! (Avisynth *cough*)
Old 2nd November 2018, 10:33   #1756  |  Link
tormento
Acid fr0g
tormento's Avatar
I had that doubt.
Let's break the balls to Pinterf
Old 22nd December 2018, 13:01   #1757  |  Link
spoRv
First, thanks a lot, LoRd_MuldeR, you made a great software!
I usually use it with a lossless file as source, but now that I need to feed it with an avisynth script, I have an error that talks about anaglyph.avsi is missing (sorry, not at my computer now...)
The fact is, the avisynth script contains just avisource commands (to chain various lossless files) and nothing more, for sure not an anaglyph command... and, by the way, that anaglyph.avsi file is in the avisynth plugins directory.
The error came up both with an older version and with the newest one.
May you help me? Thanks a lot in advance!
spoRv is offline   Reply With Quote
Old 22nd December 2018, 14:25   #1758  |  Link
LoRd_MuldeR
Software Developer
This error message originates from Avisynth, so not actually a Simple x264/x265 Launcher error. What if you open the exactly same .avs file in, e.g., VirtualDub?
My advice would be to make sure your AVS script really doesn't import/load anything that isn't needed. Also, make sure you remove any .avsi file and any plugin DLL from your Avisynth "plugin" directory that isn't required! Actually I much prefer to keep my Avisynth "plugin" directory to the bare minimum and explicitly load additional plugins (or import additional .avsi files). There's too much that can go wrong, if you bloat your Avisynth "plugins" directory with "legacy" stuff...
BTW: You are using latest "stable" official Avisynth 2.6, or something else?
Old 23rd December 2018, 01:19   #1759  |  Link
spoRv
The script works perfectly on VirtualDub (or VirtualDubMod).
About plugins full of stuff: you are right, mine is full of them, but I can't remember anything I need, anytime, to load them for every script I use... the fact is, for some scripts, I could use up to twenty, if not more, plugins and/or .avsi files!
I use 2.6.0.5 on Windows 10.
Auto-hint: maybe I could just rename the plugin folder temporarily, and see if in the case of a simple script with just avisource commands it works!
Old 24th December 2018, 08:29   #1760  |  Link
spoRv
Solved!
Indeed, I just put the (very few) necessary plugins for a very light script, and it works!
Now, I'm curious to know how to get rid of potentially harm plugins - not only for your software, but in general... but this could be material for a new thread (or is there an existing one?)
