20th November 2008, 22:01 | #7081 | Link | |
BR= Back Right |
20th November 2008, 22:58 | #7083 | Link |
got a DTS 5.1 track here, eac3to reports it as DTS 5.1, while PowerDVD says it's DTS-ES 5.1
so which is right in this case? http://www.sendspace.com/file/79229m |
20th November 2008, 23:24 | #7084 | Link | |
Location: The Great North (the better half of North America)
eac3to v2.72 command line: e3\eac3to c:\videos\test\dts sample.dts c:\videos\test\log.txt -logdts ------------------------------------------------------------------------------ + DTS-Core - frameSize 1006 - DTS-ES - - channelNo 5 - lfe 1 - channelDescr 5.1 - samplingRate 48000 - bitDepth 24 - bitrate 768000 - samplesPerFrame 512 - copyHistory 1 DTS, 5.1 channels, 0:09:16, 24 bits, 768kbps, 48khz |
21st November 2008, 04:20 | #7088 | Link |
I just got the Wall E Blu-ray and it's supposed to have DTS-HD Master Audio 6.1 but eac3to shows only 5.1.
I was wondering what the "($f)" is under Active speakers. Edit: let me clarify, the box says 5.1 DTS MA but blu-ray.com says 6.1 DTS-MA and several reviews have indicated 6.1 so maybe I'm just reaching for something that just isn't there... Code:
D:\Program Files\eac3to>eac3to.exe "c:\Audio Testing\20000.m2ts" -logdts + DTS-Core - frameSize 2012 - DTS-ES + - channelNo 5 - lfe 1 - channelDescr 5.1 - samplingRate 48000 - bitDepth 24 - bitrate 1509000 - samplesPerFrame 512 - copyHistory 1 + DTS-HD - fullSize 2776 - headerSize 32 - refClockCode 1/48000 - frameDurationCode 1 - activeMasks [1], [[1]] + Asset [0] - fullSize 2744 - headerSize 14 - corePackets Core - extSubStrPackets XLL - bitResolution 24 - maxSampleRate 48000 - totalNumChannels 6 - activeSpeakers C L R Ls Rs LFE ($f) M2TS, 3 video tracks, 3 audio tracks, 3 subtitle tracks, 1:37:26 1: Chapters, 32 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: h264/AVC, 480p24 /1.001 (20:11) 4: h264/AVC, 480p24 /1.001 (20:11) 5: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz (core: DTS-ES, 5.1 channels, 24 bits, 1509kbps, 48khz) 6: AC3 Surround, English, 2.0 channels, 192kbps, 48khz 7: AC3 Surround, English, 2.0 channels, 192kbps, 48khz 8: Subtitle (PGS), English 9: Subtitle (PGS), English 10: Subtitle (PGS), English D:\Program Files\eac3to> Last edited by lithiumus; 22nd November 2008 at 22:50. |
21st November 2008, 07:36 | #7089 | Link | |
21st November 2008, 14:57 | #7092 | Link | |
If you just need the wave files, then you can just do as already suggested and convert directly to waves.
Chumbo |
21st November 2008, 15:49 | #7093 | Link |
madshi, could you please implement a kind of detection which reports 2.0 tracks being mono or stereo tracks? would be useful for older movies, sometimes those original tracks are either 1.0 or 2.0 mono. then it would be possible to distinguish if a studio included an original 2.0 mono track or if they did use a modified stero track.
22nd November 2008, 15:20 | #7094 | Link |
F:\>eac3to sin.m2ts 1: e:\sin.mkv 3: e:\sin.flac
M2TS, 1 video track, 2 audio tracks, 4 subtitle tracks, 2:03:59 1: h264/AVC, 1080p24 /1.001 (16:9) 2: AC3, 5.1 channels, 640kbps, 48khz 3: DTS Master Audio, 7.1 (strange setup) channels, 24 bits, 48khz (core: DTS, 5.1 channels, 24 bits, 1536kbps, 48khz) 4: Subtitle (PGS) 5: Subtitle (PGS) 6: Subtitle (PGS) 7: Subtitle (PGS) CAUTION: Decoding this track with ArcSoft results in low volume. [v01] Extracting video track number 1... [a03] Extracting audio track number 3... [a03] Decoding with ArcSoft DTS Decoder... [v01] Muxing video to Matroska... [a03] Encoding FLAC with libFlac... [a03] Creating file "e:\sin.flac"... "Strange setup" and "CAUTION: Decoding this track with ArcSoft results in low volume" What does this mean? |
23rd November 2008, 00:03 | #7097 | Link | |
C:\>eac3to\eac3to C:\sample.m2ts C:\s_out_video.h264 C:\s_out_audio.flac M2TS, 1 video track, 2 audio tracks, 4 subtitle tracks, 0:00:26 1: h264/AVC, 1080p24 /1.001 (16:9) 2: AC3, 5.1 channels, 640kbps, 48khz 3: DTS Master Audio, 7.1 (strange setup) channels, 24 bits, 48khz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz) 4: Subtitle (PGS) 5: Subtitle (PGS) 6: Subtitle (PGS) 7: Subtitle (PGS) Track 3 is used for destination file "s_out_audio.flac". CAUTION: Decoding this track with ArcSoft results in low volume. CAUTION: Decoding this track with ArcSoft results in low volume. [a03] The Arcsoft DTS Decoder only allows one operation at a time. Code:
C:\>eac3to\eac3to C:\sample.m2ts C:\s_out_audio.flac M2TS, 1 video track, 2 audio tracks, 4 subtitle tracks, 0:00:26 1: h264/AVC, 1080p24 /1.001 (16:9) 2: AC3, 5.1 channels, 640kbps, 48khz 3: DTS Master Audio, 7.1 (strange setup) channels, 24 bits, 48khz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz) 4: Subtitle (PGS) 5: Subtitle (PGS) 6: Subtitle (PGS) 7: Subtitle (PGS) Track 3 is used for destination file "s_out_audio.flac". CAUTION: Decoding this track with ArcSoft results in low volume. [a03] Extracting audio track number 3... [a03] Decoding with ArcSoft DTS Decoder... [a03] Encoding FLAC with libFlac... [a03] Creating file "C:\s_out_audio.flac"... [a03] The last DTS frame is incomplete and thus gets skipped. [a03] The original audio track has a constant bit depth of 24 bits. Video track 1 contains 622 frames. eac3to processing took 7 seconds. Done. Last edited by rica; 23rd November 2008 at 00:06. |
23rd November 2008, 00:12 | #7098 | Link |
When you give the adrress of video and audio; this is the result:
eac3to v2.77 command line: eac3to\eac3to C:\sample.m2ts 1: C:\s_video.h264 3: C:\s_audio.flac ------------------------------------------------------------------------------ M2TS, 1 video track, 2 audio tracks, 4 subtitle tracks, 0:00:26 1: h264/AVC, 1080p24 /1.001 (16:9) 2: AC3, 5.1 channels, 640kbps, 48khz 3: DTS Master Audio, 7.1 (strange setup) channels, 24 bits, 48khz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz) 4: Subtitle (PGS) 5: Subtitle (PGS) 6: Subtitle (PGS) 7: Subtitle (PGS) CAUTION: Decoding this track with ArcSoft results in low volume. [a03] Extracting audio track number 3... [v01] Extracting video track number 1... [a03] Decoding with ArcSoft DTS Decoder... [a03] Encoding FLAC with libFlac... [v01] Creating file "C:\s_video.h264"... [a03] Creating file "C:\s_audio.flac"... [a03] The last DTS frame is incomplete and thus gets skipped. [a03] The original audio track has a constant bit depth of 24 bits. Video track 1 contains 622 frames. eac3to processing took 8 seconds. Done. |
23rd November 2008, 05:21 | #7099 | Link | |
23rd November 2008, 11:20 | #7100 | Link | |||||||||||||||
In case of a 7.1 track, SL/SR are the channels intended for the side speakers while BL/BR are intended for the back speakers. In case of a 5.1 track, the surround channel pair can be played through SL/SR with the back channels not playing any sound. Or you can use some funny algorithms to upconvert 5.1 to 7.1. If you play a 7.1 track on a 5.1 speaker setup (or if the studio downmixes 7.1 to 5.1) the 5.1 surround channel pair usually contains a mix of the 7.1 SR/SR and BL/BR channel pairs. It doesn't matter much whether you name the 5.1 surround channel pair SL/SR or BL/BR. But IMO SL/SR is the correct name. Quote:
The "($f)" is the hex value of the "activeSpeakers" bitstream element. What it means is shown in the log, namely "C L R Ls Rs LFE". These are the speakers contained in the DTS-HD track. You can see, there is no Back channel in the track, just plain 5.1. Quote:
Why does ArcSoft lower the volume? Don't ask me. It's caused by the speaker mapping the studio has chosen. DTS-HD supports a big number of different speaker mappings for 7.1 streams. There are at least 3 different mappings the ArcSoft decoder decodes perfectly. But this specific speaker mapping used for this track seems to confuse the ArcSoft decoder, which makes it decode the track with lower volume. It's not a terribly bad thing, it's more or less similar to the effect DialNorm has. If you want, you can report this problem to the ArcSoft guys (together with a small sample). Should be easy for them to fix. Just ask them to decode the sample as 5.1 and then as 7.1. The 7.1 decoding volume will be lower, which doesn't really make any sense. With almost every other 7.1 track on the planet the 7.1 decoding volume is not lower. You can use "-logdts" to see which speaker mappings a specific 7.1 DTS-HD track uses... |
eac3to |
