11th November 2016, 20:08 | #21181 | Link |
Thanks
So i've to delete xysubfilter from external filters? I've it setted in subtitle options yet. 1. yes, i set them as preferred. I have to turn back selected internal filters or i can leave them deselected? asking just to be sure :P
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM |
11th November 2016, 20:19 | #21182 | Link | ||
11th November 2016, 20:44 | #21183 | Link |
Ok, thanks.
Removed it from ex. filters. So i'll leave internal disabled. What about difference between lav splitter and lav splitter source? But it automatically download subs too?
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM Last edited by steakhutzeee; 11th November 2016 at 22:13. |
12th November 2016, 09:49 | #21185 | Link |
Hi nevcairiel!
I just need to be clarified if lav supports hardware acceleration on a video that is is 4:2:2 10bit x265? Experimented on one today. It seems the "GPU" icon doesn't show in MPC-BE which is an indicator that GPU is being utilized. Lav icons are no where to be found as well in the task bar. Is it a bug?
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR |
12th November 2016, 09:50 | #21186 | Link |
4:2:2 is generally not hardware accelerated. Only 4:2:0.
12th November 2016, 11:57 | #21188 | Link |
Its a hardware limitation.
12th November 2016, 16:19 | #21189 | Link |
pretty strange......
I have got a second-hand display card when i use this one to play movies it is causing tearing of the screen...... when i chose filters other than lavfilter everything went well...... it never happened on my old card...... My card is amd hd 6700 series (asus 6750) drivers are all the latest...... only when use "lavfilter" filter could have this issue so i could be sure it is lavfilter's problems....... wish it could be fixed in the later version...... Thx for all your greatwork |
12th November 2016, 16:33 | #21190 | Link | |
I can't see your images inline, because PhotoBucket wraps them in an ad-bloated website... so here as links:
In your case, it seems to be either a decoding error or a rendering error. Regarding the amount of issues and their pattern in the 4th image, probably the latter. Last edited by LigH; 12th November 2016 at 16:36. |
12th November 2016, 19:48 | #21191 | Link | |
I dont know how to describe it...... so i say tearing...... did some test on it after the post... potplayer: lavfilter decoder: vmr9 -rare occasions EVR(CP) -always d3d9 -always madshi randerer -never opengl randerer -never ffmpeg decoder: vmr9 -rare occasions and less effect EVR(CP) -rare occasions and less effect d3d9 -rare occasions and less effect madshi randerer -never opengl randerer -never Last edited by uneedme; 13th November 2016 at 09:45. |
13th November 2016, 18:11 | #21192 | Link |
I've to enable and prefer "File Source (Async)" using lav splitter?
In this page i read that lav splitter source is an old version of lav splitter, so which i've to use? https://bypureland.wordpress.com/201...D%89%E8%BC%89/
14th November 2016, 02:15 | #21196 | Link | ||
My reason is simple - as I am on a laptop, I don't want to unnecessarily produce more heat/spin up the fans/consume more power than necessary when on battery. In other words, I don't want to completely disable DXVA2 and deal with the according reduction in battery life (especially with 60fps 720p videos) just because I want to be able to watch 1080p videos when plugged in to the wall. Last edited by Nintendo Maniac 64; 14th November 2016 at 02:18. |
14th November 2016, 10:59 | #21197 | Link | |
PS. You are lucky - you have this possibility - many people of the world who see artifacts with DXVA can not switch it of in LAV Video Decoder and they don't know about LAV CUVID Decoder. They have to switch off hardware acceleration because they have no choice (but sometimes with weak CPU it is impossible to decode smooth 1080p without hardware acceleration). I hope for them that nevcairiel will add possibility to switch off DXVA Processing in LAV Video Decoder. Last edited by VictorLS; 14th November 2016 at 12:22. |
15th November 2016, 13:01 | #21198 | Link |
Hi nev, I have a strange subtitle bug when using LAV splitter 0.68.1.
It's certainly related to the fact my htpc is still running XP 32bit, but I hope a fix is possible ^^; In effect, when using LAV Splitter Source, some subtitles signs are missing: http://videoff7.free.fr/samplecbbp_LAV.png http://videoff7.free.fr/samplecbbp_haali.png sample: http://videoff7.free.fr/samplecbbp.mkv when using Haali, it displays just fine. Absolutely everything else in the decoding chain is unchanged, I only alter the splitter source. Can you make sense of it? I looked/tried everything and couldn't ^^; Thanks.
XP SP3 / Geforce 8500 / Zoom Player Last edited by TheShadowRunner; 15th November 2016 at 13:04. |
15th November 2016, 14:23 | #21199 | Link |
Interesting issue. Apart from the exclamation mark and double quotes being handled like "non-printable characters" and being substituted by empty placeholders (just a kind of space char, with a wider width than the excl.), all other alphanumeric characters appear to be quite identically rendered.
