Old 8th December 2009, 09:30   #41  |  Link
Zathor
Originally Posted by JoeH View Post
Here are the installation instructions I followed. As I had a few difficulties getting it installed, and finally found a safe and sure method, I thought I'd post it here:
1. Install the standard version 1056 from SourceForge
2. Update all parts using the "Stable" servers except the 1056 core
3. Change update server to development. Update all parts again except the 1056 core (if you do this without doing step 2 first you will get an error).
4. Copy the files that Zathor has prepared and select replace all.
When you open up MeGUI you will have a fully functional 1057 install, with full support for the new X264 features! Fantastic!
Thanks for your reply.
With the newest build it is even easier to install:
1. Install Avisynth 2.5.8 (if not already installed)
2. Extract my build to a new/empty directory
3. Run the program and let it update all necessary files from the development server.
4. Update some files manually (x264.exe, ...)
Zathor is offline   Reply With Quote
Old 8th December 2009, 11:20   #42  |  Link
nakTT
May I know which one U mean by "newest build"? Is it the one at the 1st post or the one at the 2nd page?
nakTT is offline   Reply With Quote
Old 8th December 2009, 11:23   #43  |  Link
forum king
thanks mate
i have used the latest development build of urs ..
but tell me when i usesd to use 1051 with unrestricted 2 pass profile the settings were that of SLOWER
in mean like this :
program --profile high --pass 2 --bitrate 1000 --stats ".stats" --ref 5 --b-adapt 2 --b-pyramid --direct auto --deblock -1:-1 --trellis 2 --partitions all --me umh --thread-input --output "output" "input"
but in this one ( the new patched 1057 build the settings in that same profile are FAST..
program --profile high --preset fast --pass 2 --bitrate 1000 --stats ".stats" --thread-input --deblock -1:-1 --no-dct-decimate --output "output" "input"
what should be done ( does it mean that in the new megui build and x264 build SLOWER stuff is more faster or i need to drag the slider to slower to get the same settings.. and quality as that of unrestricted 2 pass
forum king is offline   Reply With Quote
Old 8th December 2009, 11:49   #44  |  Link
Triccotracco
The one in the first page, is true that at 2nd page there is a newer version but with a lot of changes, if I understand well.
Also for me patched 1057 version works fine & faster (used with x264 rev.1360 Jeeb's build)
Thank you again!
Triccotracco is offline   Reply With Quote
Old 8th December 2009, 11:52   #45  |  Link
forum king
its very clearly mentioned on page 1
Stable build
http://www.mediafire.com/download.php?hj23mmmlmux
Development build with the additional changes below
http://www.mediafire.com/download.php?mfwnemetzt4
i have used the developmemnt build and its working great...
Old 8th December 2009, 12:32   #46  |  Link
nakTT
Thank you again!
I see. I have just downloaded the unpatched one.
I'm interested to know about the "faster" bit for the patched 1057. Hope you can share your experience in a little bit detail.
Old 8th December 2009, 12:46   #47  |  Link
quantum5uicid3
better solution...
quantum5uicid3 is offline   Reply With Quote
Old 8th December 2009, 12:58   #48  |  Link
forum king
well guys i am giving up
looks like i cant use the latest megui builds and the benefits of x264.
i have done everything as was said here and at the troubleshooting thread..
but it just wont work out..
i used the latest build by Zathor ( the 2nd one ) and installed it in a separate folder..
used unrestricted 2 pass HQ with SLower settings
it will do the first pass and give a STANDARD ERROR STREAM error upon second always..
sometimes the same error on first pass as well..
can someone please please please guide me how should i go about it all.. i have been trying to do this from last 3 days in TOTALO vain.
it looks i ll have to go back to 1051
Old 8th December 2009, 13:02   #49  |  Link
quantum5uicid3
stop trying to use the old presets. theyre no longer applicable
Old 8th December 2009, 13:04   #50  |  Link
forum king
o damn !!!
then which one is equivalent to unrestricted 2 pass now ..
i need something equivalent to that with no blurred edges and no pixelations at all.
thanks
Old 8th December 2009, 13:08   #51  |  Link
quantum5uicid3
your gonna have to create your own presets, because nobody has taken time to do so yet. putting the preset slider on "slower", change the mode to automated twopass, uncheck the turbo, and entering the bitrate will be pretty damn close to what you were doing before
do what i said in my post above, so you can get all the old junk out of the way. you'll have a fresh new megui with no presets, then use this information to create your own presets based on your needs.
http://mewiki.project357.com/wiki/X264_Settings
you don't need to understand all of it, the default values and the presets built into x264 is all you need to be aware of
here's the settings you need if you want compatibility with a certain device
http://forum.doom9.org/showthread.php?t=149711
Old 8th December 2009, 13:13   #52  |  Link
forum king
ok as you say dear Sir !!!
but if i am right turbo used to be on in the past ,
BTW i am kinna noob in all this , setting it up would be so damn diff for me..
cant i just set it up as it was earlier in the unresticted 2 pass .. i have screenshotts of the 1051 version presets settings,
EDIT also , u said first to install 1056 then ur build ..
do we have to update 1056 first and then install ur build or how ?
also the 1309 x264 is there in ur update should i also replace this with 1360 from x264.nl
please forgive me noobiness , but my head is now aching with all this :P
regards
Glenn
Old 8th December 2009, 13:19   #53  |  Link
quantum5uicid3
turbo turns the options way down for the first pass. what i'm telling you is that the defaults in conjunction with presets built into x264 really replace the need for sharktooth's presets. setting up x264 is nowhere near as complicated as it was before.
do you even need to hit a specific file size?
Old 8th December 2009, 13:22   #54  |  Link
kool
a very 1th error I get under Win 7, I have installed as Zathor says
Error 1: happen when I select all profile and hit on import.
Error 2: same as error 1
Error 3 & 4 at the same time when I want to close meGUI.
kool is offline   Reply With Quote
Old 8th December 2009, 13:24   #55  |  Link
forum king
yes
actually i am trying to make some dvds and and some HD content to a lower size like around bitrate of 600 to 700..
Old 8th December 2009, 13:27   #56  |  Link
quantum5uicid3
regards
Glenn
no
1. uninstall and remove any traces of megui
2. install 1056, but dont even run it (this is just to provide the uninstaller and shortcuts, im lazy)
3. download and install the package of 1057 i put together ( it is fully up to date so no need to copy x264)
Old 8th December 2009, 13:34   #57  |  Link
forum king
no
yupp i have done it like that..
now the issue is how to make a profile which can rip on the same grounds as the unrestrcited 2pass was doing earlier in earlier builds.
Old 8th December 2009, 13:37   #58  |  Link
quantum5uicid3
like i said before, putting the preset slider on "slower", change the mode to automated twopass, uncheck the turbo, and entering the bitrate will be pretty damn close to what you were doing before. leave turbo checked if you'd like but if your encoding down below 1000kbps, your gonna need to squeeze as much as you can out of it
Old 8th December 2009, 13:43   #59  |  Link
quantum5uicid3
kool, i had problems with the audio presets as well. thats why i made that package. ru using 32 or 64bit windows 7?
Old 8th December 2009, 13:53   #60  |  Link
forum king
Thanks Q
i donno anything about the options and yes i generally encode below 700 bits almost always :P so if u say it shouls be unticked then it ll be unticked dear Sir
what about deblocking strength coz i found thats thew only thing that has changed in this..
in earlier presets it used to be -1:-1 but tyhe default in that lone preset now is 0:0 should i change that..
if u can suggest anything which will be beneficial for ripping on low bit rate and getting good quality then please
regards
Glenn
