#49064 | Link |
Upload is very slow, odd. Do you have "present a frame for every VSync" enabled? Try changing it. Also try changing "use a separate device for presentation". How does "enable automatic fullscreen exclusive mode" influence it?
How about f.lux or other programs that interact with the GPU? This looks like Optimus or other odd architecture issue but of course you are using AMD with a dGPU. Edit: The issue is getting the frame from the decoder to the GPU, usually a memory bandwidth problem (that can be caused by drivers or software along with hardware limitations).
madVR options explained Last edited by Asmodian; 19th February 2018 at 18:56. |
#49065 | Link | |
There is no other programs that interact with the GPU. After my testing,I found it that only 10bit videos lag too much.Is that really a memory bandwidth problem? |
#49067 | Link |
"More than 8 bit per component" also means "more than one byte" ... so processing 10 bit may already require twice the memory bandwidth, even if just in a part of the processing.
But a lack of hardware accelleration due to unsupported attributes weights more. |
#49068 | Link |
can someone help me understand this. Star trek 2009, I have a 1080p remux, a 2160p remux and a 2160p HDR remux. I have set MADVR so it only outputs in 2160p so it should only be upscaling the 1080p version, right?. If so then it should take more GPU processing to do this, right?
I'm using lanczos for chroma upscale and NGU sharp medium for image upscale, here are my results on my AMD RX 550. 1080p GPU 83% Rendering times 33 ms 2160p GPU 92% Rendering times 32ms 2160p HDR Rendering times - 147ms GPU - unknown - probably 99% Something has defo changed with HDR playback, dont know if its MADVR or GPU drivers as I was able to get smooth HDR playback with these settings, now HDR is unwatchable. I went back a few versions in MADVR and it made no difference so I guess it could be drivers. Anyone else out there with an crappy RX 550 who can share their settings / experiences? time for a new card maybe, used RX 480/580 maybe. |
#49070 | Link |
Ive just reinstalled MADVR and i'm back to reasonable rendering times and smooth playback now, getting about 33ms for 4k/4k HDR stuff, still running my card over 90% though, MADVR really doesnt like my RX 550.
what is odd however is if I tick all the perf vs quality ticks it make pretty much zero difference, should this be doing something here? https://www.dropbox.com/s/6i5qpd5orr...23%5D.jpg?dl=0 |
#49071 | Link |
But what are your GPU clock speeds doing? Render time may stay the same but you're using less power.
Also.. Your screenshot doesn't show me anything obviously set up wrong.. Do you have some image processing on? Last edited by ryrynz; 19th February 2018 at 23:30. |
#49077 | Link |
what is it that most effectively determines the power of a GPU in MADVR, processing units, shaderss?, looking at these stats should I expect a more than double performance out of an RX470, how do we think these cards scale real life, worth the upgrade?
Radeon RX 570 Radeon RX 550 GPU Name Ellesmere (Ellesmere PRO) vs Polaris 12 (Baffin XT) Fab Process 14 nm vs 14 nm Die Size 232 mm² vs 0 mm² Transistors 5,700 million vs unknown Shaders 2048 vs 640 Compute Units 32 vs 10 Core clock 926 MHz vs 1125 MHz ROPs 32 vs 16 TMUs 128 vs 40 |
#49079 | Link | |
Thanks, I did not know that. Just so we're clear, you do mean video decoding, and not the navigator? Does that also apply if the DVD is deCSS'd?
MediaInfo says progressive for all VOBs of NCfOM, and if I play the main feature from the start it indeed plays as progressive ("deinterlacing off (says upstream)"), like in the screenshot of the Paramount Vantage logo intro I took of it for steakhutzeee). For Zodiac, MediaInfo says interlaced for the 1st VOB but progressive for the others. If I play the main feature from the start it plays as interlaced ("deinterlacing on (says upstream)"), but if I play the second VOB directly it plays as progressive. I know MediaInfo only looks at the start of the file, and there's a ~12 second Warner logo intro clip at the start, I guess it's probably flagged as interlaced even though it isn't (no artifacts when I force weave on it). ![]() I suspect what's happening is the decoder isn't detecting when the frame flags change from interlaced to progressive, like when you go from the menu to the main feature or when a main feature has interlaced intro clips, and that's why I have to stop after the feature has started and then resume from where I left to have my DVDs automatically play as progressive. I clearly remember when I used the old NVIDIA PureVideo MPEG2 decoder 10 years ago, it was switching between interlaced and progressive on the fly with my DVDs. I'll continue this discussion in the LAV thread to ask nevcairiel. (for the anecdote, I have only one PAL DVD in my collection that I can't watch in progressive: The Abyss Extended Edition, R2 belgian. I don't know what the hell happened when they mastered that thing ![]()
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti Last edited by el Filou; 20th February 2018 at 01:27. |
