Old 25th November 2015, 12:23   #34381  |  Link
a8213711
Originally Posted by chros View Post
Try out FSE Old path, maybe you'll get more speed (see below).
As for fullscreen exclusive mode, I have it disabled because the screenshot issue.
What GPU do you have? laptop or desktop?
My gpu is an integrated in an old laptop!
Bilinear where? image or luma upscaling? with what content and display resolution?
Bilinear everywhere, and for content of many different types and on a 1080 TV, therefore I can't use a fixed resolution to disable any up/down scale, and suggested to implement a Disable command.
If you'd disable upscaling, with an 720p contonet on a 1080p screen, the image will be only in the middle of the screen. I don't think that you want to do that
Shouldn't the TV do the upscale and fill the screen? That's what I would like to see (probably will try it in the weekend, but any feedback is still welcome).
If you used an installer for MPC-HC then it can be a problem. Either you can make a backup of the appropriate regisrty entries before uninstallation or you can leave there the other one. If you just extracted it to a folder then you can delete it.
I did use the installer; I suppose leaving both it's the easiest solution, although not very clean.
You won't have these problem with the filters (e.g. madvr), you can leave them there.
Actually I have madVR and XySubFilter in the MPC-HC x86 folder, therefore this should be another problem if I want to install MPC-HC x64 and retain their settings. I'm scared to try anything if I don't know what I'm doing. Can I simply move these 2 filter folders on new MPC-HC x64 folder?
Many thanks!
a8213711 is offline   Reply With Quote
Old 25th November 2015, 12:37   #34382  |  Link
Asmodian
Originally Posted by j5627429 View Post
I am scaling quite a bit anyway for all of my video content, so why is there such a big difference in performance for a near-1080p resolution to 4K versus 1080p?
1920x1080 -> 3840x2160 = smooth playback
1280x718 -> 3840x2160 = smooth playback
1916x1076 -> 3840x2160 = extremely choppy ~1fps playback
The only way I can play back the 1916x1076 file smoothly is to greatly reduce super-xbr image doubling to only double or off (versus octuple that I normally use)
Do you have image quadrupling set to "always"?
In that case when watching 1920x1080 only doubling runs but when watching 1916x1076 both doubling and quadrupling run. Doubling 3832x2152 to 7664x4304 and then downscaling to 3840x2160 takes a lot of performance and is pointless. Set quadrupling to only run with 1.5 or 2x scaling, in fact I would recommend setting doubling and quadrupling to 1.5x scaling, maybe 1.2x if you really like doubling, but always does more harm than good in my opinion.
Doubling or Quadrupling do not run unless the image is upscaled, no matter what you set in "image doubling" quadrupling will never run for 1920x1080 video on a 4K display.
madVR options explained
Old 25th November 2015, 13:07   #34383  |  Link
YxP
If you send 1920x1080 TV 1280x720 signal, then yes, it should fill the screen. I don't know why you would want to do this instead of using lighter players though. I'm guessing whatever good madvr is achieving is lost during TV's processing.
YxP is offline   Reply With Quote
Old 25th November 2015, 13:58   #34384  |  Link
hannes69
I found a strange behavior/bug by using the new Radeon Crimson driver. I updated recently the rest of the video software (madVR, LAV filters, MPC HC nightly) so the driver is not certainly the culprit.
GPU: Radeon R7 250
Driver: Radeon Crimson
affected rendering modes: fullscreen modes (both windowed and exlusive), no problem while NOT rendering fullscreen
behavior: all 4 queues + rendering and presenting times jumping wildly, queues partially running empty so dropped frames, decoder queue showing 20-25/24
"remedy": deactivating smoothmotion and/or checking "use 10bit image buffer instead of 16bit" in trade quality for performance section -> normal behavior
Edit:
Reverted now back to Catalyst 15.7.1. Everything ok now. In my case Radeon Crimson seems to be not ok for my system. Furthermore I found out that most of video related settings are completely removed from Control Center. I stay with 15.7.1 meanwhile, was a mistake to install new AMD crap.
Edit2 (10.12.15):
New test with Crimson: new "real" remedy: reducing rendering queues to maximum 21 (was 24 in my case).
hannes69 is offline   Reply With Quote
Old 25th November 2015, 16:05   #34385  |  Link
chros
chros's Avatar
Screenshot??? Use a different player for that functionality or switch to windowed mode in madvr until you take one.
Was FSE Old path faster for you?
Unistall them first, move them, them install them again.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config
Old 26th November 2015, 00:56   #34386  |  Link
wolfman2791
wolfman2791's Avatar
GPU: Radeon R7 250
Edit:
The issue is the "fullscreen exclusive" option. It's not supported on the new AMD driver. Disable that and use windows overlay... then it works for me.
The new driver is 3-5% faster so it's worth trying it out.
wolfman2791 is offline   Reply With Quote
Old 26th November 2015, 05:11   #34387  |  Link
QBhd
QB the Slayer
QBhd's Avatar
FSE Works fine for me, so saying it's not supported is a little over the top.
As for the new AMD drivers... I think they are pretty good, still in need of some work (some settings are in the old CCC interface and others in the new interface)... But one thing that is fantastic, the new Custom Resolutions. No need for a separate app like CRU anymore
QB
QBhd is offline   Reply With Quote
Old 26th November 2015, 10:06   #34388  |  Link
aufkrawall
Well, as I already said, please check the queues in DX11 FSE.
Old 26th November 2015, 10:44   #34389  |  Link
Francois76l
Madvr 3dlut gamma editor
Hello Madshi
I have one demand/question:
Many of us are experiencing the same problem: i1d3 (or low end colorimeters) measure our display with a perfect black (accuracy problem) and the result is always a linear gamma from 0 to 100%. The reason is simple: perfect black = infinite contrast ratio but we don't have an oled tv!
As a consequence the blacks are crushed between 0 to approximately 2.5%.
The 17-18 blanking bars are always invisibles after 3dlut creation.
I tried to decrease the gamma @1.25% with videoequalizer v2.06. It works very good (17-18 became visibles again) but it's not compatible with a 3dlut and I can't use this solution.
Do you think it could be possible to create a tool in madvr to modify the gamma curve in realtime after the 3dlut?
The goal is not to make a new gamma curve but only to correct the grayscale with our eyes at very low ire because the i1d3 can't.
A 100 points gamma editor would be really amazing for us. Something like videoequalizer but in madvr, after the 3dlut...
The idea is just to lower the gamma between 0 to 5%. It would be so cool...
I'm not sure if it's clear or if it's the good way to ask but...
Thanks Madshi
HC:Arcam AV888 + BSS-BLU 100-120 + 3x LabGruppen C series + 3x JBL 3678 + 4x Klipsch THX5000 (surrounds) + DIY subwoofer
DISPLAY:JVC RS3100 + Screenline 150"
HTPC: Bi Xeon + RTX3700 + LAV + Madvr
Francois76l is offline   Reply With Quote
Old 26th November 2015, 16:02   #34390  |  Link
QB
flash videos and madVR at the time results in a blue screen for me.
and yeah don't forget disco madVR before the PC crashed.
and AMD calls that "stable"...
Old 26th November 2015, 16:19   #34391  |  Link
adhara
I would add image doubling. super-xbr or low values of NNEDI3 luma doubling would improve the image further.
You could also add SuperRes from upscaling refinement to make the image sharper. SuperRes + enhance detail is another possibility.
Hi Warner306,
Thanks for the cookbook in your signature.
I tried to follow it with my 960GTX.
Display: 3840 x 2160p
Medium profiles
With 720p video, got lot of dropped frames with deinterlacing in auto mode. I have to deactivate it in order to get things ok.
How comes ?
regards.
adhara is offline   Reply With Quote
Old 26th November 2015, 19:17   #34392  |  Link
e-t172
By "i1d3" I assume you mean Eye-One Display Pro? If so, you're probably doing it wrong. I regularly measure very deep black levels with that color sensor with no issues. Even if there were issues, it would most likely result in noise near black, as opposed to the sensor reporting a "perfect" black like you're suggesting. Are you sure your sensor is not faulty? What software are you using for the measurements?
e-t172 is offline   Reply With Quote
Old 26th November 2015, 19:41   #34393  |  Link
Asmodian
Hello Madshi
As already mentioned, this is a problem that can be solved with the calibration software (Argyllcms?). Please move to the calibration thread or start a new thread for discussion as it is off topic for this madVR thread.
Old 26th November 2015, 22:21   #34394  |  Link
Warner306
Originally Posted by adhara View Post
Hi Warner306,
Medium profiles
How comes ?
regards.
It is the deinterlacing likely causing the issue. madVR uses some of the GPU's muscle to deinterlace. You would have to reduce your settings. Start with using Ordered Dithering and then reducing chroma upscaling to something like Lanczos3 + AR.
You can create separate profiles for deinterlaced content (srcInterlaced) using madVR profile rules, which what I would recommend. Then, you could turn down your settings when deinterlacing is encountered, and turn them back up when it is not.
Also, I realize you are likely using image quadrupling at 720p -> 2160p. You could simplify things by disabling image quadrupling and using image doubling + image upscaling instead. I think I would still go with the separate profile for deinterlaced content, but that would probably provide immediate relief to your graphics card.
The moral of the story is your settings are likely too aggressive for your card.
Old 26th November 2015, 23:02   #34395  |  Link
deinteralcing is taken the source framerate and is doubling it.
so madVR has to scale 50-60 frames a sec this is way and without it is 25-30 frames per sec. so double the power is needed to scale the deinterlaced stream.
deinterlacing it self is nearly free.
Old 26th November 2015, 23:21   #34396  |  Link
Warner306
Thanks for that. I didn't know that. I have only encountered one deinterlaced video in my own travels. But that is a much bigger deal.
So to the previous poster...You might have to completely abandon image doubling for these sources and use lesser settings. I thought a tweak here or there would bring the rendering queue down.
Also, you could use (deintFps > X) to create separate profile rules as opposed to (srcInterlaced), because huhn says it is the deinterlaced frame rate that is the problem once interlacing is complete, not the deinterlacing itself. The source frame rate and amount of scaling are two most important factors in determining the load placed on madVR.
As a starting point, these are my rules for a 1080p display:
if (deintFps <= 24) and (srcWidth > 1280) "1080p24"
else if (deintFps > 24) and (srcWidth > 1280) "1080p60"
else if (deintFps <= 24) and ((srcWidth > 960) and (srcWidth <= 1280)) "720p24"
else if (deintFps > 24) and ((srcWidth > 960) and (srcWidth <= 1280)) "720p60"
else if (srcWidth <= 960) "SD"
Or, using height:
if (deintFps <= 24) and (srcHeight > 720) "1080p24"
else if (deintFps > 24) and (srcHeight > 720) "1080p60"
else if (deintFps <= 24) and ((srcHeight > 540) and (srcHeight <= 720)) "720p24"
else if (deintFps > 24) and ((srcHeight > 540) and (srcHeight <= 720)) "720p60"
else if (srcWidth <= 960) or (srcHeight <= 540) "SD"
Old 27th November 2015, 00:19   #34397  |  Link
j5627429
I did have it set to always, like you suspected.
With your explanation, I finally understand how to set image doubling. It all makes sense now! And the OSD will show what is happening, as others have pointed out.
Thanks for everyone's assistance.
j5627429 is offline   Reply With Quote
Old 27th November 2015, 00:32   #34398  |  Link
Warner306
Can someone with better profile knowledge tell me how to write a profile where, if the width component is failed, madVR will check the source height before proceeding to the next profile?
Old 27th November 2015, 00:39   #34399  |  Link
if (srcWidth > number) "profile/action"
else if (srcHeight > number) "profile/action"
i don't use profiles but i can write code (or at least i was able to do that 10 years ago...) so not 100 % sure if the syntax is correct for the profile
Old 27th November 2015, 02:25   #34400  |  Link
lanzorg
Can someone with better profile knowledge tell me how to write a profile where, if the width component is failed, madVR with check the source height before proceeding to the next profile?
I can't test but it should work.
if (deintFps <= 24) and ((srcWidth > 1280) or (srcHeight > 720)) "1080p24"
else if (deintFps > 24) and ((srcWidth > 1280) or (srcHeight > 720)) "1080p60"
What about 25fps (mostly european) videos?
I think you should check with 30 fps instead of 24.
And you can use more generic profile names like sd (480p), hd (720p), fhd (1080p) and uhd (>1080p).
So something like these: uhd, uhd_hifps, fhd, fhd_hifps, hd, hd_hifps, sd, sd_hifps.
You can remove the underscore to suit madshi's naming preferences.
hifps = High FPS
lanzorg is offline   Reply With Quote
