Old 4th February 2011, 14:21   #41  |  Link
manolito
manolito's Avatar
Hi shon3i,
thanks for the new version.
I just made some extended tests to maybe detect a pattern which IFOs ChapterGen refuses to accept. But there does not seem to be a specific thing these IFOs have in common.
It happens for about 10% of my DVDs. It does not matter if I open the IFO from the DVD or from the hard drive. ChapterGen just does nothing. When I then try to use the Open Disc command I get an error message 'Runtime Error 55, File is already open', and ChapterGen closes itself. Restarting ChapterGen and using the Open Disc command again works. (For the Open disc command to work it is necessary that the IFO is located in a folder with the name VIDEO_TS)
ChapterXTractor has no problems with these IFOs.
Here is the link to one of the problematic IFOs:
http://www.sendspace.com/file/il4lz5
Hope this helps...
Cheers
manolito
Old 4th February 2011, 17:02   #42  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Thanks you both. Updated to 1.0.5.
shon3i is offline   Reply With Quote
Old 4th February 2011, 18:14   #43  |  Link
Subbat
Cool... It works well now...
PS : Thank you very much for this tool...
Subbat is offline   Reply With Quote
Old 4th February 2011, 18:58   #44  |  Link
manolito
manolito's Avatar
Yep, working fine now...
Thanks again
Cheers
manolito
Old 4th February 2011, 19:35   #45  |  Link
laserfan
Aging Video Hobbyist
With this version my .cmd file stops dead at a dialog I've never seen before, saying only CHAP and requiring a keystroke?
laserfan is offline   Reply With Quote
Old 4th February 2011, 19:43   #46  |  Link
Usedocne
lurkster
shon3i, you should maybe think about putting a link to this thread (ChapterGen) in your sig.
Also, thanks for making/sharing this.
Usedocne is offline   Reply With Quote
Old 4th February 2011, 20:11   #47  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
My bad , i forgot to remove all debug breaks :P
redownload again
@Usedocne, I will thank you for using program
ChapterGen - manipulate with chapters in various i/o formats, with CLI support
Official website or Doom9 thread
Old 14th February 2011, 08:16   #48  |  Link
Subbat
Hi shon3i,
Chaptergen doesn't work in cmd mode when the source video path contains a "-" character (even when the path is between quotes), it indicates a "Run-time error '52' => Bad file name or number", maybe it recognizes the "-" character as an option operator?
Thanks...
Old 14th February 2011, 09:54   #49  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Originally Posted by Subbat View Post
Hi shon3i,
Thanks...
Yep, i will see what i can do.
Thanks for report
Old 14th February 2011, 10:12   #50  |  Link
Subbat
Ok, Thanks a lot...
Old 14th February 2011, 20:50   #51  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Updated to 1.0.6
@Subbat should be fine now.
Old 14th February 2011, 21:07   #52  |  Link
Subbat
Thanks for report
Updated to 1.0.6
Hey... Cool... I will try it as soon as possible...
Old 14th February 2011, 22:37   #53  |  Link
Subbat
Cool, it's working nice now...
Thank you...
Old 15th February 2011, 09:57   #54  |  Link
Subbat
Hi shon3i,
Just to say that on your first post there's always note :
Current version 1.0.5
Download
Thanks again...
Old 18th February 2011, 18:36   #55  |  Link
laserfan
shon3i, my VideoReDo editor does not output chapters in tsMuxeR format HH:MM:SS.milliseconds as I need, but instead framenumbers. Any chance you could allow framenumbers as INPUT? Here's a sample of frame numbers from a 59.94 TV program, and the command I would like to use on it. Thanks for your consideration!
24854
35765
49430
54449
57308
65678
75212
84197
99474
137268
152460
168003
180657
185298
193434
216868
235267
238240
248278
270406
299038
332388
346824
393174
399870
402011
"C:\Program Files (x86)\ChapterGen\ChapterGen.exe" -i chapters.txt -o tsMuxeR.txt -f tsMuxer -infps 60/1.001 -outfps 60/1.001
Old 18th February 2011, 20:08   #56  |  Link
Video Dude
Senior Member
Frame number input would be useful.
I also use VideoReDo to edit HD tv captures and then author to Blu-ray with tsmuxer.
Video Dude is offline   Reply With Quote
Old 19th February 2011, 02:27   #57  |  Link
Capsbackup
I use VideoRedo, and I have the chapters format selection HH:MM:SS.ff, works for me for tsMuxeR! Seems to be pretty accurate too.
Capsbackup is offline   Reply With Quote
Old 19th February 2011, 17:03   #58  |  Link
laserfan
Yes, I noticed that too, but it's only "pretty accurate" as you said--my expectation about it is that while VRD's ff output is a frame number, tsMuxeR accepts it as .ms instead, so for example if the frame number is frame 22 e.g. VRD's output is
00:27:32.22
then tsMuxeR interprets this as .220 (220 milliseconds) whereas frame 22 for a 24/1.001 program would actually be at 918ms. So your chapter seek might land on a previous I-frame instead of the desired one.
Whether the miss is offensive or not of course depends on the program. But I'm very anal about this stuff so like to get it perfect, if possible...
Old 19th February 2011, 18:04   #59  |  Link
Capsbackup
My usage for VideoRedo is to cut commercials from recorded HD TV shows, so there is much more leniency for chapter marks at these commercial cuts. But I see and agree with your point!
Old 20th February 2011, 13:31   #60  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Ok i will see what i can do
