29th October 2012, 02:23 | #361 | Link |
Avisynth Developer
Sigh! the packed line detection code does not get applied to compressed formats, so AviSource() stumbles along with the default frame shape from env->NewVideoFrame(vi, -4); Looks like I got some more code to add.
29th October 2012, 03:58 | #363 | Link |
@Hajj_3, have already made that suggestion. EDIT: Like magic, now it is 2011
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 29th October 2012 at 14:32. |
6th November 2012, 19:55 | #364 | Link | |
Bug: AudioTrim not supported
Trying to use AudioTrim gives error message in VDub
my code was Code:
x = NicMPG123Source("The Beatles - One - 01 - Love Me Do.mp3").killvideo().eqaudio() x = AudioTrim(x, 0, 168) audiotrack = audiotrack + x |
6th November 2012, 22:05 | #365 | Link |
Huba Huba
I'm reading a lot about fixes in cvs, any chance of someone compiling a more recent version than the 2011 one please?
"The innocent have nothing to fear" :stupid: |
6th November 2012, 22:33 | #366 | Link |
I'm guessing that Mr B would be the best person to do that, time and updates/fixes would make alpha 4 a good idea.
5th December 2012, 14:42 | #367 | Link |
Is this a bug
colorbars() GScript(""" if(defined(LACED)) { convertToYUY2(interlaced=LACED) # BANG ! } else { convertToYUY2() } """) return Last EDIT: Emptied out my plugins (bar GScript) just in case an auto loaded script had a LACED, it did not.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 5th December 2012 at 14:48. |
5th December 2012, 14:50 | #368 | Link |
契約者
maybe it is time to release 2.6 final already? maybe it won't be as feature reach as we wanted it to be but there won't be sudden huge changes in the future anyway, isn't it? Also this will help to a lot of people who fail to understand that "alpha" doesn't necessarily means that it is broken and can make your computer explode. Because of this we for example have 2.5.8 ported to linux instead of 2.6...
5th December 2012, 15:09 | #369 | Link | |
Avisynth language lover
Did you expect something else? What exactly do you get? |
5th December 2012, 15:34 | #370 | Link |
Same here, I was expecting it to work, ie defined() to say if exists in script or not.
So presumably there is no way to tell if it says 'everything' is defined ? I wanted to use in this script so that if commented out (AUTOCROP_THRESH) it would call QueryBorderCrop() with an undefined arg to Thresh (as internally it reacts different if Thresh not supplied). http://forum.doom9.org/showthread.ph...80#post1604080
5th December 2012, 15:42 | #371 | Link | |
Defined() checks the status of values, not variables as such. As the wiki says, "More formally, the function returns false if its argument (normally a function argument or variable) has the void ('undefined') type, otherwise it returns true." If you want to check whether a variable exists, put its use inside a try/catch. |
5th December 2012, 15:47 | #372 | Link | |
EDIT: Perhaps a "Declared(String s)" function would be a good idea [or maybe "VarExist(String s) ]".
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 12th December 2012 at 01:39. |
11th December 2012, 18:48 | #373 | Link |
A non-imaginary bug this time.
RT_Debug(String(HexValue("FFFFFFFF"))) RT_Debug(String(HexValue("80000000"))) return colorbars() Produce this: Code:
RT_Debug: 2147483647 RT_Debug: 2147483647 Code:
AVSValue HexValue(AVSValue args, void*, IScriptEnvironment* env) { char *stopstring; return strtol(args[0].AsString(),&stopstring,16); } Code:
AVSValue Create_HexValue(AVSValue args, void*, IScriptEnvironment* env) { char *stopstring; return (int)(strtoul(args[0].AsString(),&stopstring,16)); } Code:
RT_Debug: -1 RT_Debug: -2147483648
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 12th December 2012 at 13:25. |
