18th December 2012, 18:04 | #1 | Link |
A bit confused with FFMPEG - I want something to play in my "Home Theater"...
Hi everyone. It's been quite a while since I've last been here, and even longer since I've done any serious video transcoding. I've changed my OS in the meantime (completely switched to Linux from Windows), and a few other things.
Now that I want to rip some DVDs (and similar) again, I feel a bit confused. Yes, I've read the documentations and googled extensively, and yet, I haven't found a solution to my problem which I could really trust. Here's the thing - my parents own an LG home theater, which happily plays MPEG4 files (in .avi container), i.e. the XviD, DivX and similar media. However, now that I'm on Linux, I'm surrounded by a few different commandline applications, as well as their GUIs, and it's quite a change from what I am used to (back on Windows, I used to rip DVDs with MeGUI, and through your forum acquired quite a bit of understanding about all this stuff, particularly about XivD and AVISynth). There's no such application on Linux, and besides, I personally prefer to use command line here. Thus, from what I understand, ffmpeg is the thing to use if I want to transcode media. I am looking for a solution to make standalone-compatibile video files (i.e. MPEG4+avi), with the video quality and size like I used to in MeGUI. Which usually means, full DVD resolution and framerate, and that everything looks quite nice if I put it on 2 CDs (1,4 GB or so - usually 1000-1500 kbps video). However, I can't get that with ffmpeg. I am using the "mpeg4" as vcodec, and the flags which were recommended in the official documentation - and at the same bitrate as XviD in MeGUI, this produces videos of much worse quality. The difference in video quality is blatantly obvious, in favour of XviD. The video which ffmpeg produces is terribly blocky, and if I set the constant quantizer of e.g. 2 the video quality is OK, but the resulting file is huge (usually not much smaller than a DVD - way over 3 GiB for a 2h film). So, what am I to do? Should I use libxvid as a video codec? Is there a source which can give me good info about using it? Should I just try to get all the flags which I have in MeGUI's "HQ Home Theater" profile? Or am I doing something wrong with ffmpeg+mpeg4? Is there any other viable solution (what is the actual state of mencoder, compared to ffmpeg)? Thanks in advance! (and sorry if I write too much) (edit: just realised I might be in the wrong subforum for this... if someone would be so kind and move it to the right forum, that would be grand! ) TL;DR - Linux - ffmpeg's mpeg4 video codec, or libxvid? How to get good video quality at a "reasonable" bitrate (1000-1500kbps)? Any good documentation and/or examples of using libxvid through ffmpeg? What about mencoder? TIA!
Only the best is good enough. Last edited by Wintershade; 18th December 2012 at 18:07. |
18th December 2012, 21:06 | #2 | Link | ||
Here are the settings I use (taken from WinFF profiles). They are for widescreen 16:9 content:
Good luck manolito |
18th December 2012, 21:16 | #3 | Link |
OK, so I'm supposed to use "-vcodec libxvid" over "-vcodec mpeg4" after all?
Thanks for the line, friend Will give it a go, and will post about the results.
Only the best is good enough. |
19th December 2012, 14:29 | #4 | Link |
-vcodec mpeg4 would use FFMPEG's own mpeg4 ASP encoder, which is a different implementation from xvid. You might be able to get better quality from it if you overcome the loads of cryptical options, but it is also slower than xvid AFAIK.
21st December 2012, 00:30 | #5 | Link |
Sorry for taking so much time for the feedback. real life kicks in on a daily basis
So I've tried the proposed settings for ffmpeg, and I still didn't get the quality/compression I was looking for. To clarify things a bit, I'm trying to encode a few videos at 720x400px resolution, at the bitrate of around 1200kbps for video. Now, I got much better results with mencoder (quality-vs-compression-wise), but I've used different options (mostly taken/translated from a MeGUI profile), as follows: Code:
[xvid-HQ-HT-pass1] profile-desc="XviD for Home Theater, HQ - pass 1" ovc=xvid=1 xvidencopts=pass=1:bitrate=1200:turbo=1:trellis=1:max_key_interval=250:max_bframes=1:threads=1:vhq=4:me_quality=6:chroma_me=1:chroma_opt=1: lumi_mask=1:min_iquant=2:max_iquant=10:min_pquant=3:max_pquant=20:min_bquant=3:max_bquant=20:bquant_ratio=162:bquant_offset=0: keyframe_boost=100:kfthreshold=1:kfreduction=20:overflow_control_strength=25:max_overflow_improvement=10:max_overflow_degradation=33: curve_compression_high=15:curve_compression_low=30:quant_type=h263 passlogfile=xvid-pass1.log nosound=1 [xvid-HQ-HT-pass2] profile-desc="XviD for Home Theater, HQ - pass 2" ovc=xvid=1 xvidencopts=pass=2:bitrate=1200:turbo=1:trellis=1:max_key_interval=250:max_bframes=1:threads=1:vhq=4:me_quality=6:chroma_me=1:chroma_opt=1: lumi_mask=1:min_iquant=2:max_iquant=10:min_pquant=3:max_pquant=20:min_bquant=3:max_bquant=20:bquant_ratio=162:bquant_offset=0: keyframe_boost=100:kfthreshold=1:kfreduction=20:overflow_control_strength=25:max_overflow_improvement=10:max_overflow_degradation=33: curve_compression_high=15:curve_compression_low=30:quant_type=h263 passlogfile=xvid-pass1.log oac=mp3lame=1 af=resample=44100 lameopts=aq=0:vbr=4:q=5 This has given me far better (i.e. enjoyable to my eyes) video at that bitrate and resolution. However, mencoder's encoding speed leaves something to be desired (I suppose). I have a (rather old, I know) Intel core2duo CPU @2GHz, and mencoder yields around 23-27 fps and around 15ish fps, for the 1st and 2nd pass, respectively. To compare, ffmpeg had the encoding speed of around 30-50 fps for both passes. Now, I understand that the options I've used in mencoder might have slowed it down quite a bit, and am content on using it as is, if this looks right. But I am now wondering - does it really look right? Should they have such impact on performance, or am I doing something wrong? I remember having about the same speed with my old computer on MeGUI, and it was an AMD AthlonXP (single core, 32bit, compared to this which is dual-core, 64bit, on a 64bit OS with 64bit mencoder and ffmpeg), so forgive me if it looks a tad bit suspicious to me. (just a quick reminder - I'm currently on Linux, and I admit that I'm not a Linux guru by any criteria) If this is all good and well, then my next question will be - can I use such settings in ffmpeg when calling libxvid? If I understand Linux correctly, this is exactly the same libxvid when invoked by either of the two apps, so it should (in theory) accept the same options and flags... but how to do it? Sadly, "ffmpeg -h long > ffmpeg.txt" has provided me with a plaintext file with no information on libxvid options whatsoever... Anyone have any ideas regarding that? As well as the cryptic mpeg4 options in ffmpeg (mentioned by @mandarinka)... I'd like to see them and play with them a bit as well. Thanks everyone, and again, thanks in advance! TL;DR - tried the settings; not completely happy with the outcome (720x400px video @1200 kbps); tried mencoder with settings stolen from a MeGUI profile - much happier with the results, but the speed is much lower - is that normal? how to use such settings in ffmpeg? any documentation regarding libxvid and mpeg4 codecs for ffmpeg? TIA
Only the best is good enough. Last edited by Wintershade; 21st December 2012 at 00:33. Reason: I've chopped down the xvidencopts lines in the codes, so the post is easier to read. Bear that in mind if you're c/p-ing them |
ffmpeg, libxvid, mencoder, mpeg4, xvid |
