Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 9th October 2008, 16:33   #1  |  Link
gerryino
Lightweight DVB-T VCR with linux
If i have a debian machine without X installed, is it possible to add a DVB-T card and make a lightweight VCR with some command line app and maybe cron?
I mean, do i need X server or i can just install the card driver and work with... (mencoder?)
I have a mini-ITX with Atom@1.6Ghz, i think i can drop the stream on the HD and maybe process it later.
gerryino is offline   Reply With Quote
Old 9th October 2008, 17:10   #2  |  Link
nm
I recommend installing VDR for DVB receiving. It works without X and is pretty lightweight with 10-30 MB resident memory usage, depending on installed plugins. Among other uses, VDR can serve as a plain recording backend, controlled through a web interface like VDRAdmin-AM or VDR LIVE. Debian's VDR packages are quite good, but configuration may be a bit awkward at first. There are some Debian-specific instructions at the VDR Wiki: http://www.linuxtv.org/vdrwiki/index...onfiguring_VDR
You could also write cron scripts and use command-line DVB tools to control the card, capture transport streams and disect them manually, but VDR already does all this and much, much more. To process VDR's MPEG-2 recordings, use Project X to demux or remux the streams and then re-encode if you wish (all this can be scripted too).
Old 15th October 2008, 19:40   #3  |  Link
gerryino
Didn't know about it, thanks a lot.
dvb-t, headless, linux, mencoder
