Old 28th April 2007, 18:04   #41  |  Link
plugh
A hollow voice says
The "12" I used in the extra cell was just a guess, based upon the perceived pattern in the array. My goal was to eliminate this as a cause of differing output, to see if there were other causes still present. I'm glad to have someone knowledgable build upon my discovery.
EDIT: I reviewed the changes syskin committed, and now better understand his post.
It isn't simply that the "12" I used should be "11", but that the debug check he added to mbcoding.c reveals that the "12" in some of the _existing_ cells is slightly too high an estimate for _some_ vectors... That perhaps the 'slick/fast' code in d_mv_bits isn't as accurate as it could be (I'll leave that one to the experts), but that the error should have little if any effect.
In any event, my "fix" (with the corrected value), is OK for the existing implimentation, as grabbing random garbage from outside the array definitely isn't right.
Many thanks, syskin...
(Updated 1.1.2 msvc build attached)
plugh is offline   Reply With Quote
Old 29th April 2007, 08:18   #42  |  Link
sysKin
sysKin's Avatar
Yes exactly. Think what would happen if the value there was negative O_O Such vector would be always chosen, regardless how bad it would be.
Nono, thank YOU!
Visit #xvid or #x264 at irc.freenode.net
sysKin is offline   Reply With Quote
