Old 3rd March 2009, 17:45   #21  |  Link
saint-francis
too much lurking
saint-francis's Avatar
Originally Posted by 0xdeadbeef View Post
Therefore, if you want to convert the frame rate, you have to select the source and target frame rates manually.
How is this done? I see no option to specify frame rate. Only resolution. I actually see nothing about frame rates at all in your tool.
Fantastic tool BTW. I'm loving it. Thanks for all of your hard work.
saint-francis is offline   Reply With Quote
Old 3rd March 2009, 17:53   #22  |  Link
0xdeadbeef
Author of BDSup2Sub
Changing the frame rate is not visible in the main view. However, when you select "Save" in the file menu, an export dialog pops up where you can set the checkbox for "Change frame rate". If this checkbox is active, the source and target frame rate can be edited and the time stamps will be changed accordingly during export.
0xdeadbeef is offline   Reply With Quote
Old 3rd March 2009, 18:32   #23  |  Link
saint-francis
too much lurking
Gotcha. Thanks.
Old 3rd March 2009, 23:57   #24  |  Link
turbojet
Hey thanks for the program it's definitely useful however I came across some subs that are misaligned that I reported here. If you could take a look at it be much appreciated.
Old 4th March 2009, 01:05   #25  |  Link
0xdeadbeef
Author of BDSup2Sub
How am I supposed to take a look if you didn't post a stream?
Besides, if two different tools which don't share a single line of code, show the same behavior, chances are that the stream is either buggy or uses an undocumented/unknown formatting feature.
Anyway, without a stream, nobody can tell for sure.
Old 4th March 2009, 03:25   #26  |  Link
~bT~
н∂-ƒαиαтι¢
how do i get the subs to show up in white rather than grey?
Old 4th March 2009, 05:57   #27  |  Link
turbojet
Here's one of the many streams, most sup's I've converted to 720p with BD-RB has shown the problem so I think it would be a pretty common issue. I just found BDSup2Sub earlier today so this is the first.
I think it is issues with the streams like you say, I've seen many strange displays with SupRip over the past year or so but they seemed to ocr ok so I didn't pay much attention to it. But these strange displays play fine in the retail somehow.
Old 4th March 2009, 12:29   #28  |  Link
0xdeadbeef
Author of BDSup2Sub
Can you name a frame that you think is misaligned in this SUP?
On the first look, the window (WDS) locations and sizes seem to be valid.
BTW: how was this created? It contains DTS info, so it was probably not created with EAC3TO...
Old 4th March 2009, 17:40   #29  |  Link
hubblec4
Matroska Dev-Helper
i converted some BD.sups and i finde a timestamp problem in the sub.idx
some subtitles are shown too long...
sample is here
load the sub/idx in SubtitleCreater an go to subtitle 135 and you will see what i mean.
Thats not a mistake of SC because during the playback in MPC the subtitle are shown too long.
hubble
hubblec4 is online now   Reply With Quote
Old 4th March 2009, 18:30   #30  |  Link
turbojet
5, 8, 11-26, 29-40, 42-56, 58, 63-71, 73,75, 77, 81-83, 86-90, 92, 93, 95-101 are all the 'shifted' entries in the first 100.
It was demuxed with tsmuxer I will try eac3to and see if that changes anything.
eac3to threw an error
s06 Writing the destination file failed.
Aborted at file position 2052063232.
Old 4th March 2009, 19:50   #31  |  Link
0xdeadbeef
Author of BDSup2Sub
@turbojet
Hm, looks like the windows are perfectly centered, but the image is quite a bit smaller than the window in this case (which it usually isn't). Since there is no window in the VobSub format, the image is displayed at the coordinates of the window and thus is shifted left. Problem is that I'm unsure how to handle this case (image smaller than window) in general. Maybe centering is an option, maybe there are flags in the stream that define what to do. I'll have a look.
@hubblec4
This is obviously a problem in the original stream (or created by the demuxer). If you go to frame 134 in BDSUP2Read, it shows an end time stamp "00:00:00:000". This is of course a bad thing to start with.
Since I wanted to add some time stamp inconsistency checking anyway, I might add some auto fix code as well.
Old 4th March 2009, 22:46   #32  |  Link
0xdeadbeef
Author of BDSup2Sub
Hope I didn't destroy more than I fixed this time. First post is updated again.
04.03.2009 1.2 -> 1.3
  • x/y ofs from start PCS is used instead of that from the window definition (fixes most misaligned subtitles)
  • Time stamp inconsistencies are reported and fixed
  • Swapped checkboxes in export dialog to emphasize the relation between the "Change frame rate" checkbox and the src/trg FPS
  • Added ini file to store frame size/position and load/save paths. Probably more to follow.
  • Added upscaling (indeed the scaling algorithm already supported it, only the factors were wrong)
  • Allowed all output formats for the moment. Dunno where this will take us, but it's worth a try.
  • Added layout panel that shows the location of the subtitle
  • Worked a bit on the user interface (less rescaling of components)
  • Removed warnings about empty palettes since this seems to be pretty common.
  • All editable fields of export dialog read out again before saving (indeed already done in 1.2)
Old 5th March 2009, 04:45   #33  |  Link
turbojet
Thanks!
1.3 got rid of the misaligned subs, at the least the ones I had remembered on 3 of 3 sup's so far. I'm considering it fixed and not going to try to remember those other ones that were misaligned. I'll let you know if I see it happen in the future.
One thing I notice in vista x64 is progress bar is very small screenshot
Old 5th March 2009, 06:22   #34  |  Link
hubblec4
Matroska Dev-Helper
Hello
Thanks for the new version.
A new problem i found.
sample
The subtitles are doubled and the first sub has no endtime in the timestamp. the problem i found on SupRead to. Only SupRip load and show the file correctly.
hubble
Old 5th March 2009, 18:32   #35  |  Link
0xdeadbeef
Author of BDSup2Sub
Well, again, this is more a problem of the stream.
The section sequence of a typical stream looks like this:
PCS(start)/WDS/PDS/ODS/END PCS(end)/WDS/END
In your stream it looks like this:
PCS(start)/WDS/PDS/ODS/END PCS(start)/WDS/PDS/ODS/END PCS(end)/WDS/END
So the whole start sequence including the the palette and RLE compressed bitmap is duplicated, yet with different start times (PTS). IMHO this doesn't make sense since it wastes lots of space. So this is most probably a authoring fault or a problem with the demuxer.
Then again, I think I can add a workaround.
Old 6th March 2009, 00:37   #36  |  Link
0xdeadbeef
Author of BDSup2Sub
Just a small update, mainly for the last two issues reported.
Hubble/turbojet, could you give it a try and report back?
06.03.2009 1.3 -> 1.4
  • Tinkered around with progress dialog to solve problems under Vista. Can't test it though.
  • Added frame/sequence number checks/warnings
  • Added automatic elimination of double subtitle start frames.
Old 6th March 2009, 04:25   #37  |  Link
turbojet
I think progress bar looks ok now in vista.
Thanks again
Old 6th March 2009, 10:40   #38  |  Link
hubblec4
Matroska Dev-Helper
Hubble could you give it a try and report back?
Well done. it works pretty good. No doubling anymore.
Thank you
Old 6th March 2009, 11:02   #39  |  Link
hubblec4
Matroska Dev-Helper
Another problem i have found. please look at my sample
After transcoding the time to show this subtitles is very short. Example. Subtitle 78
here is the original length from SupRip:
78
00:08:47,068 --> 00:08:50,820
-Ich heirate.
-Was? Hör auf, ich versteh ihn nicht.
but in the new file.sub/idx (open it in SC)
78
00:08:49,070 --> 00:08:50,822
-Ich heirate.
the endtime seems to be correct but the starttime is too late and nobody can read this subtitle in this short time.
hubble
Old 6th March 2009, 12:14   #40  |  Link
0xdeadbeef
Author of BDSup2Sub
Damnit, how many samples do you actually have ?
I will have a look this evening. However I assume that this is another case of stream inconsistency that SupRip detects and fixes. I just fear that each workaround added might create new problems. Also with all that stream bug fixing I somehow don't find the time to continue core development.
