13th November 2009, 22:04 | #401 | Link |
ffx264/ffhevc author
Have you already tried the two xbox presets available (mx and mxhq) ? They don't work? I don't see anything special in the above settings that'll make the already present xbox presets in the script incompatible. The only thing is that CABAC is disabled while I have it enabled in the xbox presets. Maybe xbox1 can't take CABAC?
13th November 2009, 23:15 | #402 | Link |
Those are xbox360 presets and to tell you the truth I tried them many revisions ago and many xbmc revisions ago and at the time it would stutter from time to time in high action scenes. But that was a while ago and I could try them again this weekend.
It seems the xbox1 can only handle CABAC if Deblocking is disabled and visa versa. With CABAC on and deblocking off the video is better quality but larger and with CABAC off and deblocking on the quality goes down slightly along with the file size. |
13th November 2009, 23:21 | #403 | Link |
hmm, CABAC is supposed to increase compression more than CAVLC so I'm a bit at a loss why you get smaller file sizes when you disable it. If I add such a preset, then I'll only disable CABAC but leave deblocking on. Can you try the xbox presets again on a short sample and see if you still get problems with them on the xbox1?
18th November 2009, 20:32 | #404 | Link |
I have a multi core cpu I was wondering if there is an option I need to be setting to make the encode multi-threaded? I got h264enc off the Karmic repository today (version 9.0.0) and am trying out a test encode but it is currently only using a single core. A quick search of this thread and the man pages hasn't revealed anything to me ... :-( Thanks in advance. ~Dan |
18th November 2009, 20:36 | #405 | Link |
First of all, I'd recommend getting MPlayer/MEncoder SVN, built against a recent libx264 version and then the latest h264enc version. Ubuntu provides oldish versions of these programs.
Multithreading should work with those versions too, but maybe froggy1 can guess what's going on. Last edited by nm; 18th November 2009 at 20:41. |
18th November 2009, 21:22 | #407 | Link |
Froggy1, nm,
Thanks for the really fast reply guys. I've got the latest x264 from git, but I'm currently unable to get the latest mplayer from svn, one of the dependencies (I'm using this guide on compiling mplayer-nogui, so maybe I'm building completely the wrong thing) has a broken deb. I've got a bug raised against it, so for now the only way I've been able to get h264enc working is to go with what is coming from rvm's ppa (https://launchpad.net/~rvm/+archive/testing). I'll try upgrading as soon as a fix is made available for the deb (or someone points out I'm being thick and get pointed to the right guide for compiling on Karmic ) |
18th November 2009, 21:41 | #408 | Link |
what is this broken dependency? Just go to mplayer's site, get SVN link, and pull from there. That's what I always to (though I have a script called getprog which accepts params about which software to pull from SVN, something small I've written to east it for me)
18th November 2009, 22:16 | #409 | Link | |
To quote Andrew from the Ubuntu forums:
However, as it turns out in researching these links to reply to you (and running the apt-get command again to try and get the error), the dependencies now actually install, which means my compilation should succeed! Huzzah. So, I'll grab the latest h264enc once I've got the latest mplayer. Will update this with my results. Thanks very much for your help. Thanks ~Dan |
18th November 2009, 22:23 | #410 | Link |
This is why I don't use Ubuntu! They got to have the most incompetent packagers out there :P
I'm a packager myself but luckily not for Ubuntu... So then... compile everything, first x264 then mplayer, and see if you get threading problems. Make sure to run h264enc -r to reset its config file |
18th November 2009, 23:06 | #411 | Link |
Gaah, it's still only running on a single core
I'm pretty sure that it's not an option I've selected (I've attached my options file just to make sure). I'm going to call it a day on this, but will look at it again tomorrow evening. I'm guessing the best way would be to call the encoder directly from the command line and see what is happening there. Is it mencoder called, or ffmpeg? Cheers, |
18th November 2009, 23:08 | #412 | Link |
better post attachments to an external site as it can take here some time before they get accepted by a mod
as for the threading. I don't have problems, neither other users who have reported that it works |
19th November 2009, 09:52 | #413 | Link | |
Im getting errors after updating h264enc, mencoder, mplayer and ffmpeg.
19th November 2009, 13:42 | #414 | Link |
@kripz
Look at the top, your libx264 is not new enough as it's missing weightp option. Pull latest x264 from git and compile it, then you may need to recompile mplayer and make sure it's linked to it, not to another older libx264 if you have one on your system |
19th November 2009, 22:56 | #416 | Link | ||
lol i totally missed that line
edit: those patches on your website are very outdated? edit2: Doesnt look right... Quote:
30th November 2009, 09:36 | #417 | Link |
For NAL-HRD, you need to use a preset which has vbv-bufsize and vbv-maxrate set. The blu-ray/avchd presets have these. Unless you really need HRD signaling, you shouldn't use it otherwise. Also, the HRD patches are still (very) experimental
For the audio issue, it's a known problem in the default demuxer for TS files. Configure as usual, save all to the batch file, open it up and add to the mencoder line -demuxer lavf then run your encode from the batchfile. See if this fixes it for you |
30th November 2009, 23:17 | #418 | Link |
Ok, ill try that next time.
I'm now having another problem with another movie, not sure what it is. I didnt save the mencoder options but here they are from within the job folder. Code:
nice -n 10 /usr/local/bin/mencoder "/storage/public/Random/BOURNE_SUPREM_G51/BDMV/STREAM/00009.m2ts" -o /dev/null -passlogfile "/home/user/.h264enc/job4653/The Bourne Supremacy.log" -vid 4113 -vf softskip,harddup -aid 4358 -channels 6 -oac copy -ovc x264 -x264encopts pass=1:bitrate=10000:turbo=2:me=tesa:me_range=64:nodct_decimate:nointerlaced:8x8dct:nofast_pskip:trellis=2:partitions=all:mixed_refs:keyint=240:keyint_min=24:psy_rd=0.8,0.2:frameref=10:bframes=7:b_adapt=2:b_pyramid=none:weight_b:weightp=2:direct_pred=auto:subq=10:mbtree:rc_lookahead=60:chroma_me:cabac:aq_mode=1:deblock:level_idc=41:threads=auto:ssim:psnr nice -n 10 /usr/local/bin/mencoder "/storage/public/Random/BOURNE_SUPREM_G51/BDMV/STREAM/00009.m2ts" -o "/storage/public/Random/The Bourne Supremacy.avi" -passlogfile "/home/user/.h264enc/job4653/The Bourne Supremacy.log" -vid 4113 -vf softskip,harddup -aid 4358 -channels 6 -oac copy -ovc x264 -x264encopts pass=2:bitrate=10000:me=tesa:me_range=64:nodct_decimate:nointerlaced:8x8dct:nofast_pskip:trellis=2:partitions=all:mixed_refs:keyint=240:keyint_min=24:psy_rd=0.8,0.2:frameref=10:bframes=7:b_adapt=2:b_pyramid=none:weight_b:weightp=2:direct_pred=auto:subq=10:mbtree:rc_lookahead=60:chroma_me:cabac:aq_mode=1:deblock:level_idc=41:threads=auto:ssim:psnr Code:
Starting the second pass of the encoding process in: 5 4 3 2 1 MEncoder SVN-r29934-4.3.2 (C) 2000-2009 MPlayer Team success: format: 0 data: 0x0 - 0xf7a51000 TS file format detected. VIDEO VC1(pid=4113) AUDIO A52(pid=4358) NO SUBS (yet)! PROGRAM N. 1 Searching for VC1 sequence header... found VIDEO: VC-1 1920x1080, 23.976 fps, header len: 30 [V] filefmt:29 fourcc:0x31435657 size:1920x1080 fps:23.976 ftime:=0.0417 ========================================================================== Opening audio decoder: [liba52] AC3 decoding with liba52 Using SSE optimized IMDCT transform Unimplemented resampler for mode 0xA -> 6 channels conversion - Contact MPlayer developers! Unimplemented resampler for mode 0xA -> 5 channels conversion - Contact MPlayer developers! Unimplemented resampler for mode 0xA -> 4 channels conversion - Contact MPlayer developers! Unimplemented resampler for mode 0xA -> 3 channels conversion - Contact MPlayer developers! Using MMX optimized resampler AUDIO: 48000 Hz, 2 ch, s16le, 192.0 kbit/12.50% (ratio: 24000->192000) Selected audio codec: [a52] afm: liba52 (AC3-liba52) ========================================================================== Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 0 Opening video filter: [harddup] Opening video filter: [softskip] ========================================================================== Requested video codec family [wmvvc1dmo] (vfm=dmo) not available. Enable it at compilation. Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family Selected video codec: [ffvc1] vfm: ffmpeg (FFmpeg WVC1) ========================================================================== audiocodec: framecopy (format=2000 chans=2 rate=48000 bits=16 B/s=24000 sample-1) Movie-Aspect is 1.78:1 - prescaling to correct movie aspect. x264 [warning]: NAL HRD parameters require VBV max bitrate and buffer size to be specified x264 [info]: using SAR=1/1 x264 [warning]: DPB size (10 frames, 31334400 bytes) > level limit (4 frames, 12582912 bytes) x264 [info]: using cpu capabilities: MMX2 SSE2Fast FastShuffle SSEMisalign LZCNT x264 [info]: profile High, level 4.1 Pos: 0.0s 1f ( 0%) 0.15fps Trem: 0min 0mb A-V:0.000 [0:0] 1 duplicate frame(s)! Writing header...3f ( 0%) 4.69fps Trem: 0min 0mb A-V:0.027 [0:0] ODML: vprp aspect is 16:9. Setting audio delay to 0.042s. Writing header... ODML: vprp aspect is 16:9. Setting audio delay to 0.042s. Pos: 112.2s 2722f ( 1%) 0.21fps Trem:13956min 6193mb A-V:0.036 [6746:192] Also, instead of defaulting the jobs to the home directory, can you please make it specifiable? my home directory isnt very big. Last edited by kripz; 30th November 2009 at 23:20. |
30th November 2009, 23:21 | #419 | Link |
did you compile x264 with asm? yasm enabled?
for the job directory, you can already do that in the config file. Look at the TEMPDIR variable in /home/username/.h264enc/config and set it there |
1st December 2009, 02:00 | #420 | Link |
Just came back from the pub
Looking again at your settings, no wonder you'll get such slow speeds (even on Quad cores). You got 10 frame references, 7 bframes with badapt=2, subq of 10, trellis of 2, me_range of 64, weigthp=2, mbtree on, me=tesa and lookahead of 60. This combined with a resolution of 1920x1080 will be pretty slow, even on quad cores and some of the settings are placebo-like (me=tesa f.ex). I bet you're using the insane high quality preset, huh? This preset is a "troll" preset, for those who think they'll see the difference between it and the EHQ preset, and of course for the Japs who love crazy settings My advice: do not go above the EHQ preset. I always use VHQ but only because my system is a bit slow. Nevertheless, it produces very nice results Last edited by microchip8; 1st December 2009 at 02:03. Reason: them typos, them typos |
h264enc, ipod, mencoder, ps3, xbox360 |
