4th April 2010, 14:58 | #11281 | Link | |
4th April 2010, 20:07 | #11282 | Link | |
5th April 2010, 09:37 | #11285 | Link |
I know. I'm only wondering, why the builtin post processing do so much blur on h-264 videos. On good videos I cannot see an effect of applying SPP deblocking to MPEG2 or MPEG4-ASP videos, no blurrying. I'd expect this behaviour for h.264, too.
6th April 2010, 09:49 | #11288 | Link |
Hi.
I just tested ffdshow_rev3345_20100402.exe build, CTRL+ALT+F4 or CTRL+ALT+numpad1 still doesnot working for me. Only me ?
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
6th April 2010, 11:21 | #11289 | Link | |
I do not see this issue with the following builds: - ffdshow_rev3304_20100304_sse_icl11 (ICL11, x86; xvidvideo.ru) - ffdshow_rev3305_20100304_clsid_icl10 (ICL10, x86; SourceForge) - ffdshow_rev3330_20100323 (generic, x86; xvidvideo.ru) - ffdshow_rev3330_20100323_sse_icl11 (ICL11, x86; xvidvideo.ru) - ffdshow_rev3334_20100325 (generic, x86; xvidvideo.ru) - ffdshow_rev3334_20100325_sse_icl11 (ICL11, x86; xvidvideo.ru) I see this issue with the following builds: - ffdshow_rev3336_20100327 (generic, x86; xvidvideo.ru) - ffdshow_rev3336_20100327_sse_icl11 (ICL11, x86; xvidvideo.ru) - ffdshow_rev3337_20100329 (generic, x86; xvidvideo.ru) - ffdshow_rev3337_20100329_sse_icl11 (ICL11, x86; xvidvideo.ru) - ffdshow_rev3342_20100331_clsid (generic, x86; SourceForge) - ffdshow_rev3345_20100402 (generic, x86; xvidvideo.ru) - ffdshow_rev3345_20100402_sse_icl11 (ICL11, x86; xvidvideo.ru) My CPU: QuadCore AMD Phenom II X4 945 (Deneb), 3000 MHz (15 x 200), RB-C2; x86, x86-64, MMX, 3DNow!, SSE, SSE2, SSE3, SSE4A Probably related to rev. 3335: "added H264 format to postprocessing filter" -- maybe I should have changed some option there? Last edited by LigH; 6th April 2010 at 12:11. |
6th April 2010, 12:56 | #11290 | Link |
I tested with PP disabled, so that would likely be the cause.
That change has been reverted in 3347, so your problem is probably fixed now.
MPC-HC 2.2.1 |
6th April 2010, 15:07 | #11291 | Link |
I have a DTS passthrough issue with ffdshow. I'm currently using ffdshow_rev3342_20100331_clsid and a Radeon HD4xxx's HDMI output (supports SPDIF, but no 7.1/HD-audio).
I previously used the ffdshow version of the CCCP which is totally outdated but there I had no problems. For the ffdshow settings see the attached screenshot. File 1: Code:
ID : 2 Format : DTS Format/Info : Digital Theater Systems Format-Profil : ES Codec-ID : A_DTS Dauer : 1h 40min Bitraten-Modus : konstant Bitrate : 755 Kbps Kanäle : 6 Kanäle Kanal-Positionen : Front: L C R, Surround: L R, LFE Samplingrate : 48,0 KHz Auflösung : 24 bits Stream-Größe : 544 MiB (27%) Titel : 5.1 DTS Code:
Audio ID : 3 Format : DTS Format/Info : Digital Theater Systems Format-Profil : MA Codec-ID : A_DTS Dauer : 45min Bitraten-Modus : variabel Kanäle : 6 Kanäle Kanal-Positionen : Front: L C R, Surround: L R, LFE Samplingrate : 48,0 KHz Auflösung : 16 bits I know it's DTS-MA but the core should still be a DTS bitstream right? PS: Enabling DTS HD bitstream doesn't make any difference. My AV Receiver is Onkyo TX-SR607. |
6th April 2010, 18:26 | #11292 | Link |
Media Control author
about bluray subtitles and subtitles in general, I am still working on it. Pel (supread creator) and I are working on making a better PGS format support The current implementation is not correct but I think I am close to the solution There is also the new ffmpeg libs on their way, the last issues to fix |
6th April 2010, 19:02 | #11293 | Link | ||
I am mainly thinking of this bug stated on the front page: Quote:
If it helps, vsfilter does not have this issue. |
6th April 2010, 20:42 | #11294 | Link |
4:2:0 hater
Albain, did you finally disable jitter correction for THD? With the lastest revisions I get huge jitter (30 segs or more) that is causing crashes, silence and audio desync with m2ts files here. No issues with matroska though, jitter is always at ~0. Can anybody confirm?
6th April 2010, 21:44 | #11295 | Link | |
"Do everything by hand, even when using the computer." - Hayao Miyazaki |
7th April 2010, 10:14 | #11297 | Link |
IFFDECODER_H outdated
Hi, I use ffdshow in delphi app, and every time you guys
change iffdecoder I had to update my prog. But you didn't update iffdecoder.h (nor delphi interface) in time. Please update interface units. Thanks |
7th April 2010, 18:07 | #11298 | Link | |
Just wanted to give you a heads up, but I tested with the newest Haali and I still get crashing while ff/rew with any mkv while using ffdshow dxva. I know you are aware (and very busy) but I wanted to let you know. Would love this to be fixed personally, as its the only thing from preventing me from using ffdshow dxva within Windows Media Center. Thanks |
7th April 2010, 18:22 | #11299 | Link | |
@All : I have fixed the last issues on new ffmpeg libraries (nv12 black screen). Now everything is working I'm doing some code cleanings but the modifications are ready to be committed. |
