5th March 2007, 09:03 | #1201 | Link | |
Assume both sources in this example are at 1080. And not to pile on, but I have yet to say it, so thanks SO MUCH for your work on this project. I've turned several friends onto it, as well, and they've been equally impressed. Last edited by Prospero424; 5th March 2007 at 09:09. |
5th March 2007, 10:06 | #1202 | Link |
HDConvertToX author
a bit of grain is always neccessary for a "not washed-out look" of movie.
Pourpose of filter is to gain a little bit compressibility and to remove excessive grain or noise/flickering/mosquito/ringing/halo.... the "best" filter could be the "not apply filters" or a heavy weight Spresso, or a sharpener Seesaw usually a removegrain(mode=2) is light enough to not destroy image but to clean a little noise around i can suggest to do several test with varius filter on a short sample. BHH P.S. thanks for introducing AutoMKV to other user !
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
5th March 2007, 10:33 | #1203 | Link | |
5th March 2007, 23:22 | #1204 | Link |
AutoMKV with or Without Decrypter
Hi folks,
I have this "Dumb" question ... Q1: What is the AutoMKV with Decrypter used for? If I am only interested in converting my DVD files (that are already on my hard drive) into AVI format ... then I guess the AutoMKV without Decrypter should work fine ... right!?!?! G! |
6th March 2007, 00:28 | #1205 | Link |
Using DVDFab Decrypter 3.0.8.6, I've ripped only the 16x9 movie from a disc that contains 16x9 and 4x3 versions, and other misc extras.
I pointed AutoMKV to the video_ts.ifo, chose wmv/wmv, 128 Kbps stereo audio, and "Set Width Resolution" to Auto. This caused 2 issues with the resultant movie: 1) It seems to be in 4x3 format. 2) The farther into the movie you get the more often the audio gets out of sync by 2-3 seconds. But then the audio does sync for a bit, then it gets out of sync by 2-3 seconds. Very intermittent. Any ideas? |
6th March 2007, 08:29 | #1206 | Link | ||||
HDConvertToX author
Now i am using dvdfabdecrypter because it's command line usable and can deal with some old arcoos protection Quote:
@Shark_jlc Quote:
you should rip only the pgc you want (or wait next version with pgc selection...) Quote:
one more: wmv encoding is done by wmencoder ... please try opening movie.avs with mpc/virtualdub and play it... is desyncronized ? BHH
6th March 2007, 14:28 | #1207 | Link | |
The audio de-sync happens when I play the movie on my xbox360, or my windows xp box (athlon XP @ 1.7 ghz) Where would I find the movie.avs file? In the temp folder I deleted ? Thanks. |
6th March 2007, 17:22 | #1208 | Link | |
HDConvertToX author
if it look "4:3" ... i don't know.. the wmv encoder don't set the aspect ratio... so if it look like 4:3 i can suppose that original file was a 4:3 film cropped and resized to 16:9 you can edit the <pixelratio> value to these DV NTSC fullscreen 10:11 DV NTSC widescreen 40:33 DV PAL fullscreen 12:11 DV PAL widescreen 16:11 if you know it (but you must reencode) and gain... yes... the movie.avs was in temp folder... don't delete it till encoded film isn't played ! BHH P.S. a will look to AR into wmv...
6th March 2007, 17:42 | #1210 | Link |
HDConvertToX author
attention Shark_jlc !
change the pixelratio NOT to "16:11" (for example) but to "16 11" without quotes and without : BHH EDIT: dowload this 2 sample from the name you will understand the parameter used (are pal= http://www.64k.it/andres/data/a/16_11movie.wmv and http://www.64k.it/andres/data/a/12_11_movie.wmv (~1mb each)
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 Last edited by buzzqw; 6th March 2007 at 17:46. |
6th March 2007, 20:02 | #1211 | Link |
This post will show my ignorance, I'm sure, but why do both movies show a width of 640 when you do a properties check on them?
It's obvious that one is widescreen and the other is not, would the widesreen not have a.... wider width? |
6th March 2007, 20:18 | #1212 | Link |
HDConvertToX author
one word : PAR (and two more AR and DAR)
would be long to explain but SeeMoreDigital have a lots of info on his site start here http://www.seemoredigital.net/03_Video_Info.html and then go to "Resolution" and "Anamorphics" i can suggest a long a intesive read. it is very well written andd ask to most "unquestionable" question BHH
7th March 2007, 11:23 | #1214 | Link |
I am having a problem encoding a certain episode. For some reason each time I try and encode during the second pass at 81% the xvid_encraw says it has to shut down.
Here is the log. Code:
01:11:09 0.76 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - - 01:11:09 Selected Input file: C:\DBZ\Episode 21\VTS_02_0.IFO 01:11:09 Selected Output dir: C:\DBZ\Episode 21\temp\ 01:11:09 Selected Final Name: VTS_02_0 01:11:09 Selected Container type: MKV 01:11:09 Selected Encoder: XviD 01:11:09 Selected Size: 265 01:11:09 Selected Slice: 1 01:11:09 Selected Profile: XviD_Extra_Slow.xml 01:11:09 Selected Width: Automatic 01:11:09 Selected Resizer: NONE 01:11:09 Selected Filters: MipSmooth(preset = "AnimeHQ") 01:11:09 Selected Deinterlacer: AUTO 01:11:09 Selected Field Order: AUTO 01:11:09 NeroAACEnc.exe: not present 01:11:09 Using Matrix: Sharktooth's EQM v3ULR.cqm 01:11:09 Track Language 1: All Audio Tracks 01:11:09 Audio Codec 1: Ogg Vorbis 01:11:09 Audio Quality 1: 4 01:11:09 Audio Channel 1: Stereo 01:11:09 Advanced Audio Settings DUMP Track 1 01:11:09 Nero Option Profiles: AUTO --- Encoding Mode: Quality 01:11:09 CCT Option Profiles: AUTO --- Channel Options: AUTO 01:11:09 Lame Settings: VBR 01:11:09 Audio Normalization: 1 01:11:09 Frequency: AUTO --- Tempo : NONE 01:11:09 Pitch: NONE --- Other Add : 01:11:09 Advanced Audio Settings DUMP Track 2 01:11:09 Nero Option Profiles: AUTO --- Encoding Mode: Quality 01:11:09 CCT Option Profiles: AUTO --- Channel Options: AUTO 01:11:09 Lame Settings: VBR 01:11:09 Audio Normalization: 1 01:11:09 Frequency: AUTO --- Tempo : NONE 01:11:09 Pitch: NONE --- Other Add : 01:11:09 Activate Anamorphic Encoding 01:11:09 01:12:24 Starting fixing all audio files 01:12:25 DelayCut CMD: C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\dgindex\Delaycut.exe -auto -out "C:\DBZ\Episode 21\temp\fixed1.ac3" "C:\DBZ\Episode 21\temp\movie T01 3_2ch 448Kbps DELAY -206ms.ac3" 01:12:38 DelayCut CMD: C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\dgindex\Delaycut.exe -auto -out "C:\DBZ\Episode 21\temp\fixed2.ac3" "C:\DBZ\Episode 21\temp\movie T02 2_0ch 192Kbps DELAY -206ms.ac3" 01:12:43 DelayCut CMD: C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\dgindex\Delaycut.exe -auto -out "C:\DBZ\Episode 21\temp\fixed3.ac3" "C:\DBZ\Episode 21\temp\movie T03 2_0ch 192Kbps DELAY -206ms.ac3" 01:12:50 Encoding C:\DBZ\Episode 21\temp\fixed1.ac3 to Ogg with 4 quality 01:16:10 Encoding C:\DBZ\Episode 21\temp\fixed2.ac3 to Ogg with 4 quality 01:18:01 Encoding C:\DBZ\Episode 21\temp\fixed3.ac3 to Ogg with 4 quality 01:20:02 ForceFilm Detected: 99.900002% FILM found 01:20:09 Number of Frames: 37290 01:20:09 Framerate: 29.970030 01:20:09 Movie lenght in Seconds: 1245 01:20:09 Movie Width: 720 01:20:09 Movie Height: 480 01:26:09 Processing completed. Type is determined to be film. 01:26:10 BFF: 27 01:26:10 TFF: 158 01:26:10 Order: tff 01:26:11 FIRST pass XviD: "C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\encoder\xvid_encraw.exe" -pass1 -progress -bitrate 1473 -turbo -threads 1 -max_bframes 2 -imax 16 -qpel -quality 6 -vhqmode 4 -pmax 16 -bmax 16 -framerate 23.976 -bquant_ratio 162 -chigh 30 -clow 15 -nopacked -nochromame -noclosed_gop -bvhq -qmatrix "C:\Documents and Settings\Owner\Desktop\AutoMKV076\profiles\XviD-profiles\matrix\Sharktooth's EQM v3ULR.cqm" -i "C:\DBZ\Episode 21\temp\movie.avs" -type 2 -mkv "C:\DBZ\Episode 21\temp\movie.mkv" 01:26:11 SECOND pass XviD: "C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\encoder\xvid_encraw.exe" -pass2 -progress -bitrate 1473 -threads 1 -max_bframes 2 -imax 16 -qpel -quality 6 -vhqmode 4 -pmax 16 -bmax 16 -framerate 23.976 -bquant_ratio 162 -chigh 30 -clow 15 -nopacked -nochromame -noclosed_gop -bvhq -qmatrix "C:\Documents and Settings\Owner\Desktop\AutoMKV076\profiles\XviD-profiles\matrix\Sharktooth's EQM v3ULR.cqm" -i "C:\DBZ\Episode 21\temp\movie.avs" -type 2 -mkv "C:\DBZ\Episode 21\temp\movie.mkv" 01:26:11 Starting First Pass 02:13:07 Starting Second Pass 03:38:59 Only Movie Size: 183357440 bytes 03:38:59 C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\matroska\mkvmerge.exe" -o "C:\DBZ\Episode 21\temp\VTS_02_0.mkv_pre" --track-name -1:"VTS_02_0" --aspect-ratio 0:1.777778 --chapters "C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\chapters.txt" "C:\DBZ\Episode 21\temp\movie.mkv" "C:\DBZ\Episode 21\temp\audio1.ogg" "C:\DBZ\Episode 21\temp\audio2.ogg" "C:\DBZ\Episode 21\temp\audio3.ogg" --title "Done with AutoMKV 0.76 http://forum.doom9.org/showthread.php?p=854221 " 03:39:00 Final Muxed size: -1 bytes 03:39:01 Encoding finished: 02:27:52 elapsed time 03:39:01 ----------------------------------------------------------------------- 03:39:01 Script AutoCrop.log 03:39:01 03:39:01 Crop(10,0,700,480) 03:39:01 ----------------------------------------------------------------------- 03:39:01 Script Resmovie.avs 03:39:01 03:39:01 ----------------------------------------------------------------------- 03:39:01 Script movie.avs 03:39:01 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\autocrop.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\BicublinResize.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\blockbuster.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\cnr2.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\ColorMatrix.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\Convolution3D.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\corrector.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\DctFilter.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\Decomb.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\Deen.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\degrainmedian.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\DGDecode.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\EEDI2.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\fft3dfilter.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\FluxSmooth.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\frfun7.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\hqdn3d.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\LeakKernelDeint.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\MaskTools.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\medianblur.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\MipSmooth.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\mt_masktools.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\mvtools.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\NicAudio.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\RemoveGrainS.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\RepairS.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\SangNom.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\SimpleResize.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\TBilateral.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\TDeint.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\TIVTC.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\TomsMoComp.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\TTempSmooth.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\UnDot.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\UnFilter.dll") 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\VSFilter.dll") 03:39:01 #loadpluginstart 03:39:01 03:39:01 #test1 03:39:01 03:39:01 Import("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\MCBob_v03c.avsi") 03:39:01 Import("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\mvbob.avsi") 03:39:01 Import("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\seesaw.avsi") 03:39:01 Import("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\spresso.avsi") 03:39:01 #importstart 03:39:01 03:39:01 #test2 03:39:01 03:39:01 movie = mpeg2source("C:\DBZ\Episode 21\temp\movie.d2v") 03:39:01 function getOrder(clip c) { 03:39:01 order = GetParity(c) ? 1 : 0 03:39:01 Return order } 03:39:01 #filter1start 03:39:01 03:39:01 #test3 03:39:01 03:39:01 #cropstart 03:39:01 03:39:01 cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=0,threshold=34,samplestartframe=0) 03:39:01 fixed_aspect = 1 03:39:01 c_width = width(cropclip) 03:39:01 c_height = Round(height(cropclip) / fixed_aspect) 03:39:01 input_par = float(float(c_width)/float(c_height)) 03:39:01 input_par = input_par > 1.4 ? input_par : (4.0/3.0) 03:39:01 out_width = 720 03:39:01 out_height = Round(float(out_width) / input_par) 03:39:01 hmod = out_height - (floor(out_height / 16 ) * 16) 03:39:01 out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) 03:39:01 new_aspect = (float(out_width) / float(out_height)) / fixed_aspect 03:39:01 autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=new_aspect,threshold=34,samplestartframe=0) 03:39:01 03:39:01 last = movie 03:39:01 tfm(d2v="C:\DBZ\Episode 21\temp\movie.d2v").tdecimate() 03:39:01 #resizestart 03:39:01 03:39:01 #test4 03:39:01 03:39:01 #filter2start 03:39:01 03:39:01 #test5 03:39:01 03:39:01 MipSmooth(preset = "AnimeHQ") 03:39:01 ColorMatrix("Rec.709->Rec.601",hints=false,threads=0) 03:39:01 ----------------------------------------------------------------------- 03:39:01 Script mkvmaudio.avs 03:39:01 03:39:01 LoadPlugin("C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\filter\NicAudio.dll") 03:39:01 NicAC3Source("C:\DBZ\Episode 21\temp\fixed3.ac3") 03:39:01 EnsureVBRMP3Sync() 03:39:01 ConvertAudioTo16bit() 03:39:01 #Applyed STEREO downmixing routines 03:39:01 function stereo(clip a) 03:39:01 { 03:39:01 fl = GetChannel(a, 1) 03:39:01 fr = GetChannel(a, 2) 03:39:01 c = GetChannel(a, 3) 03:39:01 lfe = GetChannel(a, 4) 03:39:01 sl = GetChannel(a, 5) 03:39:01 sr = GetChannel(a, 6) 03:39:01 l_sl = MixAudio(fl, sl, 0.2929, 0.2929) 03:39:01 c_lfe = MixAudio(lfe, c, 0.2071, 0.2071) 03:39:01 r_sr = MixAudio(fr, sr, 0.2929, 0.2929) 03:39:01 l = MixAudio(l_sl, c_lfe, 1.0, 1.0) 03:39:01 r = MixAudio(r_sr, c_lfe, 1.0, 1.0) 03:39:01 Return MergeChannels(l, r).Normalize() 03:39:01 } 03:39:01 # 03:39:01 function original(clip a) 03:39:01 { 03:39:01 Normalize(a) 03:39:01 Return last 03:39:01 } 03:39:01 6==Audiochannels() ? stereo() : original() 03:39:01 ----------------------------------------------------------------------- 03:39:01 Script mkvmaudio.bat 03:39:01 03:39:01 "C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\besweet\bepipe.exe" --script "Import(^C:\DBZ\Episode 21\temp\mkvmaudio.avs^)" | "C:\Documents and Settings\Owner\Desktop\AutoMKV076\exe\besweet\oggenc2.exe" -q 4 - -o "C:\DBZ\Episode 21\temp\audio3.ogg" 03:39:01 ----------------------------------------------------------------------- 03:39:01 Script mkvmaudio2.avs 03:39:01 03:39:01 ----------------------------------------------------------------------- 03:39:01 Script mkvmaudio2.bat 03:39:01 03:39:01 03:39:01 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - - - - - - |
7th March 2007, 13:15 | #1215 | Link | |
HDConvertToX author
please try to open the movie.avs with mediaplayer classic or virtualdub and advanced till 81% of movie... got any error ? another try could be changing the xvid profile or better try with x264 BHH
8th March 2007, 14:09 | #1217 | Link |
HDConvertToX author
@Shark_jlc
try reducing resolution, open movie.avs look at out_width = XXX, set it to 320 and play... is in synch ? if not may be a problem of ripping... (try with ripit4me) @ALL As you now Sh0dan has build an awesome plugin for avisynth ( http://forum.doom9.org/showthread.php?t=120025 ) "SoundOut" With this plugin is possible to eliminate BePipe usage , and so .Net Framework what is cons and pro ? PRO: no .NET needed, no LAME.exe, mp3 encoding would be more robust since will be limited to official preset ( 32 40 48 56 64 80 96 112 128 160 192 224 256 320) Other audio encoding NERO/OGG would be the same CONS: AAC CCT (winamp) wouldn't be able to encode to 5.1 Channels , AAC CCT would be limited only to 2 ch (mono,stereo,dpl,dpl II), for MP3 only ABR and CBR mode avaiable (no more pure quality preset) Maybe a little slower (60 seconds for every hours of audio encoded, on my p4 3.0 lame goes to near x8 realtime) i have already done all modify to automkv, but, as always i have backupped all source please tell me your preference BHH
8th March 2007, 14:39 | #1218 | Link |
Changing the out_width doesn't seem to make a difference in the playback of the file for me. I'll rip with ripit4me and re-encode tonight.
In regards to the new plugin, the trade off is that AutoMKV loses some dependencies, but also loses some functionality. *shrug* I have no preference :/ |
8th March 2007, 19:36 | #1220 | Link |
HDConvertToX author
@Shark_jlc
have you select NONE to resizer ? if so delete from movie.avs last=movie @sunflash10 thanks for you answer about cct i think too could be ok even if limited to 2ch. Nero aac deliver an optimal quality and is freeware for personal use. Even more encoding 5.1 with nero is painless while with cct i must check every switch to make compliant... i would like to include neroaacenc with automkv software but actually there is some license problem... i have better hope for future BHH
