Go Back   Doom9's Forum > Hardware & Software > Hardware players
Old 11th August 2013, 16:07   #1  |  Link
kotuwa
Media Compatibility - PSP, PS3, Xbox etc. Re-Frames, Level, Resolution
How about media (mostly Video) Compatibility of Portable Devices such as PSP, PS3, Xbox. ?
What are the things that directly and mostly affect the compatibility?..
Among below 3,
  1. Max. Reference Frames
  2. Max Resolution
  3. AVC Level
Especially I want to know about Reference Frame Limit!
As I know PSP Support AVC Level Main @ 3.0.
PS3 and Xbox support AVC Level High @ 4.0.
Regarding ReFrames, All support ReFrames Upto 3.
But can we use more than 3 re-frames, with any setting?..
how?
With regarding device playback, does max re-frames supported depends on avc level or resolution?
kotuwa is offline   Reply With Quote
Old 11th August 2013, 16:28   #2  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
Get yourself a well known program that has solved this problem already (such as FFCoder, Handbrake, MeGui, Ripbot264, WinFF, ...) and study their profiles. They have been polished over time with user feedback and a lot of hard work.
raffriff42 is offline   Reply With Quote
Old 17th August 2013, 12:43   #3  |  Link
kotuwa
thanks...
i posted this after looking at their profiles.... i mean not all of them, but MeGUI, RipBot, Handbrake and StaxRip.
what i need to do is after selecting a profile, do some changes to gain more quality!
doing so, sometimes they indicate that it is no longer compatible... (ex: changing tha AVC level)
but sometimes, they does not.... ex: if I change max ReFrames to 16, they still show that it is compatible..... but I know that 16 re-frames does not work with them....
what I want to know is in between value, such as from 4 to 10...... do they work?
also need to know that about HE SBR and HEv2 SBR+PS AAC support, Multi-Channel Audio support and SRT support!... those encoders are less informative about them!
the problem im facing is I don't have those devices, if I had I can test, but i need to encode for them!
compatibility, mp4, ps3, psp, xbox
