19th September 2008, 13:53 | #6261 | Link | |
P.S: Oh, 6.1 channels! My fault. There's just something missing. Will add that to the next eac3to build... P.P.S: Blu-Ray does not support 6.1 LPCM. Instead it only supports 7.1 LPCM, as far as I know. So should I enforce channel doubling when exporting to PCM? Last edited by madshi; 19th September 2008 at 14:23. |
19th September 2008, 18:28 | #6262 | Link | |
Location: The Great North (the better half of North America)
When you say >4GB... tsMuxeR doesn't work. Do you mean it won't accept the .wav file at all, or there will be playback problems after muxing? |
19th September 2008, 19:19 | #6264 | Link | |
tsMuxer, like other soft, accept the wav but don't play/use the full length. |
19th September 2008, 21:49 | #6265 | Link |
Converting TrueHD, DTS-MA and DD+ to PCM. Is one library better and more exact then the next? I don't have nero or total media installed and just planned on using the default library.
I want the most accurate conversion available what should I use? |
19th September 2008, 22:36 | #6266 | Link | |
I mean there is no option B in default library. Last edited by rica; 19th September 2008 at 22:48. |
19th September 2008, 22:59 | #6268 | Link | |
The best decoders are unfortunatlely the commercial ones like nero or TMT which are selected by Madshi as default. If eac3to can not find those defaults, that time it will use the default ones coming with the library. For any particular format, you don't have two options since library gives only one default decoder for any particular format. Last edited by rica; 20th September 2008 at 00:07. |
19th September 2008, 23:12 | #6272 | Link | ||
And, you don't have to purchase anything; it is up to you. (trust your own ears first; it is a rule.) _ _ _ _ _ Last edited by rica; 20th September 2008 at 10:56. |
20th September 2008, 12:07 | #6273 | Link | ||
sample: http://www.sendspace.com/file/gvx7sn Quote:
http://www.sendspace.com/file/kifr28 |
20th September 2008, 14:45 | #6274 | Link | ||
(1) eac3to must properly detect the channel configuration. The track could be 2/2 or 3/1. The next eac3to version will detect that correctly for m2ts sources. (2) FLAC used to not support funny channel masks. But I've seen that there's a way now to store a WAV channel mask as FLAC meta information. So storing 3/1 in FLAC should be possible now. But eac3to will have to read/write that channel mask meta information. I've put that on my to do list, but it might take a while until I find the time to implement that. (3) The FLAC decoder (e.g. madFlac) must be able to read and interpret the channel mask meta information. madFlac doesn't do that yet. Quote:
20th September 2008, 15:28 | #6275 | Link |
does eac3to allow joining independent mono wav/raw files into a single multi-channel file ? because it seems there are no wave editors that are capable of reading a single 7.1 channel wav larger than 4 GB, while some maybe able to allow the one (larger than 4 GB) but that same program does not allow the other (7.1 channel) and the other way around, there may be one or two programs that do support reading such a file fully (both 4 GB size AND 7.1 channels), but they have other drawbacks (only open first 30 minutes (nero) and others open the multi-channel file and open all the channels as mono separated channels, without support for joining them into a single .wav file (cooledit))
20th September 2008, 16:49 | #6276 | Link |
sidekick
I got a problem with converting vc1 tracks from hddvd (Full Metal Jacket) and Blu-Ray (The Prestige)
(this time the files are ripped properly ) Code:
eac3to v2.63 command line: eac3to feature_01.evo+feature_02.evo fullmetal.mkv ------------------------------------------------------------------------------ EVO, 1 video track, 6 audio tracks, 10 subtitle tracks, 1:56:30 1: Joined EVO file 2: VC-1, 1080p24 /1.001 (16:9) with pulldown flags 3: E-AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB 4: TrueHD, 5.1 channels, 48khz, dialnorm: -27dB 5: E-AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB 6: E-AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB 7: E-AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB 8: E-AC3, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, -9ms 9: Subtitle 10: Subtitle 11: Subtitle 12: Subtitle 13: Subtitle 14: Subtitle 15: Subtitle 16: Subtitle 17: Subtitle 18: Subtitle [v02] Extracting video track number 2... [v02] Removing VC-1 pulldown... [v02] Muxing video to Matroska... [a03] Extracting audio track number 3... [a04] Extracting audio track number 4... [a06] Extracting audio track number 6... [a07] Extracting audio track number 7... [a08] Extracting audio track number 8... [a05] Extracting audio track number 5... [a04] Removing TrueHD dialog normalization... [a04] Decoding with libav/ffmpeg... [a04] Encoding FLAC with libFlac... [a05] Removing E-AC3 dialog normalization... [a07] Removing E-AC3 dialog normalization... [a03] Removing E-AC3 dialog normalization... [a06] Removing E-AC3 dialog normalization... [a08] Removing E-AC3 dialog normalization... [a04] Creating file "fullmetal - 4 - TrueHD, 5.1 channels, 48khz.24bit.flac"... [a05] Creating file "fullmetal - 5 - E-AC3, 5.1 channels, 640kbps, 48khz.eac3"... [s15] Extracting subtitle track number 15... [s18] Extracting subtitle track number 18... [a03] Creating file "fullmetal - 3 - E-AC3, 5.1 channels, 448kbps, 48khz.eac3"... [a06] Creating file "fullmetal - 6 - E-AC3, 5.1 channels, 448kbps, 48khz.eac3"... [a07] Creating file "fullmetal - 7 - E-AC3, 5.1 channels, 448kbps, 48khz.eac3"... [s12] Extracting subtitle track number 12... [s11] Extracting subtitle track number 11... [s17] Extracting subtitle track number 17... [s16] Extracting subtitle track number 16... [a08] Creating file "fullmetal - 8 - E-AC3, 2.0 channels, 192kbps, 48khz.eac3"... [s14] Extracting subtitle track number 14... [s13] Extracting subtitle track number 13... [s10] Extracting subtitle track number 10... [s09] Extracting subtitle track number 9... [s12] Creating file "fullmetal - 12 - Subtitle.sup"... [s10] Creating file "fullmetal - 10 - Subtitle.sup"... [s18] Creating file "fullmetal - 18 - Subtitle.sup"... [s09] Creating file "fullmetal - 9 - Subtitle.sup"... [s11] Creating file "fullmetal - 11 - Subtitle.sup"... [s17] Creating file "fullmetal - 17 - Subtitle.sup"... [s16] Creating file "fullmetal - 16 - Subtitle.sup"... [s15] Creating file "fullmetal - 15 - Subtitle.sup"... [s14] Creating file "fullmetal - 14 - Subtitle.sup"... [s13] Creating file "fullmetal - 13 - Subtitle.sup"... [a04] This audio track has a constant bit depth of 16 bits. [a04] The zero bytes were successfully removed. Added fps value to MKV header. Video track 2 contains 167613 frames. eac3to processing took 1 hour, 58 minutes. Done. I'm trying now vc1conv again, but this will take time...
greets, kurt. Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC Last edited by kurt; 20th September 2008 at 16:54. |
20th September 2008, 17:19 | #6278 | Link | |
Try to extract vc1 and audio with eac3to and remux with TSMuxer. If you still want an mkv, try mkvmergegui using remuxed file. |
20th September 2008, 17:28 | #6279 | Link | ||
sidekick
trying now mkvextract... takes a while.... Edit: mkvextract produces an avi, which I don't expect that tsmuxer would load it....
greets, kurt. Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC Last edited by kurt; 20th September 2008 at 17:31. |
20th September 2008, 17:34 | #6280 | Link |
You must be making something wrong.
Extract vc1 directly from your evo; this is the best way. (BTW i have lived no any issue extracting vc1 from the mkvs created by eac3to) Edit: Take a look as well: http://forum.doom9.org/showthread.ph...91#post1173291 http://forum.doom9.org/showthread.ph...70#post1173370 _ _ _ _ _ Last edited by rica; 20th September 2008 at 17:51. |
eac3to |
