Old 17th February 2009, 00:33   #8301  |  Link
Snowknight26
Couple things: time to upgrade to 3.11, -1536 is understood, and add -resampleTo48000.
Snowknight26 is offline
Old 17th February 2009, 01:09   #8302  |  Link
jj666
Originally Posted by Mixpower View Post
Given the directory structure, that's a Rule #6 and shouldn't be discussed here.
-jj-
jj666 is offline
Old 17th February 2009, 01:30   #8303  |  Link
Mixpower
-jj-
Why ?
Because the ripped blu-ray disk is in my downloads dir ?
Mixpower is offline
Old 17th February 2009, 01:38   #8304  |  Link
jj666
It's just some friendly advice, as the rules clearly state we don't discuss downloaded content. Once that is out of the way, it's a very friendly forum :-)
Cheers,
-jj-
jj666 is offline
Old 17th February 2009, 01:50   #8305  |  Link
rica
Dear mods.
Don't you think it is time to make this thread sticky?
Please check out replies and views in this thread and compare with the ex-threads which are already sticky.
Sorry in advance if i went too far.
_ _ _ _ _ _ ___
rica is offline
Old 17th February 2009, 02:55   #8306  |  Link
DrNein
I don't really know. I installed full Nero 7, registered proper (actually bought by me) license codes for Nero 7 and for the Blu-Ray/HD DVD plugin, and Nero 7 decoding works just fine for me, without having to manually register any filters.
Yeah, I was trying to be clever with a minimal install (Micro + any additional dll/ax restored). For now I have installed ShowTime (along with Burning ROM which I do want) and it "works fine". Of course there are superfluous filters and all that Nero Home & Indexing nonsense too which while offensive on priniciple I would not be obsessive about taking space (once disabled) except that I want to limit the backup image size to one DVD-5. I suppose I can instead just start eliminating unneeded files (move or archive) until something breaks
Thanks again for your help and great proggy.
DrNein is offline
Old 17th February 2009, 08:07   #8307  |  Link
mrr19121970
Apparently the language on HD-DVD is no longer coming through with v3.11
http://forum.slysoft.com/showpost.ph...&postcount=246
eac3to v3.11
command line: "C:\Program Files\eac3to\eac3to.exe" "E:\" 2) 2: "C:\temp\Evan Almighty\Chapters_2.txt" 3: "C:\temp\Evan Almighty\Video_3.*" 5: "C:\temp\Evan Almighty\Audio_5_Undetermined.AC3" -LOG="C:\temp\Evan Almighty\eac3to_PASS3_LOG.LOG"
EVO, 2 video tracks, 4 audio tracks, 2 subtitle tracks, 1:35:41
1: Joined EVO file
2: Chapters, 20 chapters with names
3: VC-1, 1080p24 /1.001 (16:9) with pulldown flags
4: VC-1, 480p30 /1.001 (3:2)
5: E-AC3, 5.1 channels, 1536kbps, 48khz, dialnorm: -27dB
6: E-AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB
7: AC3 Surround, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, -8ms
8: E-AC3, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, -27ms
9: Subtitle (DVD)
10: Subtitle (DVD)
Creating file "C:\temp\Evan Almighty\Chapters_2.txt"...
Disabling DRC for Nero (E-)AC3 decoding...
[v03] Extracting video track number 3...
[a05] Extracting audio track number 5...
[v03] Writing new framerate "24fps /1.001" to bitstream.
[a05] Removing E-AC3 dialog normalization...
[a05] Decoding with DirectShow (Nero Audio Decoder 2)...
[v03] Removing VC-1 pulldown...
[a05] DirectShow reports 5.1 channels, 24 bits, 48khz
[a05] Encoding AC3 <640kbps> with libAften...
[v03] Creating file "C:\temp\Evan Almighty\Video_3.vc1"...
[a05] Creating file "C:\temp\Evan Almighty\Audio_5_Undetermined.AC3"...
Video track 3 contains 137641 frames.
Video track 4 contains 162247 frames.
eac3to processing took 14 minutes, 4 seconds.
Done.
mrr19121970 is offline
Old 17th February 2009, 08:31   #8308  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
you should read previous posts instead of posting this...
Kurtnoise is offline
Old 17th February 2009, 09:04   #8309  |  Link
Snowknight26
Is eac3to success.wav and eac3to error.wav supposed to fail detecting the file type?
Old 17th February 2009, 17:01   #8310  |  Link
dorati
@madshi:
Is it possible to generate the Filename of the Streamnumber with 2 Digits?? (00001 - 02 - VC-1, 1080p24.vc1 instead of 00001 - 2 - VC-1, 1080p24.vc1) to have the right order under windows?
Is it possible to skip the last Chapter, when the Last Chapter is = Movie-Length?
And is it possible to have one option to create the Chapters.txt in a format to direkt use in TsMuxer? ... Like this:
00:02:02.039
00:05:26.493
00:07:58.144
00:12:35.380
00:17:50.695
00:21:31.916
00:25:37.494
00:29:09.873
00:32:23.400
00:34:54.759
00:37:54.314
00:40:44.150
00:45:51.540
00:52:04.663
00:56:51.199
00:59:41.787
01:05:12.617
01:08:16.217
01:12:34.559
01:17:09.792
01:20:39.084
01:24:14.925
01:27:08.390
thx for this Great Tool !!!!
dorati is offline
Old 17th February 2009, 17:39   #8311  |  Link
laserfan
Aging Video Hobbyist
Originally Posted by dorati View Post
@madshi:
00:02:02.039
Actually txMuxeR needs semicolon-delimited timecodes. You should check-out QPFile Generator discussed here which creates --custom-chapters list as well as qpfile.txt, celltimes, etc.
laserfan is offline
Old 17th February 2009, 18:28   #8312  |  Link
dorati
But when paste into the window, the format I use above is right !
dorati is offline
Old 17th February 2009, 19:06   #8313  |  Link
laserfan
Ah, without looking at your (pending) attachment let me guess--you are using the tsMuxeR GUI. Still, qpfile gen also outputs a timecodes file just like you want.
laserfan is offline
Old 17th February 2009, 20:02   #8314  |  Link
mrr19121970
you could use the GUI Clown_BD, it does what you're asking Madshi to do for you...
http://forum.slysoft.com/showthread.php?t=25818
Old 18th February 2009, 17:03   #8315  |  Link
nwg
That is very good software. I prefer using it to the TsMuxer GUI as it also reduces the number of steps when converting audio.
nwg is offline
Old 18th February 2009, 23:59   #8316  |  Link
chairlgmc
chairlgmc
DTS 24/96 from DTS HD
Hello,
having been a silent watcher for several weeks now and still on a steep learning curve and having read posts hither and yon I need someone to confirm the following for me before I commit myself to command line hell.
I want to either extract the dts Core of a dts HD track and presumably get 24 bit/48khz (or 96khz on the rare occasions they exist) 5.1 soundtrack or convert DTS HD into DTS 24/96. The reason for this is that I want to continue to use my much loved AV32R processor whch will handle DTS 24/96 via spdif but has no hdmi input to transfer DTSHD. this is because it A sounds fantastic an B has very good room equalisation software that is not available via the 5.1 bypass.
Goals -
1 - have 24bit/48khz 5.1 dts output via spdif. (presume yes if core is encoded as such)
2 - have the above tagged as DTS 24/96 if necessary to kick the AV32 into life.(what i am unsure of)
3 - Core is ok if it will achieve 2 above. So far my tag has not lit up to say 24/96 - just vanilla DTS
6.1 and 7.1 not needed.
I know i can extract the core from a DTSHD BluRay - the confirmation i cannot find is whether it will identify as DTS 24/96 via spdif.
Will playback via MPC HC/ffdshow and auzentech digital out.
AV32R will decode a 24/96 stereo flac file (presumably output as linear pcm) no problem. Is fine with dts es too. spdif cant handle DTSHD but i am given to understand elsewhere that it can cope with 24/96.
Sorry to be a quality junkie and somewhat exacting.
Am loving my decoded HDCD's. Thank You.
Anthony
chairlgmc is offline
Old 19th February 2009, 03:16   #8317  |  Link
TinTime
The core can be 96/24, but only if the full track is DTS-MA with a sample rate of at least 96Khz. I haven't seen any yet.
So extracting the core with eac3to (assuming it gets the 96/24 stream and not the plain core?) is your best bet for DTS if you want it passed over spdif.
Do you know for sure that you have a blu-ray with DTS 96/24 in it's audio?
Last edited by TinTime; 19th February 2009 at 03:55. Reason: Was talking rubbish prior to edit...
TinTime is offline
Old 19th February 2009, 13:23   #8318  |  Link
GZZ
is this a problem ?
I get the following warning in eac3to, not sure what it means and if I should be concerned about it:
The error happen on the Nordic version of Troy.
eac3to v3.11
command line: eac3to "H:\" 1) 1:"d:\Encoding\Troy\Chapters.txt" 2:"d:\Encoding\Troy\Video.mkv" 4:"d:\Encoding\Troy\Audio.dts" -768 17:"d:\Encoding\Troy\SubDK.sup" 18:"d:\Encoding\Troy\SubFI.sup" 19:"d:\Encoding\Troy\SubNO.sup" 21:"d:\Encoding\Troy\SubSWE.sup"
M2TS, 1 video track, 6 audio tracks, 17 subtitle tracks, 3:16:03, 24p /1.001
1: Chapters, 46 chapters
2: VC-1, 1080p24 /1.001 (16:9)
3: AC3, English, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB
4: TrueHD/AC3, English, 5.1 channels, 48khz, dialnorm: -27dB
(embedded: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB)
5: AC3, French, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB
6: AC3, German, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB
7: AC3, Italian, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB
8: AC3, Spanish, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB
9: Subtitle (PGS), English
10: Subtitle (PGS), French
11: Subtitle (PGS), German
12: Subtitle (PGS), German
13: Subtitle (PGS), Italian
14: Subtitle (PGS), Italian
15: Subtitle (PGS), Spanish
16: Subtitle (PGS), Dutch
17: Subtitle (PGS), Danish
18: Subtitle (PGS), Finnish
19: Subtitle (PGS), Norwegian
20: Subtitle (PGS), Portuguese
21: Subtitle (PGS), Swedish
22: Subtitle (PGS), French
23: Subtitle (PGS), German
24: Subtitle (PGS), Italian
25: Subtitle (PGS), Spanish
Creating file "d:\Encoding\Troy\Chapters.txt"...
[v02] Extracting video track number 2...
[s19] Extracting subtitle track number 19...
[s18] Extracting subtitle track number 18...
[a04] Extracting audio track number 4...
[a04] Extracting TrueHD stream...
[s17] Extracting subtitle track number 17...
[s21] Extracting subtitle track number 21...
[a04] Removing TrueHD dialog normalization...
[a04] Decoding with libav/ffmpeg...
[a04] Writing WAVs...
[v02] Muxing video to Matroska...
[a04] Creating file "d:\Encoding\Troy\Audio.L.wav"...
[a04] Creating file "d:\Encoding\Troy\Audio.C.wav"...
[a04] Creating file "d:\Encoding\Troy\Audio.SL.wav"...
[a04] Creating file "d:\Encoding\Troy\Audio.SR.wav"...
[a04] Creating file "d:\Encoding\Troy\Audio.LFE.wav"...
[a04] Creating file "d:\Encoding\Troy\Audio.R.wav"...
[s19] Creating file "d:\Encoding\Troy\SubNO.sup"...
[s18] Creating file "d:\Encoding\Troy\SubFI.sup"...
[s17] Creating file "d:\Encoding\Troy\SubDK.sup"...
[s21] Creating file "d:\Encoding\Troy\SubSWE.sup"...
[a04] [libav] End of stream indicated <WARNING>
[a04] [libav] Lossless check failed - expected 0, calculated 24 <WARNING>
[a04] The original audio track has a constant bit depth of 16 bits.
Encoding DTS <768kbps> with Surcode...
Found Surcode DTS Encoder version 1.0.23.0.
Surcode encoding successfully started. Please wait...
Closing Surcode...
Added fps value to MKV header.
Video track 2 contains 282025 frames.
Subtitle track 17 contains 1394 captions.
Subtitle track 18 contains 1397 captions.
Subtitle track 19 contains 1390 captions.
Subtitle track 21 contains 1027 captions.
eac3to processing took 1 hour, 23 minutes.
Surcode encoding took 39 minutes, 48 seconds.
Done.
/GZZ
GZZ is offline
Old 19th February 2009, 13:33   #8319  |  Link
jj666
Nothing to worry about, if you check a few pages back, same issue was already explained by Madshi.
Cheers,
-jj-
jj666 is offline
Old 19th February 2009, 18:33   #8320  |  Link
kurt
sidekick
kurt's Avatar
D:\Movies>eac3to test.mkv
MKV, 1 video track, 1 audio track, 0:05:22, 24p
1: h264/AVC, 1280x544 23.999p
2: AC3, 5.1 channels, 640kbps, 48khz
v01 The video bitstream is encoded in a non-standard framerate.
v01 The video bitstream framerate field doesn't match the container framerate.
I got a problem with this file on the Popcorn Hour. Autoframerate isn't working, PCH uses 23,976 (or ,999) instead of 24,000 hz as output. I thought it might be a muxing problem.
How can I distinguish between container and bitstream framerate? which tools can change the framerate to 24.000?
I tried demuxing the elementary stream with eac3to and loading it in mkvmerge (while specifying fps to 24), but eac3to reports the same message of the resulting mkv as before....
[SIZE="1"]General
Complete name                    : D:\Movies\test.mkv
Format                           : Matroska
File size                        : 197 MiB
Duration                         : 5mn 22s
Overall bit rate                 : 5 122 Kbps
Encoded date                     : UTC 2009-02-19 17:21:37
Writing application              : mkvmerge v2.4.2 ('Oh My God') built on Jan 18 2009 17:30:28
Writing library                  : libebml v0.7.7 + libmatroska v0.8.1
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L3.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 5 frames
Muxing mode                      : Container profile=Unknown@3.1
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 5mn 22s
Bit rate                         : 4 271 Kbps
Nominal bit rate                 : 4 392 Kbps
Width                            : 1 280 pixels
Height                           : 544 pixels
Display aspect ratio             : 2.35
Frame rate                       : 24.000 fps
Original frame rate              : 23.999 fps
Resolution                       : 24 bits
Colorimetry                      : 4:2:0
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.256
Writing library                  : x264 core 64 r985 e256ea1
Edit: I found the solution. A remux in mkvmerge with a timecode file (24,000 fps) solved the autoframerate problem
greets, kurt.
Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC
kurt is offline
eac3to
