27th October 2012, 10:39 | #169 | Link |
watches the world burn
Not sure if I should be posting this here or not, but using the dev builds with the new OneClick enhancements, is there a way to make it include audio when using AVISource? It always says internal audio track 1 has to be skipped because AVISOURCE is being used, yet I know for fact that settings audio=true in the AVISource line in the AVS file works just fine.
And on top of that, even if I have AVISource at the bottom of the list of which method should be used to open the file, it still uses it, even though the file indexer is at the bottom and works fine when using it standalone ( Audio works as well ). |
27th October 2012, 15:53 | #170 | Link | |
Please post/upload the complete log. |
27th October 2012, 19:08 | #171 | Link | |
Log: http://pastie.org/private/o81yhqbufwwwc6c2ob8a even though: It's also worth noting that while E:\working\akgyog12.z0b\magusi_Video.mp4 exists, the muxed/processed file that it was supposed to create ( E:\Rendered\reenc\magusi.mp4 ) does not. Edit: And can you please make it continue with the rest of the jobs if one has an error? Last edited by Incendia; 1st November 2012 at 22:28. |
10th November 2012, 17:42 | #172 | Link | ||
No. If you provide a patch it will be faster.
2191 [File Indexer] added DFSC/VFW and CFHD/CINEFORM to the list of not by FFMS supported codecs Quote:
EDIT: found & fixed. That is already the case. Only if in batch processing the first part of the jobs are failing, the following files will not be processed. Last edited by Zathor; 10th November 2012 at 18:07. |
13th November 2012, 05:10 | #173 | Link |
Can you tell me where I need to look? I have no experience but it doesn't seem like it would be hard or time consuming to add. Since AVISource is required to pull in frameserving, this is pretty much useless without such an options ( Since I have to go back and encode the audio separately, then remux the files... Might as well just manually make the avs file that has audio=true at that point, less work overall. )
I'm not sure I understand what you're saying? If one job fails to index it's file ( broken file or simply a hiccup since it never retries to make sure it's really broken ), every other job that would normally be spun up after it is never put in the job list and thus never takes place ( Because for whatever reason one click doesn't add every file to the pending jobs list ahead of time like it should ). It just dies right there ( Kind of annoying to wake up to that in the morning, so many encoding hours lost! ). |
8th December 2012, 22:29 | #174 | Link |
Doing some tests on the new one click system i ran into a odd issue. When doing an encode of a dvd output depends of whether the input file (.vob) has been splitted into multiple files or it is one big file:
Case 1: Using unstable (2231): Using dvd decrypter split set to none. Produces 1 .vob file. Input is 2.38 hour. Output is 1.16 hour. Logfile: http://pastebin.com/698AZGRA Correct chapter is selected and is shown as the correct length but still whole vob is not processed and over half the movie is missing in the output file: Case 2: megui unstable (2231) Using dvd decrypter split set to 1 gb. Produces 4 .vob files. Input is 2.38. Output is 2.38 This work. Case 3: Using megui-stable: Using dvd decrypter split set to none. Procuces 1 .vob file. Input is 2.38. Output is 2.38 This also works, so something must be off in the later versions. Best regards |
15th December 2012, 19:16 | #176 | Link | |
MeGUI is using now pgcdemux to process VOB files if there is more than one PGC. Either DVDDecrypter is producing wrong IFO information or pgcdemux is reading those information not correctly when using one VOB file. In both cases I cannot fix it so please split the VOB files. |
