23rd September 2008, 03:51 | #1462 | Link |
here is the sample http://rapidshare.com/files/147590800/TVNZ6.ts
24th September 2008, 14:12 | #1463 | Link | |
@neuron2
I have read the DGAVCIndex User Manual. In the section "Field Operation" you discuss the differences between honor pulldown, ignore pulldown, and force film. More specifically: Quote:
24th September 2008, 14:16 | #1464 | Link |
Movies on HD-DVD are always encoded as 23.976 so you can safely use Force Film
26th September 2008, 01:17 | #1468 | Link |
Version 1.0.1
* Code restructured for standard decoder interface.
* Changed hotkeys: Save BMP [F7] Copy Frame to Clipboard [F8] * Fixed a memory leak that caused indexing to fail for large files. * Licensing activation system added. [Just kidding!] * Temporarily disabled the frame type field of the Info dialog because it was showing decode order data instead of display order data, which is misleading to the user. (Note: this works correctly in DGAVCIndexNV.) Fix in progress. http://neuron2.net/dgavcdec/dgavcdec101.zip |
26th September 2008, 12:22 | #1471 | Link | |
Software Developer
(BTW: It seems you forgot to change the version number, the "About DGAVCIndex" dialog still says Alpha-35)
26th September 2008, 12:41 | #1472 | Link | |
On another matter, what is the thinking on MKV versus MP4 support? Which should I tackle first? |
26th September 2008, 13:05 | #1474 | Link |
Software Developer
Since MP4 is the "native" container for H.264 (if there is such a thing), I'd vote for MP4
26th September 2008, 14:52 | #1479 | Link | |
Software Developer
