Old 28th December 2014, 18:28   #27901  |  Link
digitech
Originally Posted by digitech View Post
Anyone have recommended settings for sd content using neddi, i have no clue what combination to use, 90% of my sd content is animation and i love to use SVP with it but if i have to sacrifice SVP for better image quality i will, im on nvidia gtx 760, Intel i5 4670k, 16 gb ram, win7
Any help?
digitech is offline   Reply With Quote
Old 28th December 2014, 18:38   #27902  |  Link
a8213711
Use ReClock. (or JRiver VideoClock)
Enable 1080p 24/50/60
Drop 1080p 23/25/30/59.
"1080p 25/30" is actually a 1080i 50/60 output.
Sorry, but this won't take more cpu/gpu load?
I have a low budget laptop, and since I see that when fps and Hz are the same I don't get any dropped frame (infact everything is smooth), I was thinking that if my TV was able to set the same refresh rate I could get a smooth playback without changing quality.
Now that I think about it I get (many) dropped frames per second especially on .wtv files (Windows Media Center recording) which show this: http://i60.tinypic.com/n4ws4i.jpg .
Next week I will try dropping those rates, if anyone have more to add, I'll be glad.
a8213711 is offline   Reply With Quote
Old 28th December 2014, 21:08   #27903  |  Link
michkrol
Unfortunately changing refresh rates won't help you with dropped frames. It depends mostly on scaling factor and framerate.
Those files are interlaced, so simplifying you get 50 frames that need processing from 25 input frames - twice as much as from progressive files.
To get smooth playback your average rendering stats (45ms on screenshot) need to be lower than movie frame interval (20ms on screenshot).
I would suggest you create profiles for your settings with rules below
if (srcInterlaced) "nice"
else "fast"
That way you can have nicer settings for progressive files and smooth playback (lower settings) for interlaced files.
Or you could create separate profiles for playback on laptop's screen and TV.
michkrol is offline   Reply With Quote
Old 28th December 2014, 23:03   #27904  |  Link
BetA13
cosmic entity
BetA13's Avatar
Originally Posted by Hprd View Post
I get the same thing, but it seems only if nnedi3 is used, either for chroma and/OR image doubling/quadrupling. Looks fine using jinc3 for example for both.
Think I'm going to revert to an older Nvidia driver, as I've never seen this before. Don't see how it's madvr's fault.
EDIT: Reverted to 344.75 WHQL drivers, and everything's perfect again.
thanks, going back to the older driver fixed it..
but i also had teh artefacts with image doubling , etc..
so it was ether, older driver or using Jinc.
nnedi3 looks much better. so back to the driver..
i guess im gonna open an Nvidia Ticket and hope for the best..
greetz
edit:
happy now again with nnedi3 and the C1C3 Stream from the CCC in germony....
MadVR and LAV work awesome with MPCHC and teh streams. never had so good picture quality in a stream..yaaayyy
greetz
BetA13 is offline   Reply With Quote
Old 28th December 2014, 23:31   #27905  |  Link
Anima123
Which nVidia driver version is the most stable so far? I am using 340.52 whql.
Anima123 is offline   Reply With Quote
Old 29th December 2014, 00:25   #27906  |  Link
BetA13
cosmic entity
BetA13's Avatar
well, for me and my gtx670 its the 344.75 WHQL one..
But i guess its best to test yourself if u encounter errors..
greetz
Old 29th December 2014, 01:02   #27907  |  Link
braddock
I'm getting dropped frames every few minutes on a 1080p movie that's 4:2:2 instead of the usual blu-ray 4:2:0
GTX 750ti
i5 3570k
16gb ram
Is my GPU?
braddock is offline   Reply With Quote
Old 29th December 2014, 02:55   #27908  |  Link
baii
Turn off smooth motion, it is taxing for lower end gpu.
If you are playing 1080i25 material, 1080p50 refresh rate setting is correct. And that will in turn make smooth option off.
Some option you can try
Cpu deinterlacing using lav
In madvr, check use half frame rate in trade quality for performance.
Sent from my 306SH
baii is offline   Reply With Quote
Old 29th December 2014, 06:45   #27909  |  Link
JarrettH
Why does madvr still contain decoders? Are there benefits I am unaware of? I think with LAV being bundled now it's no longer necessary.
Old 29th December 2014, 08:06   #27910  |  Link
romulous
LAV may be bundled with some players, but it is not bundled with madVR. Anyway, to answer the question - convenience, and troubleshooting. Convenience - if you don't want to (or can't) use another third party decoder, you don't have to, just use madVR's built in decoder. Troubleshooting - not sure if the issue you have is due to madVR, or the third party decoder? Disable the decoder and use madVR's decoder. That will tell you.
romulous is offline   Reply With Quote
Old 29th December 2014, 17:11   #27911  |  Link
a8213711
Thank you everyone, but I still can't use the laptop right now, so I will properly change its settings afterwards.
But meanwhile I want to ask something.
My GPU is capable of i25 (see http://forum.doom9.org/showpost.php?...ostcount=27887 for details), is there a way to understand if my TV is capable too?
Shouldn't my laptop be able to playback easily a file if source and output are the same? (adding in madVr all the interlaced I support)
Also let me clarify that I never use the laptop screen, and that I disabled Smooth Motion long ago; in case someone is wondering, I have this APU: http://www.notebookcheck.net/AMD-A-S...r.74885.0.html
Old 29th December 2014, 23:05   #27912  |  Link
baii
The screenshot say it is on, I think you need to disable it for every display device iirc.
Sent from my 306SH
Old 30th December 2014, 06:33   #27913  |  Link
StinDaWg
What is the minimum Nvidia gpu required for 720p60->1080p60 NNEDI3 image doubling? 750ti can't do it, so what's next in line that won't break the bank? I'm thinking of getting a 4K tv, and I don't think any AMD cards can do 4K @ 60hz yet over HDMI. Any idea if this can be updated via firmware like what happened to the Nvidia cards?
Also, can any of them NNEDI3 quadruple from 720p to 4K, or double from 1080p to 4K?
StinDaWg is offline   Reply With Quote
Old 30th December 2014, 11:02   #27914  |  Link
feelingblue
If your GPU is not powerful enough, why don't try resolution doubling with ffdshow before madvr (if your CPU can do it of course)?
For 1080p to 4k is a simple vertical and horizontal doubling.
For 720p to 1080p you can try 1280x720 doubling to 2560x1440 then downscaling to 1080p with CR (or what you like)
feelingblue is offline   Reply With Quote
Old 30th December 2014, 19:52   #27915  |  Link
don't forget older nvdia cards can do UHD 60 hz with 4:2:0 only the new 9XX cards can do UHD 60 hz 4:4:4.
Old 31st December 2014, 10:20   #27916  |  Link
Razoola
And the fact that there is the new card GTX 960 being released at the end of Janurary.
Raz
Old 31st December 2014, 12:26   #27917  |  Link
nekromantik
Is there any way to stop MadVR doing any scaling on 4k videos?
I had my laptop connected to a 4k tv at native res and played a 4k trailer and it stutters and I get 110ms render time.
However if I disable madvr its smooth.
My specs are i7 4700hq, gtx860 + intel 4600
Cheers
nekromantik is offline   Reply With Quote
Old 31st December 2014, 12:34   #27918  |  Link
madVR doesn't scale if it doesn't have too.
what chroma upscale settings do you use? and did you make sure the gtx 860 is used and not the intel IGPU?
Old 31st December 2014, 12:40   #27919  |  Link
nekromantik
Im using NND13 16 neurons.
Just checked and there is no gpu load on my GTX860m.
I got optimus laptop and tried everything on this forum to get it to use the dedicated card but still nothing apparently. I thought I had fixed it but new driver update must have messed it up again.
Old 31st December 2014, 12:44   #27920  |  Link
Qaq
AV heretic
Set player to show picture in original size.
Make sure madVR is set to OD dithering and try some lite chroma upsampler like Bicubic 75 with AR uncheked.
Check queues values.
Qaq is offline   Reply With Quote
