6th December 2010, 23:21 | #5961 | Link |
TopDonn: If I understand you correctly the issue occurs only if you mux the x264 encode with MP4Box. It does not occur if you use only the x264 encode. Is this correct? If yes then try once again another muxer e.g. this one: http://megui.org/auto/MP4Box-0.4.6-rev2125.zip
Also please disable the "Force Decoding via DirectShow" in your audio profile and maybe switch to neroenc. Additionally please upload the source file or at least a part of the file where you can reproduce the error. |
6th December 2010, 23:54 | #5962 | Link | |
Let me however try the workarounds that you have mentioned and will get back with the results |
7th December 2010, 01:14 | #5963 | Link | |
What's weird is that i had already tried replacing it with the one from Yamb as suggested by Sharktooth but that did not work. Sharktook mentioned earlier that recent versions of mp4box are a PITA. Yup, i guess they are. Anyway, issue solved. Last edited by TopDonn; 7th December 2010 at 01:16. |
7th December 2010, 10:56 | #5964 | Link |
Hi...
I just set up MeGUI for the 1st time the other day to replace AutoGK that I've used to compress TV captures in the past. I have to admit right up front here that I'm not the brightest lamp in the room when it comes to most video work. After a couple of days now, I've managed to get a basic grasp on converting MPEG2 captures to xvid avi files and h.264 MP4 files with MeGUI. But I ran into a problem converting some VOB files on an old DVD that were encoded a bit oddly, and though I've managed to get a reasonably transcoded MP4, I have to force smplayer to a 4:3 AR in order to have it display properly. Smplayer reports the file's AR as 1.6162, while both GSpot and MPC see it as 1.333. This isn't a huge problem, but I'd really like to understand what's happening here for future reference. The storage frame for the original DVD video was set to 544x480, the image is anamorphic, and was letterboxed with 18 pixels on the left, 8 pixels on the right, and 2 pixels on the bottom. And the frame rate is 29.970. Here's a frame: I originally had problems getting MeGUI's AVS Script Creator to write an avs file that would result in a file that could display the proper display AR. The tool reports the video as having an input DAR of ITU 4:3 PAL (1.367521), yet to the right of the selection box it reports NTSC. DGIndex also reports it as NTSC. But I guess it's neither, having been created by some software that's ancient history to me at this point. What I did was to run 'auto crop', set 'clever anamorphic encoding' to 'resize to mod 16', ran interlacing analysis and saved the AVS file. But I could tell that the transcoded video was slightly squeezed horizontally. I looked at the AVS file and found anamorphic encoding was resizing the video as follows: global MeGUI_darx = 21 global MeGUI_dary = 16 I just changed the values to: global MeGUI_darx = 4 global MeGUI_dary = 3 The result displayed properly in MPC, WMP, Quicktime Player, and Total Video Player. Here's a screen capture: Only smplayer had to have 4:3 forced, as by default it displays it at the value of 1.6162 that it's reporting the AR to be. This is really the 1st time I've dealt directly with anamorphic transcoding which I'm just now learning about as I learn MeGUI. So I'm wondering if there is a better solution to this problem than editing that AVS file as I've done. GSpot reports the following for the transcoded file: Codec: avc1 - Name: H.264/MPEG-4 AVC Storage frame: 544x480 sar: 1.100 (11:10) par: (none) dar: 1.333(4:3) fps: 23.976 For some reason MeGUI changed the source file's original frame rate of 29.970 to 23:976. I don't know enough about video to know if that may be contributing to smplayer's problems GSpot reports the following for the source file: Codec: MPEG2 - Name: MPEG-2 Storage frame: 544x480 sar: 1.133(17:15) par: 1.176 (20:17) dar: 1.333(4:3) fps: 29.970 Hopefully someone here can tell me if there's a better way to achieve my goal. I also hope this is the proper place to be asking about this. Thanks pq Last edited by pequickit; 9th December 2010 at 09:25. |
11th December 2010, 00:38 | #5965 | Link |
Getting Started
OK, so I am really trying to work with MeGui to see if I can get better encodes than I do with handbrake. Although handbrake seem to make the process alot simpler.
Are there any places to find up to date guides for MeGui. And some tips (best profiles, best codecs to use). I search the forums and there is alot of information but it seems like it is al either old versions of MeGui with old presets and setting that don't exist. Any I am just wondering. If not maybe some help. I am wanting to basically convert my DVD video_ts folder to mp4. I want to set up an autoencode setting that will pretty much just work (I will accept some loss in quality to not have to set and test things every time). I want to end up with a file that has: 1.The video stream (x.264_Unrestricted (DXVA) or x.264_Max Compatibility (DXVA); just how uncompatible is the unrestricted) 2. Surround sound audio stream (was thinking NDAAC-HE48Kbps as i heard faac is not as good) 3. AC3 passthrough (my guess is I have to mux this in at the end somehow) 4. Subtitles (forced subtitles and if possible CC so if I mute subtitles come up realizing that the playback software would have to support that but would want it there just in case) Would also love to know if there is a way to embeed the cover art and metadata at the time the files is encoded/muxed. Watching a buddy try to add coverart to his itunes library for his movies and it takes him about 6min each movie. I don't currently use iTunes (media center uses the folder.jpg) but don't want to have to go through what he is if down the road I get an appleTV or somthing. Would just liek to have it there. Anyhow, sorry for the tone of questions. Hopefully someone could help. |
12th December 2010, 02:24 | #5966 | Link |
These don't all address your questions, and they're all not up-to-date, but here's a few URLs that got me up and running:
Convert DVD to XviD with meGUI how to DVDRIP to XVID.AVI MeGUI/Basic DVD Ripping Guide/Ripping Windows 7 - Video Encoding x264 (MeGUI) MeGUI H.264 Conversion Guide OneClick Encoder and AutoEncode Walk-Through Guides |
12th December 2010, 08:41 | #5967 | Link |
hi, i found the problem when using the latest stable version of megui. When i choose slow first pass in x264 config, then i try to check my result file with mediainfo, it still have "fast_pskip=1" is it bug or something?
Another question, how to cut and deleting some middle part of our video? thanks |
12th December 2010, 12:54 | #5968 | Link | |
Slow first pass only means that the same settings will be used in first pass as in the second. The mediainfo of your output will be the same regardless, since the first pass doesn't write a file. Fast pskip is an analysis option. You can activate it via the advanced options if you like. The only x264 inbuilt preset that uses fast_pskip=0 is preset placebo. Last edited by nurbs; 12th December 2010 at 15:24. Reason: LigH |
12th December 2010, 14:59 | #5970 | Link | |
The Black Reaper
12th December 2010, 20:21 | #5976 | Link |
if i convert hd material to mkv full hd with me-gui i get a perfect mkv file.
but if i mux the file to a bluray with ts muxer and make an image with imgburn i get a realy bad video because it is full with arthefacts and powerdvd can`t play the bluray has anybody this problem to? my way to convert: hd stream extractor -> get the streams DgavC index -> get the dga file my avs script has 4 lines LoadPlugin("D:\DGAVCDecode.dll") AVCSource("C:\project.dga") asharp(2,3,1.3,hqbf=true) tweak(sat=1.09) this i load in megui the settings for the x264 i use only the preset verry slow and by tuning: Film after the converting i use tsmuxer to get the bluray strukture and made an image with imgburn what i doing wrong |
13th December 2010, 12:03 | #5978 | Link | |||
i already try with avs cutter. but the command in this setting is just to cut begining part and end part of video but not middle part of it. or maybe there is another command in avs cutter i dont understand? Quote:
13th December 2010, 12:09 | #5979 | Link | |
The Black Reaper
Use the zone start and zone end button preview window to select exactly which part of the video do you want to be encoded out. For the audio you can use the audio cutter or just select the cut file in the audio tab. Last edited by Lighto; 13th December 2010 at 12:16. |
megui |
