25th December 2005, 16:11 | #921 | Link |
Software Developer
There is something that makes me crazy
I was using the Nero AAC Encoder very often. Most times in BeLight, somteimes in BeSweet from command-line. And it always worked fine. Until yesterday! I encoded one file and everything was alright. Then I tried to encode another file and Wooooshhhhhh. I doesn't work any longer! I get those "error configuring bsn" error each time. How can this be? I did not change anything at all. Not one bit! Encoding one file: works. Encoding second file: does not work. And now it does not work, for any file. Even for files i encoded minutes before. Encoding doesn't work in BeLight (it says encoding completed after one second, but encoding was *not* completed) and it doesn't work if I run BeSweet directly. I cannot understand this I alread tried to re-install everything, but no success Code:
BeSweet v1.5b31 by DSPguru. -------------------------- Using Shibatch.dll v0.25 by Naoki Shibata & DSPguru (shibatch.sourceforge.net). Using bsn.dll replacement v0.02 by dimzon (dimzon541@gmail.com). Logging start : 12/25/05 , 16:10:05. BeSweet.exe -core( -input C:\Temp\X.wav -output C:\Temp\X.mp4 -logfile C:\Temp\X.log ) -bsn( -2ch -vbr_extreme -codecquality_high -aacprofile_lc ) -ota( -g max ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : C:\Temp\X.wav [00:00:00:000] | Output: C:\Temp\X.mp4 [00:00:00:000] | Floating-Point Process: No Error 84: error configuring bsn! Quiting... [00:00:00:000] Conversion Completed ! Logging ends : 12/25/05 , 16:10:05.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 25th December 2005 at 16:15. |
26th December 2005, 10:12 | #923 | Link | |
BeHappy/MeGUI developer
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
26th December 2005, 13:40 | #924 | Link |
Swallowed in the Sea
You mean bse_Nero7WA.dll only ? coz I've made a quick test with Nero7 dlls :
So, what's wrong ? |
26th December 2005, 13:42 | #925 | Link |
You need original bsn.dll (forget dimzon's bsn - it is obsolete since dedicated -dimzon switch) + bse_Nero7WA.dll
and you must call Nero7 encoder via -dimzon( -dllname bse_Nero7WA.dll ... ) always
27th December 2005, 16:02 | #929 | Link | |
Software Developer
Hope they will fix that (see posts above). Nevertheless there is another command-line front-end for the Nero Encoder, which works fine for me. Maybe you'll give this one a try: http://www.rarewares.org/files/aac/nero_fends.rar
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 27th December 2005 at 16:32. |
27th December 2005, 20:52 | #930 | Link |
You need bsn.dll from the last BeSweet package (http://dspguru.doom9.net) + bse_Nero7WA.dll. And it works fine...
27th December 2005, 23:35 | #931 | Link |
-------------------------- Using Shibatch.dll v0.25 by Naoki Shibata & DSPguru (shibatch.sourceforge.net). Using bsn.dll v0.24 by DPeshev,Richard,E-Male,DSPguru (DSPguru.Doom9.org). Logging start : 12/27/05 , 22:33:49. BeSweet.exe -core( -input C:\New Folder\rusty.wav -output C:\New Folder\rusty.mp4 -logfile C:\New Folder\rusty_2.log ) -bsn( -2ch -vbr_normal -aacprofile_lc ) -ssrc( --rate 48000 ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : C:\New Folder\rusty.wav [00:00:00:000] | Output: C:\New Folder\rusty.mp4 [00:00:00:000] | Floating-Point Process: No Error 84: error configuring bsn! Quiting... [00:00:00:000] Conversion Completed ! Logging ends : 12/27/05 , 22:33:50. thats my log file, using besweet 1.5b31 dll's and + bse_Nero7WA.dll |
27th December 2005, 23:57 | #932 | Link |
Software Developer
@deets:
dimzon said "and you must call Nero7 encoder via -dimzon( -dllname bse_Nero7WA.dll ... ) always" Seems like you didn't do that...
28th December 2005, 04:44 | #933 | Link |
Software Developer
The changelog sais that Nero's AAC Encoder supports Parametric Stereo since Version 7.0.1.2. Is there a way to use PS mode with the Nero encoder in BeSweet/BeLight?
28th December 2005, 05:25 | #934 | Link |
Mr. Sandman
PS is automatically enabled so you dont need to specify it.
28th December 2005, 05:38 | #935 | Link | |
Software Developer
28th December 2005, 15:50 | #936 | Link |
Mr. Sandman
it gets enabled around 50kbps... cant remember exactly though.
30th December 2005, 20:12 | #937 | Link |
Actually in reserve
Manual gain for ac3 encoding
Continuing the discussion from here: http://forum.doom9.org/showthread.ph...244#post759244 (thanks to dragongodz)
Summary: from my tests, the Belight/Besweet -ota gain modes are still much lower than original ac3. Tebasuna51 quantify this as-6db overall volume decrease. I will try 8.035db +6 = 14db and search for distorsion or artefacts (I tried manually +11db with ac3machine on that sample and seems ok) Could you consider implementing a manual gain command in Belight? thank you. Did
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first Want to exchange on AutoGK? try doom10.org In reserve (inactive) for an undefined period of time. |
31st December 2005, 15:52 | #938 | Link | ||
2nd January 2006, 05:33 | #939 | Link |
foobaring my ass off
Some issues with HE-AAC on Nero Digital mode:
a 1:48:46 HMS audio track 6-ch 48kHz 16bits, creates bad audio (played with ffdshow and Winamp) no matter what options I use. These are clips made with HE profile (all 20 seconds each): 1) encoding 1h48m36s WAV from 1m50s to 2m10s with these options: Code:
BeSweet v1.5b31 by DSPguru. -------------------------- Using Shibatch.dll v0.25 by Naoki Shibata & DSPguru (shibatch.sourceforge.net). Using bsn.dll v0.24 by DPeshev,Richard,E-Male,DSPguru (DSPguru.Doom9.org). Logging start : 01/01/06 , 22:55:43. BeSweet.exe -core( -input C:\Documents and Settings\Athlon XP\Mis documentos\hitch_aac.wav -output C:\Documents and Settings\Athlon XP\Mis documentos\hitch_aac_1.mp4 -logfile C:\Documents and Settings\Athlon XP\Mis documentos\hitch_aac_5.log ) -bsn( -6chnew -cbr 224 -codecquality_high -aacprofile_he ) -split( -start 110 -end 130 ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : C:\Documents and Settings\Athlon XP\Mis documentos\hitch_aac.wav [00:00:00:000] | Output: C:\Documents and Settings\Athlon XP\Mis documentos\hitch_aac_1.mp4 [00:00:00:000] | Floating-Point Process: No [00:00:00:000] | Source Sample-Rate: 48.0KHz [00:00:00:000] +-------- BSN -------- [00:00:00:000] | bitrate: cbr 192 [00:00:00:000] | HE-aac high quality encoding [00:00:00:000] +--------------------- [00:00:20:000] Conversion Completed ! [00:00:10:000] <-- Transcoding Duration Logging ends : 01/01/06 , 22:55:53. 2) encoding a 2m30s WAV entirely, and then splitting a 20 seconds clip: Code:
BeSweet v1.5b31 by DSPguru. -------------------------- Using Shibatch.dll v0.25 by Naoki Shibata & DSPguru (shibatch.sourceforge.net). Using bsn.dll v0.24 by DPeshev,Richard,E-Male,DSPguru (DSPguru.Doom9.org). Logging start : 01/01/06 , 23:04:26. BeSweet.exe -core( -input C:\Documents and Settings\Athlon XP\Mis documentos\hitch_aac_fixed.wav -output C:\Documents and Settings\Athlon XP\Mis documentos\hitch_aac_fixed_1.mp4 -logfile C:\Documents and Settings\Athlon XP\Mis documentos\hitch_aac_fixed_1.log ) -bsn( -6chnew -cbr 224 -codecquality_high -aacprofile_he ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : C:\Documents and Settings\Athlon XP\Mis documentos\hitch_aac_fixed.wav [00:00:00:000] | Output: C:\Documents and Settings\Athlon XP\Mis documentos\hitch_aac_fixed_1.mp4 [00:00:00:000] | Floating-Point Process: No [00:00:00:000] | Source Sample-Rate: 48.0KHz [00:00:00:000] +-------- BSN -------- [00:00:00:000] | bitrate: cbr 192 [00:00:00:000] | HE-aac high quality encoding [00:00:00:000] +--------------------- [00:02:30:000] Conversion Completed ! [00:00:42:000] <-- Transcoding Duration Logging ends : 01/01/06 , 23:05:08. 3) the same 2m30s WAV, but encoding 20s from 1m50s to 2m10s: Code:
BeSweet v1.5b31 by DSPguru. -------------------------- Using Shibatch.dll v0.25 by Naoki Shibata & DSPguru (shibatch.sourceforge.net). Using bsn.dll v0.24 by DPeshev,Richard,E-Male,DSPguru (DSPguru.Doom9.org). Logging start : 01/01/06 , 23:02:27. BeSweet.exe -core( -input C:\Documents and Settings\Athlon XP\Mis documentos\hitch_aac_fixed.wav -output C:\Documents and Settings\Athlon XP\Mis documentos\hitch_aac_fixed.mp4 -logfile C:\Documents and Settings\Athlon XP\Mis documentos\hitch_aac_fixed.log ) -bsn( -6chnew -cbr 224 -codecquality_high -aacprofile_he ) -split( -start 110 -end 130 ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : C:\Documents and Settings\Athlon XP\Mis documentos\hitch_aac_fixed.wav [00:00:00:000] | Output: C:\Documents and Settings\Athlon XP\Mis documentos\hitch_aac_fixed.mp4 [00:00:00:000] | Floating-Point Process: No [00:00:00:000] | Source Sample-Rate: 48.0KHz [00:00:00:000] +-------- BSN -------- [00:00:00:000] | bitrate: cbr 192 [00:00:00:000] | HE-aac high quality encoding [00:00:00:000] +--------------------- [00:00:20:000] Conversion Completed ! [00:00:09:000] <-- Transcoding Duration Logging ends : 01/01/06 , 23:02:36. 4) The same 2m30s WAV, encoded with AACEnc32 (-cbr 224 -lowpass 24000): Aacenc32 output Is there a bug related to this? Also, how come there isnīt a option to set the output fileīs name to other than the sourceīs name with differente extension?
"Damn, respect my authoritay!!" - E. Cartman |
2nd January 2006, 12:03 | #940 | Link | ||
