11th July 2010, 19:28 | #2022 | Link |
My bad neuron2
after adding LoadPlugin(path\DGmultisource.dll) Errors are gone ! I did 32 reloads (F2), and video memory remained at 192Mb. Juste like it was with the initial load of the script. I'm sorry, I tought I didn't need the loadplugin() since everything was in the same folder. Now it's working flawlessly. You're a genius. |
11th July 2010, 20:54 | #2025 | Link | |
VirtualDub 1.9.4 And right now, I can't duplicate the freezing, so I can't give you the dump... Weird. Let it go for now, I'll do some testing tomorrow. |
11th July 2010, 21:28 | #2026 | Link |
OK, thanks. It's probably not related to the memory leak issue so I will go ahead and release 2020 and we'll revisit your issue as needed.
Regarding your bad EOF case, I am thinking you have an incomplete picture at the end, but I'm still investigating. I haven't seen it on any other streams. Have you? |
11th July 2010, 22:13 | #2028 | Link |
It's working for me with the testbuild.
My template : Code:
video=DGSource("__vid__") ## ,fieldop=0,deinterlace=1,resize_w=1280, resize_h=720 audio=WavSource("__aud__") AudioDub(video,audio) DelayAudio(__del__)# in seconds -> for ms -> (0.000)ms ConvertToYV12() Code:
video=DGSource("C:\Users\Alf\Downloads\DGNV testbuild\00001.dgi") ## ,fieldop=0,deinterlace=1,resize_w=1280, resize_h=720 audio=WavSource("C:\Users\Alf\Downloads\DGNV testbuild\00001 PID 1100 2_0ch 48KHz 192Kbps DELAY 0ms.ac3") AudioDub(video,audio) DelayAudio(0.000)# in seconds -> for ms -> (0.000)ms ConvertToYV12() |
11th July 2010, 22:24 | #2029 | Link | |
And maybe I found something. I know, you always telling people not to play another video, while encoding with DGNV. But when I open in MPC some .mkv x264 hd video (using CoreAVC 2.0 without CUDA support & AC3filter), pause it and then open dgmultisouce .avs in VDub -> it freezes everytime... |
11th July 2010, 23:10 | #2031 | Link | |
11th July 2010, 23:43 | #2032 | Link |
Build 2020
* Revised DGMultiSource() to use floating CUVID contexts so that it no longer leaks GPU memory.
This should enable use in all GUIs without the dreaded decoder creation failure or crashes. * Due to the fix above, CUVID Server and DGSource() are no longer necessary and are therefore retired and omitted from the distribution. * Added an error popup for VC1 streams that erroneously contain sequence headers not followed by an I frame (as required by spec). If you run into this please let me know. * Fixed a regression in pulldown detection for VC1. * For AVC, POCs are now stored in the DGI file as they appear in the stream, i.e., they are not divided by two. * Fixed a regression in expansion of the __aud__ and __del__ macros for script generation. http://neuron2.net/dgdecnv/dgdecnv.html |
12th July 2010, 01:18 | #2033 | Link |
RedDwarf Fan
Thank you. The new version is working much better with none of the GPU memory problems which makes it far more usable for me.
I can refresh the script and resize the preview without having to keep one eye on GPU-z for memory usage and keep closing AvsP all the time. Last edited by RedDwarf1; 12th July 2010 at 02:10. |
12th July 2010, 02:19 | #2035 | Link | |
RedDwarf Fan
It's a pity ATI don't offer such support because no matter how good their GPU's are, without developers writing the software for their GPU chipsets, they are a poor choice compared to nVidia for anyone who wants to do anything serious. |
12th July 2010, 04:27 | #2036 | Link | |
-i %source_files_comma% -y 1 -o "%working_dir%\%source_name%.dgi" -a -e. I knew it had to be something simple. |
12th July 2010, 07:06 | #2038 | Link | |
http://www.anandtech.com/show/3809/n...the-200-king/4 |
12th July 2010, 13:13 | #2039 | Link |
I can't get DGDecNV to ignore the vc1 pulldown from the following file.
Here is a sample It is a vc1 stream extracted from HD DVD using eac3to with -keepPulldown option. I have tried 2019 and 2020 and both are unsuccessful. Here is my script: Code:
LoadPlugin("C:\Program Files\DGDecNV\DGMultiDecodeNV.dll") DGMultiSource("C:\Personal\Videos\sample_pulldown.dgi", fieldop=2) |
12th July 2010, 13:33 | #2040 | Link |
You chose ignore pulldown. That will cause the pulldown to not be honored (you can see that because there are no combed frames with fieldop=2) but the frame rate will not be changed. What you should use is force film (fieldop=1). It's all explained in the manual.
If the pulldown is constant pure 3:2 then it is the case that you can get the same result as force film by using ignore and AssumeFPS(23.976) in your script. |
