Old 1st February 2008, 03:12   #161  |  Link
jamos
Hey Now!
Originally Posted by VintageGuy View Post
Waiting on Jamos step by step to AVCHD.
http://forum.doom9.org/showthread.php?t=134348
jamos is offline   Reply With Quote
Old 1st February 2008, 03:14   #162  |  Link
jamos
Hey Now!
Originally Posted by SKAPiter View Post
Hi. First off, thanks for the good program! Especially m2ts option looks promising for AVCHD disk creation.
Problems I found...
1. Automatic level changing from 5.1 to 4.1 does not work for me. I had to demux to elementary streams and change to 4.1 by H264Info.
2. I successfuly muxed one h264 video stream and two AC3 audio streams. It plays both audio streams on the PC but PS3 does not see the second stream. Only first one.
Is it supposed to support only one audio stream or I am doing something wrong?
PS3 can only play the first stream for files. You would need AVCHD disk to have different audio streams. And yes the 4.1 option does not work currently with TSmuxer.
Old 1st February 2008, 03:16   #163  |  Link
jamos
Hey Now!
I just created an AVCHD disk via TsRemux 0.0.19 from the above mentioned m2ts file and burned it to DV+RW. The resulted disk is recongnized by PS3 as AVCHD. Video plays fine with all features, i.e. 5 min. chapters, ff/rw but here is NO AUDIO :-) None of the audio stream is present. Bumer. :-(
uncheck bypass audio alignment and it should work.
Old 1st February 2008, 11:38   #164  |  Link
winnydows
winnydows's Avatar
Nice tool! I wait this tool creation .
How soon will be added demuxing functions ?
Now I use ffmpeg for demuxing, but ff can`t demux mpeg4aac.
winnydows is offline   Reply With Quote
Old 1st February 2008, 18:54   #165  |  Link
jamos
Hey Now!
DTS does not work yet.
Old 1st February 2008, 23:24   #166  |  Link
menlvd
http://www.smlabs.net/tsMuxer/tsMuxeR_1.2.10.zip
menlvd is offline   Reply With Quote
Old 1st February 2008, 23:29   #167  |  Link
d1g1ta7
would it be possible to rewrite the headers of 1920x1088 h.264 videos to 1920x1080? The PS3 seems to have issues playing back 1920x1088 h.264 videos, but 1920x1080 work fine.
d1g1ta7 is offline   Reply With Quote
Old 1st February 2008, 23:59   #168  |  Link
Zow
Originally Posted by menlvd View Post
What's new? I can't try it until I get home. (I am still hoping for subtitles to MKV:-)
Zow is offline   Reply With Quote
Old 2nd February 2008, 00:16   #169  |  Link
lance79
I am trying to mux a vc1 es stream to m2ts with tsmuxer but having some problems.The vc1-es is accepted and converted but when playing back the first second play's right,after that the video go's full speed to the end.Also tsremux cant make a valid blu-ray structure from it.
I've tried with wmv 720p & 1088p.
I use VC-1 "ES" writer filter, v0.2 for getting the vc1 es from the wmv.
http://www.ftyps.com/unrelated/vc1_es.v0.2.zip
Here is a sample of the 1088p vc1 es, maby u can take a look at it?
http://www.zshare.net/download/7100918641ee95
greetz,
lance
lance79 is offline   Reply With Quote
Old 2nd February 2008, 00:26   #170  |  Link
menlvd
greetz,
lance
try new version 1.2.10 maybe that's help U
in new ver, have some bug fix for vc-1 streams?
but for me it's not worked
still have problem with playing resulting file
Old 3rd February 2008, 01:27   #171  |  Link
idbirch2
Is there any chance this app will ever be able to mux into an MPEG program stream i.e .mpg or .m2p? I'm trying to remux an MPEG2 BluRay with DTS audio for streaming to a 360 but Vista MCX does not allow .ts streaming any more.
idbirch2 is offline   Reply With Quote
Old 3rd February 2008, 01:35   #172  |  Link
@roman76r
Can you release the source code?
Old 3rd February 2008, 05:56   #173  |  Link
lchiu7
Alas I had high hopes for this but I can't get it to work.
Situation:
Some H.264 files and AC3 in a MKV container. I demultiplexed the audio and video and changed the level to 4.1
Using the latest version ran tsmuxer to put them back in a .ts container with aac and ac3 audio. File plays fine on my PC using vlc but put in on a DVD or USB stick and try to play on the PS3 and the PS3 says no data on either medium
Up till now this has worked for me
Demuxed the mkv file into the elemental streams
Change the level to 4.1
Reencode the audio from AC3 to aac 5.1 using eac2to and neroencode
Mux the two files back using mp4box
These play fine
But I really want AC3 audio since my PS3 is connected via Toslink (not HDMI) so 5.1 aac ends up as 2 channel PCM if I want to get any audio at all)
Any ideas what I could be doing wrong?
lchiu7 is offline   Reply With Quote
Old 3rd February 2008, 08:18   #174  |  Link
lance79
isn't fixed in this version...
Old 3rd February 2008, 11:32   #175  |  Link
Sparky101
Situation:
These play fine
Try remuxing your .ts to .m2ts with TSRemux.
Sparky101 is offline   Reply With Quote
Old 3rd February 2008, 11:33   #176  |  Link
Sparky101
Can't you just rename the file to .mpg?
Old 3rd February 2008, 12:35   #177  |  Link
napalm-187
hi
i have an question
i have remuxed an m2ts with h264 with an sperate dts file
in direktshowplayers plays fine, but in powerdvd not
the info window of the file says mpeg4 with 346 mbit
and the file dont play
where is here the failure
thx
napalm-187 is offline   Reply With Quote
Old 3rd February 2008, 12:39   #178  |  Link
idbirch2
No, Vista no longer allows streaming of .TS packets to an extender so it doesn't matter what file extension you rename it to, it won't play.
I've found from a bit of searching though, that ReJig can mux DTS with M2V, and it has successfully created a VOB which plays fine in MPC with DTS intact. VOB is a program stream so renaming this to .MPG should work. I'll be testing this on the 360 shortly.
Old 3rd February 2008, 13:04   #179  |  Link
mic64
Hi
anyone else have problems with importin ac3 files?
I get always the message "Can't detect Stream Type"
mic64 is offline   Reply With Quote
Old 3rd February 2008, 14:28   #180  |  Link
BillyBlue77
I'm trying to play a self encoded mkv (megui, h264, ac3 english and german, subtitles english and german) on my PS3 (non linuxed). The only success I had was using "mkv2vob", of course losing the second ac3 audio and all subtitles, but ff/rw is possible. The aspect ratio is wrong with mkv2vob though.
When I try to remux this mkv with tsMuxeR, the resulting file is not shown on the PS3, neither as ts nor m2ts. It plays well on the PC using MediaPlayerClassic and the aspect ratio is correct. Am I doing something wrong or missing a step? Do I have to use TSRemux afterwards? I thought I read in this thread that this is not necessary?
Thx in advance,
Billy
BillyBlue77 is offline   Reply With Quote
tsmuxer
