Old 31st January 2008, 09:44   #141  |  Link
[)370|\|470!2
dentist-experimenter
[)370|\|470!2's Avatar
Originally Posted by tyee View Post
I just split a .m2ts made from tsremux yesterday into 5 sections with HDBDSplitterGUI and they all play in my PS3!
Frankly very intriguing. Would you be so kind to link me to that remarkable tool, since google returns 1 result for it only which is the same exact page? Roflmao.
20 years and ubuntu has just restored my faith in humanity ...lol
[)370|\|470!2 is offline   Reply With Quote
Old 31st January 2008, 10:30   #142  |  Link
LOGiC
@[)370|\|470!2
I think he meant "HDBDSplitGUI" not splitterGUI. If you google this, it will find some more stuff. I tested this program a couple of weeks ago and really didn't like it. Even if I read from one drive and wrote to another, it was a noise as my drives would be going to explode. I think the latest version of H264TS_Cutter supports M2TS as Input as well, as long as there is AVC behind. I am going to test it this evening.
LOGiC is offline   Reply With Quote
Old 31st January 2008, 12:38   #143  |  Link
VintageGuy
Is it just me or is the new 1.2.8 version saying 1.2.6 when it opens?
VintageGuy is offline   Reply With Quote
Old 31st January 2008, 12:45   #144  |  Link
Joniii
Edit:
nm, I found what was wrong.
Joniii is offline   Reply With Quote
Old 31st January 2008, 15:20   #145  |  Link
yonta
v1.2.8 GUI is identical to v1.2.6 GUI, but the CLI is different.
yonta is offline   Reply With Quote
Old 31st January 2008, 17:03   #146  |  Link
jamos
Hey Now!
Originally Posted by LOGiC View Post
@[)370|\|470!2
there is nothing wrong with HDBDSplit I use it all the time. the sound may be a sign that your drives are going.
jamos is offline   Reply With Quote
Old 31st January 2008, 17:33   #147  |  Link
k-c-ksum
dont know why it doesnt work with this
sample -
http://rapidshare.com/files/87804796..._Plus.EVO.html
k-c-ksum
k-c-ksum is offline   Reply With Quote
Old 31st January 2008, 17:50   #148  |  Link
zeroprobe
Anyone got DTS in a TS working on PS3? or is this not supported.
EDIT: It works as DTS 1.5mb in avchd burned on a DVDR
zeroprobe is offline   Reply With Quote
Old 31st January 2008, 18:19   #149  |  Link
oozie
I knew that.
But I'm afraid we can't play DTS from the XMB, can we?
oozie is offline   Reply With Quote
Old 31st January 2008, 18:28   #150  |  Link
zeroprobe
Originally Posted by oozie View Post
I knew that.
Nope what a shame
Old 31st January 2008, 18:36   #151  |  Link
lance79
How do u mux AVC 1280x544 to blu-ray output, cos i'm getting errors using tsremux after i used tsmuxer for creating the m2ts.
The output is created but there is no clipinf...
If your stream is AVC you won't see it. Tested many times!
lance79 is offline   Reply With Quote
Old 31st January 2008, 18:58   #152  |  Link
VintageGuy
Waiting on Jamos step by step to AVCHD.
Old 31st January 2008, 20:48   #153  |  Link
The1n
Thanks for the update! (1.2.9) any chance we'll see lpcm muxing soon ?
The1n
The1n is offline   Reply With Quote
Old 31st January 2008, 21:37   #154  |  Link
jamos
Hey Now!
Originally Posted by zeroprobe View Post
Nope what a shame
no in a xmb you only can get ac3.
Old 31st January 2008, 21:42   #155  |  Link
SKAPiter
SKAPiter's Avatar
Hi. First off, thanks for the good program! Especially m2ts option looks promising for AVCHD disk creation.
Problems I found...
1. Automatic level changing from 5.1 to 4.1 does not work for me. I had to demux to elementary streams and change to 4.1 by H264Info.
2. I successfuly muxed one h264 video stream and two AC3 audio streams. It plays both audio streams on the PC but PS3 does not see the second stream. Only first one.
Is it supposed to support only one audio stream or I am doing something wrong?
SKAPiter is offline   Reply With Quote
Old 31st January 2008, 21:45   #156  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
I'm not surprised. I bet that multi audio stream support is limited to AVCHD (BluRay Structure)
Old 31st January 2008, 21:53   #157  |  Link
SKAPiter
SKAPiter's Avatar
I just dowbnloaded 1.2.9 zip but it still says 1.2.6 in the app window title.
Old 31st January 2008, 21:58   #158  |  Link
B4tm4n
Caped Crusader
B4tm4n's Avatar
Some one over at abHDTV.net has posted how to get subtitles working.
http://forum.doom9.org/showthread.ph...03#post1094903
B4tm4n is offline   Reply With Quote
Old 31st January 2008, 22:21   #159  |  Link
SKAPiter
SKAPiter's Avatar
I just created an AVCHD disk via TsRemux 0.0.19 from the above mentioned m2ts file and burned it to DV+RW. The resulted disk is recongnized by PS3 as AVCHD. Video plays fine with all features, i.e. 5 min. chapters, ff/rw but here is NO AUDIO :-) None of the audio stream is present. Bumer. :-(
Old 31st January 2008, 22:53   #160  |  Link
Zow
This sounds like an easy solution to getting subtitles to work in Blu-Ray.
Also, if what the poster says is right: "...My theory is the the author of TSRemux left a small bug in the code, when the code should replace the stream type 91 with 90, it erroneously overwrites the PID 1200 with 0090.", then it should be an easy bug to fix.
But I am trying to get a Blu-Ray ripped to a H.264 MKV, with subtitles, so I'll have to wait, I guess.
Zow is offline   Reply With Quote
tsmuxer
