Old 24th April 2008, 12:45   #1181  |  Link
roman76r
B4tm4n
But the split function has been broken, in version 1.7.x a CLIPINF files was created for every split m2ts file but in 1.8.x theres only 1 CLIPINF file been created
Are your sure? Now I have made a test, all CLIPINF files has been created.
roman76r is offline   Reply With Quote
Old 24th April 2008, 12:50   #1182  |  Link
B4tm4n
Caped Crusader
B4tm4n's Avatar
Originally Posted by roman76r View Post
B4tm4n
I'm only getting 1, I'm going to have to test on another computer.
I'll post when I've doubled checked.
The files aren't created if I aim tsMuxer to create the bluray files direct on to my FAT32 Flash drive or hard drive, but are created if I make the file on my local drive.
Now I've gone and dropped my only spare Hard drive and broke it so can't test a full movie.
Anybody can check version 1.8.2?
Yes the subs are showing now on PS3.
Thanks for your hard work.
One thing there black lines going from the subs off to the right.
The pictures aren't any good but you see what I mean.
B4tm4n is offline   Reply With Quote
Old 24th April 2008, 13:44   #1183  |  Link
roman76r
B4tm4n
Good news! You can adjust black border by means of "addition border" option in GUI.
Old 24th April 2008, 14:05   #1184  |  Link
Jim-Armao
Question:
To get the subtitles playing in PS3 is the creation of an AVCHD dvd mandatory?
Or do the resulting .m2ts files also display the subs when played directly though dlna streaming or usb stick?
Jim-Armao is offline   Reply With Quote
Old 24th April 2008, 14:13   #1185  |  Link
n0mag!c
use 'r'
n0mag!c's Avatar
Originally Posted by Jim-Armao View Post
Question:
Yes, subtitles are displayed only from AVCHD or BDMV.
n0mag!c is offline   Reply With Quote
Old 24th April 2008, 14:16   #1186  |  Link
B4tm4n
Caped Crusader
B4tm4n's Avatar
B4tm4n
I left that at 1 the default value its the black line going off to the right side of the screen I was refering to. Would they dissappear with a higher setting of the black border ?
Question:
AFAIK you can't get subs playing via dnla.
Old 24th April 2008, 14:22   #1187  |  Link
Jim-Armao
And AVCHD is only possible via DVD and not USB / memory stick etc?
I ask because subs work with divx and xsubs through dlna.
In a perfect world they would also work with .m2ts
And not to forget, THANKS to roman76r for tsmuxer!!
Old 24th April 2008, 14:24   #1188  |  Link
B4tm4n
Caped Crusader
B4tm4n's Avatar
@Roman
I downloaded the source for the app that sorts out the black level in SKY HD captures from :
http://www.hdd-player.de/phpBB2/inde...8&topic=2779.0
Heres a mirror for it :http://www.divshare.com/download/4337417-023
Would it be possible to add this to your app ?
Old 24th April 2008, 14:25   #1189  |  Link
roman76r
B4tm4n
Black lines is a bug. I can't take it in supRead. Black lines are visible in supRead or powerDVD?
Also, please send me pgs file with black lines.
Old 24th April 2008, 14:32   #1190  |  Link
B4tm4n
Caped Crusader
B4tm4n's Avatar
B4tm4n
Yes you can see the lines in supread.
http://www.divshare.com/download/4337535-6b2
Old 24th April 2008, 14:37   #1191  |  Link
campari212
@Roman: Any idea on when you'll have time to look at my eyeTV-export?
Thanks
campari
campari212 is offline   Reply With Quote
Old 24th April 2008, 14:42   #1192  |  Link
n0mag!c
use 'r'
n0mag!c's Avatar
Guys here report that AVCHD also plays from USB-flash/hard drives if rename 'BDMV' folder to 'AVCHD' and put it to the root. But also filenames of all files should be changed to short 8.3 format.
I ask because subs work with divx and xsubs through dlna. In a perfect world they would also work with .m2ts
Maybe Sony will add this feature in later firmware of PS3, will see...
Old 24th April 2008, 14:44   #1193  |  Link
B4tm4n
Caped Crusader
B4tm4n's Avatar
I really hope so.
Old 24th April 2008, 14:49   #1194  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Roman
Why subtitles have 1920x952 size instead of 1920x1080?
BTW.My subtitles still do not show up in PS3 when I import SRT directly. I suppose they must be below screen or something like that. Now I'm playing with higher bottom offset... 128 and still nothing...
Atak_Snajpera is online now   Reply With Quote
Old 24th April 2008, 14:50   #1195  |  Link
roman76r
B4tm4n
What font settings (font name, size, border width e.t.c) you used in this example?
Old 24th April 2008, 14:59   #1196  |  Link
B4tm4n
Caped Crusader
B4tm4n's Avatar
B4tm4n
I don't think I changed anything at all from the default.
Old 24th April 2008, 15:07   #1197  |  Link
roman76r
B4tm4n
Very strange. I can't repeat your problem on my PC.
Old 24th April 2008, 15:27   #1198  |  Link
jagaskywalker
You should not rename BDMV to AVCHD but create a AVCHD folder in the HDD or memory stick root and place the BDMV inside !
J
jagaskywalker is offline   Reply With Quote
Old 24th April 2008, 15:30   #1199  |  Link
n0mag!c
use 'r'
n0mag!c's Avatar
Thanks! I'll try soon!
Old 24th April 2008, 15:40   #1200  |  Link
roman76r
B4tm4n
I think what problem with black lines does not appear on my PC because your windows uses more colors for text antialiasing.
Please, try new version:
www.smlabs.net/tsMuxer/tsMuxeR_1.8.3(b).zip
tsmuxer
