Old 18th April 2006, 13:36   #1161  |  Link
duebel13
Originally Posted by Kurtnoise13
Could you provide a such sample ? Thanks...
Just use any .mpg file with sound which you already have.
Open the file in DGIndex, start playing (F5), stop playing after
a couple of seconds (ESC), demux (F4). Close DGIndex.
Now you have the .mpa file in your directory.
BTW, I use lame_enc.dll from Lame v3.97b2 and not the one coming with BeLight. Hope this is not causing the problem.
duebel13 is offline   Reply With Quote
Old 19th April 2006, 17:39   #1162  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
mmh, I just checked my mpg collection and all have an ac3 stream, not mpeg...:-/ So, if someone have a such file to provide...
I don't think so...
/me go back to fix bugs.
Old 20th April 2006, 09:53   #1163  |  Link
Kurtnoise
Kurtnoise's Avatar
ok, finally, I've retrieve some mpg files and...all seems to work fine here. That's why I need a small sample of your file. Thanks again.
Old 21st April 2006, 12:11   #1164  |  Link
Damolee
I'm having problems getting this to work.
Trying to run a VBR Mp3 through it, to basically change frame rate from 23fps upto 25 (pal) using Quality / VBR mode it starts the process but the progress bar doesn't budge and it just says 00:01 time remaining while the time elapsed ticks over. I can't tell whether it's actually doing anything or not.
I tried using the regular way to install it , and also the CoreCodec package ....same problem.
Any ideas?
Damolee is offline   Reply With Quote
Old 21st April 2006, 12:38   #1165  |  Link
Kurtnoise
Kurtnoise's Avatar
What kind of input file did you have ?
Old 21st April 2006, 12:45   #1166  |  Link
Damolee
Right, I see what's going on.
It was trying to encode and save over itself, I couldn't find an option to name the output file... lol
So what I did was rename it using the "View Commandline" option.
Then it output fine.
My input was a VBR MP3, all I am trying to do is change the frame rate of the audio to 25 for a PAL AVI file.
For some reason, using BeSweetGUI to convert it to CBR mode the audio keeps going out of sync on the standalone player, it seems to prefer VBR ....which is strange seeing as CBR is usually prefered.
Old 25th April 2006, 16:52   #1167  |  Link
Kurtnoise
Kurtnoise's Avatar
Originally Posted by dwrbudr
Ok. The bug is 100% reproducable so it is easy to fix. Try this:
- start BeLight.exe
- open c:\temp\1.wav
- menu Edit - View BeSweet command
- you see "C:\Tools\BeLight-0.22_beta\BeSweet.exe" -core( -input "C:\Temp\1\1.wav" -output "C:\Temp\1\1.aac" -logfile "C:\Temp\1\1.log" ) -dimzon( -dllname WA_aacPlus.dll -cbr 32 -mpeg4 -mode 1 ) -ota( -g max )
- click on Copy button
- close the BeSweet command form with X button
- right click in files list
- Clear list
- open c:\2.wav
- HERE you still see the command for 1.wav !
Fixed...
Old 26th April 2006, 08:22   #1168  |  Link
Igor Kharchenko
I made fresh install of BeSweet and BeLight, put enc_aacplus.dll and WA_aac.dll in BeSweet folder, and try test conversion using AAC->HE->CT->CBR2.0@128 preset. I get a message that I need bse_WinampAacPlusV2.dll. Copy/paste command line works fine. May be this check is useless?
Igor Kharchenko is offline   Reply With Quote
Old 26th April 2006, 14:10   #1169  |  Link
Kurtnoise
Kurtnoise's Avatar
Yeah, right. I'll change that. Thanks for the tip.
Old 28th April 2006, 07:31   #1170  |  Link
dwrbudr
Unregistered User
dwrbudr's Avatar
10x for the new version!
Here are some things to fix:
Winamp AAC "Channel mode" isn't remembered, e.g. click on AAC tab, select Channel mode - Mono (for Winamp AAC), then click AC3 tab, then back to AAC - Channel mode is now "Parametric stereo"
It would be nice if you make all comboboxes style csDropDownList, so the user cannot type in them.
my subtitle site
dwrbudr is offline   Reply With Quote
Old 28th April 2006, 09:12   #1171  |  Link
Kurtnoise
Kurtnoise's Avatar
Allright, I was fixing that last night. i'll try to put online a new build today.
btw, the last aac encoder from Nero 7.2.xx doesn't work with GUIs using aacenc32.dll, aac.dll & NeroIPP.dll. If it works for you, this means that the old encoder used to. So, wait for a working solution for the alternative GUIs.
Old 29th April 2006, 03:33   #1172  |  Link
ron spencer
DVD Magistrate
bug? If I choose a path to SoX program never remembers it on next load...can you verify?
ron spencer is offline   Reply With Quote
Old 29th April 2006, 10:40   #1173  |  Link
Kurtnoise
Kurtnoise's Avatar
This part is not finished yet. Same thing also for BeSplit.
Old 29th April 2006, 15:26   #1174  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
The latest daily build still has to old nast bug:
If there are a lot of source files on the list and I press convert button, BeLight will display 100% after view milliseconds and then only convert the first file. All other files get a .log file only...
Old 29th April 2006, 19:22   #1175  |  Link
fight2win
What's in a name dude !
fight2win's Avatar
how to encode ac3 to nero aac, new nero has only aacenc32.dll, no aac.dll!
fight2win is offline   Reply With Quote
Old 29th April 2006, 20:09   #1176  |  Link
Kurtnoise
Kurtnoise's Avatar
A I said previously...
Yes, I'm working on it.
Old 30th April 2006, 00:53   #1177  |  Link
LoRd_MuldeR
Software Developer
Old 30th April 2006, 04:06   #1178  |  Link
Bathrone
Curious Beta Tester
Isnt the recommend lame enc for build 3.97 beta 2?
Bathrone is offline   Reply With Quote
Old 30th April 2006, 11:10   #1179  |  Link
Carpo
Carpo's Avatar
ok now this may have already been addressed - i did search but didnt find a solution (maybe i didnt search too good )
anyway - while using belight as per doom9s guide to converting ac3 to aac i have selected the aac preset and changed a few settings - well one the output had to be 5.1 - now when i play the file it always says that its mono - is this right or have a touched a setting i shouldnt have
Thanks
The Internet: where men are men, women are men, and children are FBI Agents
Carpo is offline   Reply With Quote
Old 30th April 2006, 11:46   #1180  |  Link
Bathrone
Curious Beta Tester
Bugs with trying to transcode ac3 to aac using nero.
"C:\Program Files\BeLight\BeSweet.exe" -core( -input "C:\Encoding\movies T01 3_2ch 448Kbps DELAY 0ms.ac3" -output "C:\Encoding\movies T01 3_2ch 448Kbps DELAY 0ms.mp4" -logfile "C:\Encoding\movies T01 3_2ch 448Kbps DELAY 0ms.log" ) -dimzon( -dllname bse_Nero7WA.dll -6chnew -vbr_extreme -codecquality_high -aacprofile_lc ) -ota( -d 0 )
BeSweet v1.5b31 by DSPguru.
Using azid.dll v1.9 (b922) by Midas (midas@egon.gyaloglo.hu).
Using Shibatch.dll v0.25 by Naoki Shibata & DSPguru (shibatch.sourceforge.net).
Using bse_Nero7WA.dll by dimzon, Build Nov 10 2005, 14:35:28
Logging start : 04/30/06 , 20:45:13.
C:\Program Files\BeLight\BeSweet.exe -core( -input C:\Encoding\movies T01 3_2ch 448Kbps DELAY 0ms.ac3 -output C:\Encoding\movies T01 3_2ch 448Kbps DELAY 0ms.mp4 -logfile C:\Encoding\movies T01 3_2ch 448Kbps DELAY 0ms.log ) -dimzon( -dllname bse_Nero7WA.dll -6chnew -vbr_extreme -codecquality_high -aacprofile_lc ) -ota( -d 0 )
[00:00:00:000] +------- BeSweet -----
[00:00:00:000] | Input : C:\Encoding\movies T01 3_2ch 448Kbps DELAY 0ms.ac3
[00:00:00:000] | Output: C:\Encoding\movies T01 3_2ch 448Kbps DELAY 0ms.mp4
[00:00:00:000] | Floating-Point Process: No
Error 84: error configuring bsn!
Quiting...
[00:00:00:000] Conversion Completed !
Logging ends : 04/30/06 , 20:45:13.
