Old 15th January 2006, 16:55   #1001  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Originally Posted by buzzqw
using belight 0.22 beta 9 plus
Aac.dll -> version 3.0.0.7 (nero 7)
aacenc32.dll -> version 4.2.2.3 (nero 7)
and the same command line i got NO errors
BHH
I made a fresh install of BeLight 0.22 Beta 9 and then jsut copied over the Nero DLLs (exactly the same versions you have). And there IS an error. As said before, the Nero CLI encoder and Nero itself work fine...
Old 15th January 2006, 17:08   #1002  |  Link
Palikrovol
Palikrovol's Avatar
did you also copy the 'NeroIPP.dll' file into besweet directory?
I think it is also needed.
Palikrovol is offline   Reply With Quote
Old 15th January 2006, 17:16   #1003  |  Link
LoRd_MuldeR
Software Developer
sure (v4.2.2.3)
Old 15th January 2006, 17:43   #1004  |  Link
buzzqw
HDConvertToX author
just to note: i DON'T have to copy neroipp.dll
and i have REGISTERED (with nero start smart) the he-aac plugins , plus some other plugins.
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 15th January 2006, 19:14   #1005  |  Link
LoRd_MuldeR
Software Developer
BHH
This way or that way, it refuses to work on my machine
Old 16th January 2006, 10:26   #1006  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Sorry, but it's the same error as before
In this case, this is either an issue with your sn or your input file...So, try via BeSweet directly before to bash BeLight.
Second, check BeLight log to see whether your have all dlls (Options-->View-->Log...to check warnings)...maybe bsn is missing.
Worst thing is: BeLight "thinks" conversion was completed successfully...
here is a build with errors detection...
Old 16th January 2006, 17:21   #1007  |  Link
LoRd_MuldeR
Software Developer
The Log does not show any warnings/errors. It sais all BeSweet DLLs found plus it recogniszes aac.dll and aacenc32.dll. So missing files should not be the problem...
My input files is PCM Wave-Audio (Stereo, 44KHz), which I converted before without problems. This cannot be the problem.
At least BeLight now says that the convertion has faild
But I got no idea what's wrong. As I already told you, Nero itself or Nero WaveEditor convert without problem. Same for the CLI front-end (aacenc32.exe). Only BeLight / BeSweet refuse to work...
Really strange. Any ideas?
Old 16th January 2006, 18:42   #1008  |  Link
namchik
Now Belight always says "Encoding failed..." even if everything went ok...
namchik is offline   Reply With Quote
Old 16th January 2006, 19:26   #1009  |  Link
Kurtnoise
Kurtnoise's Avatar
Sorry...I had uploaded a wrong version. Test this one...
Old 16th January 2006, 20:03   #1010  |  Link
ron spencer
DVD Magistrate
this is beta9 build....should we start a beta 9 thread? just a suggestion
ron spencer is offline   Reply With Quote
Old 17th January 2006, 12:26   #1011  |  Link
Kurtnoise
Kurtnoise's Avatar
Is it really necessary ? Could be more interesting to open a new thread when 0.22 will be released...
I know that I can't edit the title thread but...
Old 17th January 2006, 15:29   #1012  |  Link
ron spencer
DVD Magistrate
not necessary for me...just for others who have not followed the thread...you have an idea on official release of 0.22? Sounds promising
Old 17th January 2006, 20:10   #1013  |  Link
LoRd_MuldeR
Software Developer
1) With the latest build BeLight again says "Convertion completed" although this is not true.
2) I did some testing with Dependency Walker an I found two problems. First one are some missing Exports in KERNEL32.DLL:
DllMain(0x00370000, DLL_PROCESS_ATTACH, 0x00000000) in "BSE_NERO7WA.DLL" called.
GetProcAddress(0x77E40000 [KERNEL32.DLL], "InitializeCriticalSectionAndSpinCount") called from "BSE_NERO7WA.DLL" at address 0x00374F29 and returned 0x77E5DE5E.
GetProcAddress(0x77E40000 [KERNEL32.DLL], "FlsAlloc") called from "BSE_NERO7WA.DLL" at address 0x0037239F and returned NULL. Error: Die angegebene Prozedur wurde nicht gefunden (127).
GetProcAddress(0x77E40000 [KERNEL32.DLL], "FlsGetValue") called from "BSE_NERO7WA.DLL" at address 0x003723AC and returned NULL. Error: Die angegebene Prozedur wurde nicht gefunden (127).
GetProcAddress(0x77E40000 [KERNEL32.DLL], "FlsSetValue") called from "BSE_NERO7WA.DLL" at address 0x003723B9 and returned NULL. Error: Die angegebene Prozedur wurde nicht gefunden (127).
GetProcAddress(0x77E40000 [KERNEL32.DLL], "FlsFree") called from "BSE_NERO7WA.DLL" at address 0x003723C6 and returned NULL. Error: Die angegebene Prozedur wurde nicht gefunden (127).
Furthermore I found out that AAC.DLL has an import from MFC71.DLL, which was missing. So I copied the MFC71.DLL over from Nero folder and now it seems to work. Finally !!!
Don't know what's the problem with KERNEL32.DLL, but it doesn't seem to do any harm. I now think BeLight shuld check for MFC71.DLL, because this file IS required!
Old 17th January 2006, 20:39   #1014  |  Link
Kurtnoise
Kurtnoise's Avatar
not BeLight but probably some others dlls for BeSweet.
BeLight is developped in Delphi. So, there aren't mfc dependencies...
Old 17th January 2006, 20:41   #1015  |  Link
Kurtnoise
Kurtnoise's Avatar
fortunately no...
All in all, the 1st post in this thread has some explanations to start well I think...
Old 17th January 2006, 20:47   #1016  |  Link
LoRd_MuldeR
Software Developer
It is the AAC.DLL (this means the Nero encoder) that requires MFC71.DLL
So there should be a warning in BeLight, since MFC71.DLL has to be in the folder or Nero encoder won't work!
Old 17th January 2006, 20:53   #1017  |  Link
Kurtnoise
Kurtnoise's Avatar
Did you check Common Files/Ahead folder to see if this dll is there ?
Old 17th January 2006, 21:22   #1018  |  Link
LoRd_MuldeR
Software Developer
MFC71.DLL is in the Common Files\Ahead\Lib folder as well as in Nero\Core
But it has to be copied to the BeSweet folder. Otherwise I get this error I had all the time (faild configure bsn). When used in BeSweet AAC.DLL seems *not* to be able to load MFC71.DLL from the Common Files\Ahead\Lib. With MFC71.DLL in BeSweet folder it works
Old 18th January 2006, 22:33   #1019  |  Link
tedgo
@LoRd_MuldeR
Thank you!
I got exactly the same error, but copying the MFC71.DLL from Common Files\Ahead\Lib to BeLight-folder solved the problem.
Would be great if BeLight could automatically check for MFC71.DLL, because it really seems to be needed.
EDIT:
MFC71.DLL must not be copied to the BeLight-folder.
It also works when copied to WINDOWS\system32-folder.
It may be the reason for a working Nero-plugin in BeLight on some machines (when MFC71.DLL is already there).
tedgo is offline   Reply With Quote
Old 18th January 2006, 23:45   #1020  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by tedgo
@LoRd_MuldeR
Thank you!
EDIT:
Okay, but I don't think it's a good thing if BeLight depends on some DLLs in the Windows dir. It's much better to have a complete installation with all required DLLs in the install-folder. So I believe BeLight must check for MFC71.DLL. There's no other way...
