Old 11th January 2006, 19:01   #981  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
It seems that the new winamp's dll doesn't support multichannel streams anymore...
Old 11th January 2006, 23:07   #982  |  Link
setarip_old
setarip_old's Avatar
@Kurtnoise13
BeSweet doesn't need to extract audio streams from AVI.
Please clarify, as I don't understand your reply. Version 0.21 of BeLight (in conjunction with BeSweet) allows for extracting the audiostream from .AVIs, while v.0.22beta8 does not.
I was just asking if this ability will be re-instated, to which you've answered, "But yes, It's planned..."
setarip_old is offline   Reply With Quote
Old 12th January 2006, 08:14   #983  |  Link
Kurtnoise
Kurtnoise's Avatar
Demuxing means that we extract each streams from the container. However, BeSweet doesn't extract each streams because with this own plugin it is able to find the first audio stream directly.
Re-installing is not the appropriate term because 0.21 and 0.22 branches are completely different in the code. Especially running process. So, I try to make my best. Stay tuned.
Old 12th January 2006, 08:20   #984  |  Link
setarip_old
Thanks for the clarification ;>}
Old 12th January 2006, 20:28   #985  |  Link
Kurtnoise
Kurtnoise's Avatar
hehehe guys....A new build is up. I spent a lot of time to include lst & mux files. With my tests all seems to be ok. So, don't forget VOBInput.dll if you want to test it.
Keep in mind that some tunings are needed. This is not finished.
There are also some enhancements concerning eta.
Enjoy !!!
Old 12th January 2006, 20:29   #986  |  Link
Kurtnoise
Kurtnoise's Avatar
Originally Posted by neo squidward
This GUI is a lot easier to understand than the original thanks for making it. I think a useful feature would be to have it recognize that if the input is not a wav then it should convert frame rate using ota instead of soundtouch.
Done...Check the link above.
Old 13th January 2006, 18:18   #987  |  Link
Kurtnoise
Kurtnoise's Avatar
BeLight 0.22 beta 9 has been released
As promise, a new beta is out.
changelog:
-Add LST & MUX files support.
-Add Parametric Stereo for AAC Presets.
-Add Nero dlls detection. If they are available then BeLight copies them automatically to his own folder.
-Add a function to find Nero dlls version. If dlls belong to Nero 7 then ND PS-AAC Presets are enabled otherwise this is disabled.
-Add a Manual Gain option.
-Add "Go to" functions in Options Menu.
-Add Japanese, Greek, German, Nederlands and Italian languages.
-Rewrite & Improve BeLight ETA section.
-Update some Presets.
-Update some BeSweet libraries.
-Update Command Line Part.
-Fix some bugs.
http://corecodec.org/frs/?group_id=4...se_id=245#r245
Roadmap for the next releases:
  • Add AVI & VOB files support.
  • Finish properly the Job List.
  • Add upmix and BeSplit functions.
  • Add Open with...in the shell.
Old 13th January 2006, 18:25   #988  |  Link
sillKotscha
what's this for?
sillKotscha's Avatar
thank you for the new build... nice features added
and before someone asks (as I did )
Originally Posted by Kurtnoise13
- There are 3 packages now at CoreCodec.org (Normal, Lancer and P4). The main difference between these 3 builds comes from libvorbis. The Normal version corresponds to normal libvorbis.dll, Lancer bundle is optimized for speed without loose quality and P4 version refers to libvorbis.dll optimized for Pentium4 core. In addition, all versions use AoTuv enhancements.
sillKotscha is offline   Reply With Quote
Old 13th January 2006, 18:31   #989  |  Link
Kurtnoise
Kurtnoise's Avatar
and this is also mentioned in my 1st post in this thread...
Old 13th January 2006, 19:34   #990  |  Link
Skelsgard
foobaring my ass off
Skelsgard's Avatar
what´s the difference between the .exe´s and the .zip?
"Damn, respect my authoritay!!" - E. Cartman
Skelsgard is offline   Reply With Quote
Old 13th January 2006, 20:33   #991  |  Link
Kurtnoise
Kurtnoise's Avatar
.zip contains only BeLight whereas .exe files are installers with BeLight+BeSweet+some dlls.
Old 13th January 2006, 21:07   #992  |  Link
Skelsgard
Skelsgard's Avatar
that´s what I thought. I was just about to test the new release.
With .mux enabled ( )!!!
Old 13th January 2006, 23:05   #993  |  Link
deets
love the new beta, made it nice and simple to install and work on my other machines. many thanks
deets is offline   Reply With Quote
Old 14th January 2006, 00:27   #994  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Nero 7 Encoder still doesn't work with Beta-9
And I got an A/V error on quitting BeLight
Old 14th January 2006, 00:43   #995  |  Link
ron spencer
DVD Magistrate
thanks
ron spencer is offline   Reply With Quote
Old 14th January 2006, 08:19   #996  |  Link
Kurtnoise
Kurtnoise's Avatar
blame yourself to not have given more details...
Is it too complicated to post a logfile at least ?
Old 14th January 2006, 08:25   #997  |  Link
mazzo85
this version work with nero's 7 DLL??
mazzo85 is offline   Reply With Quote
Old 14th January 2006, 10:45   #998  |  Link
Kurtnoise
Kurtnoise's Avatar
of course...
Old 14th January 2006, 17:35   #999  |  Link
LoRd_MuldeR
Software Developer
Sorry, but it's the same error as before:
BeSweet v1.5b31 by DSPguru.
Using hip.dll v1.19 by Myers Carpenter <myers@users.sf.net>
Using Shibatch.dll v0.25 by Naoki Shibata & DSPguru (shibatch.sourceforge.net).
Using bse_Nero7WA.dll by dimzon, Build Nov 10 2005, 14:35:28
Logging start : 01/14/06 , 17:33:46.
BeSweet.exe -core( -input C:\Temp\Ansicht X - BassBox.wav -output C:\Temp\Ansicht X - BassBox.mp4 -logfile C:\Temp\Ansicht X - BassBox.log ) -azid( -s stereo -L -3db ) -dimzon( -dllname bse_Nero7WA.dll -2ch -vbr_normal -codecquality_high -aacprofile_lc -exportaac ) -ota( -g max )
[00:00:00:000] +------- BeSweet -----
[00:00:00:000] |  Input : C:\Temp\Ansicht X - BassBox.wav
[00:00:00:000] |  Output: C:\Temp\Ansicht X - BassBox.mp4
[00:00:00:000] |  Floating-Point Process: No
Error 84: error configuring bsn!
Quiting...
[00:00:00:000] Conversion Completed !
Logging ends : 01/14/06 , 17:33:46.
Worst thing is: BeLight "thinks" conversion was completed successfully...
BTW: The commandline front-end for the Nero Encoder works without any probs.
Old 14th January 2006, 20:19   #1000  |  Link
buzzqw
HDConvertToX author
using belight 0.22 beta 9 plus
Aac.dll -> version 3.0.0.7 (nero 7)
aacenc32.dll -> version 4.2.2.3 (nero 7)
and the same command line i got NO errors
D:\Programmi\Audio\BeLight>BeSweet.exe -core( -input aaa.ac3 -output c:\BassBox.mp4 ) -azid( -s stereo -L -3db ) -dimzon( -dllname bse_Nero7WA.dll -2ch -vbr_normal -codecquality_high -aacprofile_lc -exportaac ) -ota( -g max )
Using azid.dll v1.9 (b922) by Midas  (midas@egon.gyaloglo.hu).
[00:00:00:000] |  Input : aaa.ac3
[00:00:00:000] |  Output: c:\BassBox.mp4
[00:00:00:000] |  Overall Track Gain: 8.913dB
[00:00:00:000] +-------- AZID -------
[00:00:00:000] |  Input Channels Mode: 2/0, Bitrate: 192kbps
[00:00:00:000] |  Output Stereo mode: Stereo
[00:00:00:000] |  Total Gain: 0.000dB, Compression:  None
[00:00:00:000] |  LFE levels: To LR -3.0dB, To LFE 0.0dB
[00:00:00:000] |  Center   mix level: BSI
[00:00:00:000] |  Surround mix level: BSI
[00:00:00:000] |  Dialog normalization: No
[00:00:00:000] |  Rear channels filtering: No
[00:00:00:000] |  Source Sample-Rate: 48.0KHz
[00:00:00:000] +---------------------
[00:00:21:376] Conversion Completed !
[00:00:04:000] <-- Transcoding Duration
Visit DSPguru's Homepage at :
                                http://DSPguru.doom9.net/
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
