Old 6th February 2009, 18:08   #961  |  Link
ultratoto14
@neuron
http://neuron2.net/dgavcdecnv/DGAVCDecodeNVManual.html
In the samples, there is
AVCSource("project.dga", deinterlace=true)
instead of
AVCSource("project.dga", deinterlace=1)
ultratoto14 is offline
Old 6th February 2009, 18:22   #962  |  Link
Fixed. Thank you for pointing it out.
Guest is offline
Old 7th February 2009, 03:03   #963  |  Link
CUVID Server/CUVID Client 1.0.4
I've updated the CUVID server and client to support MPEG1 and MPEG2 video.
http://neuron2.net/dgavcdecnv/dgavcdecnv.html
You can probably guess what's coming next.
After that my plan is to combine all three variants into one. Then I will add "output trimmed TS" as well as multiple ranges.
Guest is offline
Old 7th February 2009, 06:47   #964  |  Link
woah!
seeing only source code in the zip file for server version?
woah! is offline
Old 7th February 2009, 07:02   #965  |  Link
I added the EXE so please re-download it.
Guest is offline
Old 7th February 2009, 19:05   #966  |  Link
rica
Congrats
rica is offline
Old 7th February 2009, 23:25   #967  |  Link
Sagekilla
x264aholic
Thanks for all your work neuron2! Looking forward to become a supporter as soon as I get out of my poor-college-student situation
Sagekilla is offline
Old 8th February 2009, 16:44   #968  |  Link
laserfan
Aging Video Hobbyist
I've updated the CUVID server and client to support MPEG1 and MPEG2 video... You can probably guess what's coming next.
I'm surprised there hasn't been more reaction to this! Although I have (finally) learned when-and-how to invoke DGIndex.exe and DGAVCIndexNV.exe and DGVC1IndexNV.exe and CUVIDServer.exe and which .d2v or .dgv or .dga goes-with-which it will be great if any UI streamlining can be done, so THANKS DG IN ADVANCE! Sign me up for any alphas-or-betas!
laserfan is offline
Old 9th February 2009, 04:48   #969  |  Link
xopowo
Is there a memory leak in CUVIDServer 1.0.4? I'm using Win 7 64-bit and encoding with x264.exe and the memory used by the server has grown from 262mb to now 690mb in 19 minutes. I only have 4gb of memory. Is 64gb recommended
avs is just "1.dga", deinterlace=1)
not doing anything fancy ... decimating after that, no cropping or resize
I was looking at x264.exe memory usage ... cuvidserver passed it ... now, 22 minutes into the encode, it's at 867mb!
xopowo is offline
Old 9th February 2009, 05:40   #970  |  Link
Funny you should ask. I just reported that to Nvidia today. I'll keep you informed.
Can I have your full script please?
I thought it only happens with random access. Decimation could force that.
Guest is offline
Old 10th February 2009, 03:34   #971  |  Link
The memory leak has been fixed. All NV tools have been updated with the fixed nvcuvid.dll, so redownload any of them to get the fixed DLL.
@xopowo
Please advise if this fixes your issue.
Guest is offline
Old 11th February 2009, 21:12   #972  |  Link
Deinorius
Najarenthur
Deinorius's Avatar
@neuron2
The Core Team just updated CoreAVC to 1.9.0.0 with CUDA-Support. Would be interesting, if it's more efficient than VP2-Part.
I never read it but is it possible for DGAVCIndexNV to index LV 5.0/5.1 Streams?
Deinorius is offline
Old 11th February 2009, 22:01   #973  |  Link
Rectal Prolapse
I am pretty sure CoreAVC CUDA still requires a videocard with VP2 support. Someone I know has a G80 NVIDIA card (8800GTS 640) and CUDA is not selectable in CoreAVC 1.9 - so that would support that theory.
Rectal Prolapse is offline
Old 11th February 2009, 22:04   #974  |  Link
~bT~
н∂-αиαтι
^ i believe u are correct.. vp2 or higher is needed for cuda.
~bT~ is offline
Old 11th February 2009, 22:09   #975  |  Link
Deinorius
Najarenthur
Deinorius's Avatar
Damn, I hoped it could be more. So it's not really reasonable. The only sense it does for me to decode non-DXVA compatible Streams, but that's it. At least other DXVA Video decoder can use ATI UVD too.
Old 12th February 2009, 00:49   #976  |  Link
Yes, no problem.
Guest is offline
Old 12th February 2009, 01:37   #977  |  Link
Audionut
From the CoreAVC thread.
Originally Posted by squid_80 View Post
I think it would be better if DGAVCIndexNV didn't rely on nvcuvid.dll being in system32; the program location is stored in the .dga file so why can't DGAVCDecodeNV load nvcuvid.dll from there?
I do not have a copy of nvcuvid.dll anywhere on my comp other than dg***decodenv folders.
The closet I have is nvcuda.dll
edit: and everything works fine that way too.
http://www.7-zip.org/
Audionut is offline
Old 12th February 2009, 03:42   #978  |  Link
Both DGXXXIndexNV.exe and CUVIDServer.exe must be able to find nvcuvid.dll. DGXXXDecodeNV.dll does not need it and so is irrelevant. Thus, the two EXEs must see the DLL via the Windows DLL search path:
http://msdn.microsoft.com/en-us/libr...18(VS.80).aspx
If you have those two EXE's in the same directory with nvcuvid.dll, everything will be fine.
It is reasonable to have the CUVID Server in its own directory, as well as to have the DG tool variants in their own directories. That is why I recommended to put nvcuvid.dll in system32, so that multiple copies of it are not required.
I will give some thought to a solution that doesn't require multiple copies and doesn't overwrite the version installed by the Nvidia driver install. Ideas are welcome.
Guest is offline
Old 12th February 2009, 10:38   #979  |  Link
~bT~
н∂-αиαтι
i installed this driver: 181.20_geforce_winvista_32bit_international_whql
when i moved nvcuvid.dll to system32, it never overwrote anything..
~bT~ is offline
Old 12th February 2009, 10:57   #980  |  Link
squid_80
All nvidia driver versions after 181.20 should include nvcuvid.dll.
squid_80 is offline
