Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 7th September 2009, 15:46   #1  |  Link
invisible
invisible's Avatar
Can mplayer playback blu-ray ?
For mplayer, I use vdpau to playback HD video so right now mplayer is all I can use for it. I'm thinking about a BDR drive to playback blu-ray, but can mplayer playback blu-ray like it does dvd? I hear stuff about ripping to a decrypted image, but this is no good. So mplayer can't use the decrypt library and playback blu-ray directly? I'll have to forget about getting a drive if so.
invisible is offline   Reply With Quote
Old 7th September 2009, 15:52   #2  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
no, but today a guy came on mplayer-dev mailing list and he's currently working on a patch for it to add native BD support to mplayer so it'll be able (hopefully - somewhere in the future) to play BD discs just like it does now for DVDs. He's also working on AACS and in the future BD+ decryption. There's on going discussion on how to add this patch - built-in into mplayer or a separate library. There is libbluray project but it's been abandoned (though the guy on the mplayer list said someone picked it up) and is also coded in C++ (lolwut?) which could be problematic for mplayer as generally the devs are not very fond of C++ code in mplayer, though it does link to some
Old 7th September 2009, 19:42   #3  |  Link
pynux
i have a method for read bluray
i use svn version of mplayer compil with vdpau
and i install dumphd
and i use this command :
./dumphd.sh --infile:BDMV/STREAM/000054.m2ts /media/cdrom | mplayer -cache 8192 -lavdopts threads=4 -vo vdpau -vc ffh264vdpau -
(change 000054.m2ts by the right file)
it's work perfectly for me (for mkbv1->v10)
pynux is offline   Reply With Quote
Old 8th September 2009, 04:56   #4  |  Link
invisible
invisible's Avatar
That's very interesting. Does anyone else have experiences with that technique? I'm wondering if there's any caveats. Subs, audio, cpu use, smoothness? And what's BD+ and does dumphd handle it? btw, thanks for posting that.
Old 8th September 2009, 09:34   #5  |  Link
Selur
Selur's Avatar
Native BluRay Support in MPlayer would be sooo nice
Old 8th September 2009, 10:37   #6  |  Link
Tariella
I wrote a little guide on bluray playback using dumphd and mplayer.
It is written to work for my linux distro (gentoo) but it should work for all others too. You can find it here.
Please notice that depending on your country it might not be legal to bypass the copy protection.
Tariella is offline   Reply With Quote
Old 15th September 2009, 14:29   #7  |  Link
cRTrn13
cRTrn13's Avatar
I'm that guy working on native support for bluray in mplayer. A patch has already been submitted. It works (for AACS only) - just pull it off the net if you want to try it out. But it's v early days so expect issues.
We're currently discussing if there are better ways to go about the whole bluray (aacs/bd+) thing and there is something in the works by some other people so stay tuned...
cRTrn13 is offline   Reply With Quote
Old 20th September 2009, 12:07   #8  |  Link
XYZ123
I'm using mplayer with a little patch and a library for bluray playback on my HTPC.
You just nedd to install the library and apply the patch to latest mplayer source.
Then you can playback blurays with
mplayer bluray://playlist:chapter//mountPath
playlist ans chapters are optional parameters.
e.g.: mplayer bluray:///media/cdrom0
more informations are in the readme file.
Supports AACS until mkb 10, (backwards and forwards) seeking and movies, which are splitted over more than one file.
Needs openssl 0.9.8 to be installed!
If you have any questions just ask.
XYZ123 is offline   Reply With Quote
Old 20th September 2009, 15:39   #9  |  Link
microchip8
microchip8's Avatar
@ XYZ123
why don't you post your patch to mplayer-dev mailing list?
Old 20th September 2009, 16:06   #10  |  Link
XYZ123
It is not just a patch, but also a library and before I make it more public and post source code it needs to be tested a little bit more.
(it is only tested with 2 blurays, I do not have more)
Old 20th September 2009, 16:18   #11  |  Link
microchip8
microchip8's Avatar
Well, you can post it on the list and get together with the other guys who are working on native BD support for MPlayer. He still has questions and I'm sure both of you can benefit from this collaboration and in the end all will benefit too when finally BD support is added to MPlayer
Further, devs on the list will also comment on your code and test it, as they have done so with the code of the dev working on BD support for MPlayer
Old 21st September 2009, 04:50   #12  |  Link
cRTrn13
cRTrn13's Avatar
I'm that other dev and i'm definately interested in your patch (and more so in your library...). There are a number of library projects going on (some behind the scenes) - maybe all could benefit from your code (you should definately release as soon as possible). There is no point in having different ppl working on the same thing in different directions...
Old 21st September 2009, 12:21   #13  |  Link
teox99
i'm interested in your project too.
i can make some tests and reports for a lot of BD
please let me know if you need help on devel or others.
teox99 is offline   Reply With Quote
Old 21st September 2009, 15:54   #14  |  Link
XYZ123
@teox99
Would be nice, if you test it on some blurays and report errors and bugs.
Old 21st September 2009, 19:02   #15  |  Link
teox99
i followed the instruction in Readme file to build libbluray
i patched svn mplayer
but this is the output while i try to open a BD
user[~]$ mplayer bluray:///media/43501845_VOLUME_ID
MPlayer SVN-r29694-4.3.3 (C) 2000-2009 MPlayer Team
Playing bluray:///media/43501845_VOLUME_ID.
No stream found to handle url bluray:///media/43501845_VOLUME_ID
Exiting... (End of file)
Old 21st September 2009, 19:31   #16  |  Link
XYZ123
Are you sure the patch is applied correctly to mplayer?
Can you look in mplayers configure.log, if libbluray is enabled.
Old 21st September 2009, 22:40   #17  |  Link
teox99
user[mplayer]$ patch -p0 -i bluray_support.diff
(Stripping trailing CRs from patch.)
patching file stream/stream_bluray.c
patching file stream/stream.c
patching file stream/stream.h
patching file Makefile
patching file configure
Hunk #2 succeeded at 636 (offset 2 lines).
Hunk #4 succeeded at 7659 (offset 38 lines).
Hunk #6 succeeded at 8696 (offset 38 lines).
./configure:
Checking for libbluray ... yes
while mplayer make ends with error:
/usr/local/lib/libbluray.so: undefined reference to `BN_bn2bin@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EC_KEY_get0_group@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EC_GROUP_free@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EC_POINT_point2bn@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `BN_set_word@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `AES_cbc_encrypt@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `AES_set_decrypt_key@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `AES_decrypt@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `ECDSA_SIG_free@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `BN_free@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EVP_MD_CTX_init@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `BN_bin2bn@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `BN_CTX_free@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `AES_set_encrypt_key@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `BN_dec2bn@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EVP_DigestUpdate@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `ECDSA_do_sign@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EC_KEY_new@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `BN_new@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EC_POINT_set_affine_coordinates_GF2m@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EC_KEY_free@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EVP_sha1@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `ECDSA_do_verify@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EC_KEY_set_group@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EC_GROUP_set_generator@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EVP_ecdsa@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EC_POINT_set_affine_coordinates_GFp@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EC_KEY_set_private_key@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `BN_clear_free@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EC_POINT_mul@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EC_GROUP_new_curve_GFp@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EVP_DigestFinal_ex@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EVP_DigestInit@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EC_KEY_set_public_key@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `ERR_put_error@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `BN_CTX_new@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EC_POINT_new@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `EC_POINT_free@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `AES_ecb_encrypt@OPENSSL_0.9.8'
/usr/local/lib/libbluray.so: undefined reference to `ECDSA_SIG_new@OPENSSL_0.9.8'
collect2: ld returned 1 exit status
make: *** [mencoder] Error 1
Old 22nd September 2009, 10:26   #18  |  Link
cRTrn13
cRTrn13's Avatar
Openssl needs to be linked in with -lcrypto
Old 23rd September 2009, 14:43   #19  |  Link
TomZ
It doesn't compile. I think (but am not sure) it's because my distro is x86_64.
root@vdrbox:/usr/local/src/mplayer# uname -a
Linux vdrbox 2.6.24-22-generic #1 SMP Mon Nov 24 19:35:06 UTC 2008 x86_64 GNU/Linux
root@vdrbox:/usr/local/src/mplayer# grep bluray configure.log
/usr/bin/ld: skipping incompatible /usr/local/lib/libbluray.so when searching
/usr/bin/ld: cannot find -lbluray
root@vdrbox:/usr/local/src/mplayer# make
cc -Wundef -Wdisabled-optimization -Wno-pointer-sign -Wdeclaration-after-statement -std=gnu99 -Wall -Wno-switch -Wpointer-arith
-Wredundant-decls -O4 -march=native -mtune=native -pipe -ffast-math -fomit-frame-pointer -D_LARGEFILE_SOURCE
-D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE -Ilibdvdread4 -I.  -D_REENTRANT -I/usr/include/  -I/usr/include/freetype2 -I/usr/local/include
  -c -o stream/stream_bluray.o stream/stream_bluray.c
stream/stream_bluray.c: In function 'open_f':
stream/stream_bluray.c:92: warning: implicit declaration of function 'isdigit'
stream/stream_bluray.c:93: warning: implicit declaration of function 'atoi'
stream/stream_bluray.c: At top level:
stream/stream_bluray.c:178: error: redefinition of 'struct stream_priv_s'
stream/stream_bluray.c:180: error: redefinition of 'stream_priv_dflts'
stream/stream_bluray.c:24: error: previous definition of 'stream_priv_dflts' was here
stream/stream_bluray.c:186: error: redefinition of 'stream_opts_fields'
stream/stream_bluray.c:30: error: previous definition of 'stream_opts_fields' was here
stream/stream_bluray.c:190: error: redefinition of 'stream_opts'
stream/stream_bluray.c:34: error: previous definition of 'stream_opts' was here
stream/stream_bluray.c:197: error: redefinition of 'fill_buffer'
stream/stream_bluray.c:41: error: previous definition of 'fill_buffer' was here
stream/stream_bluray.c:202: error: redefinition of 'seek'
stream/stream_bluray.c:46: error: previous definition of 'seek' was here
stream/stream_bluray.c:209: error: redefinition of 'control'
stream/stream_bluray.c:53: error: previous definition of 'control' was here
stream/stream_bluray.c:218: error: redefinition of 'open_f'
stream/stream_bluray.c:62: error: previous definition of 'open_f' was here
stream/stream_bluray.c:302: error: redefinition of 'stream_info_bluray'
stream/stream_bluray.c:146: error: previous definition of 'stream_info_bluray' was here
stream/stream_bluray.c:334: error: redefinition of 'struct stream_priv_s'
stream/stream_bluray.c:336: error: redefinition of 'stream_priv_dflts'
stream/stream_bluray.c:180: error: previous definition of 'stream_priv_dflts' was here
stream/stream_bluray.c:342: error: redefinition of 'stream_opts_fields'
stream/stream_bluray.c:186: error: previous definition of 'stream_opts_fields' was here
stream/stream_bluray.c:346: error: redefinition of 'stream_opts'
stream/stream_bluray.c:190: error: previous definition of 'stream_opts' was here
stream/stream_bluray.c:353: error: redefinition of 'fill_buffer'
stream/stream_bluray.c:197: error: previous definition of 'fill_buffer' was here
stream/stream_bluray.c:358: error: redefinition of 'seek'
stream/stream_bluray.c:202: error: previous definition of 'seek' was here
stream/stream_bluray.c:365: error: redefinition of 'control'
stream/stream_bluray.c:209: error: previous definition of 'control' was here
stream/stream_bluray.c:374: error: redefinition of 'open_f'
stream/stream_bluray.c:218: error: previous definition of 'open_f' was here
stream/stream_bluray.c:458: error: redefinition of 'stream_info_bluray'
stream/stream_bluray.c:490: error: redefinition of 'struct stream_priv_s'
stream/stream_bluray.c:492: error: redefinition of 'stream_priv_dflts'
stream/stream_bluray.c:336: error: previous definition of 'stream_priv_dflts' was here
stream/stream_bluray.c:498: error: redefinition of 'stream_opts_fields'
stream/stream_bluray.c:342: error: previous definition of 'stream_opts_fields' was here
stream/stream_bluray.c:502: error: redefinition of 'stream_opts'
stream/stream_bluray.c:346: error: previous definition of 'stream_opts' was here
stream/stream_bluray.c:509: error: redefinition of 'fill_buffer'
stream/stream_bluray.c:353: error: previous definition of 'fill_buffer' was here
stream/stream_bluray.c:514: error: redefinition of 'seek'
stream/stream_bluray.c:358: error: previous definition of 'seek' was here
stream/stream_bluray.c:521: error: redefinition of 'control'
stream/stream_bluray.c:365: error: previous definition of 'control' was here
stream/stream_bluray.c:530: error: redefinition of 'open_f'
stream/stream_bluray.c:374: error: previous definition of 'open_f' was here
stream/stream_bluray.c:614: error: redefinition of 'stream_info_bluray'
make: *** [stream/stream_bluray.o] Erreur 1
make: *** Attente des tâches non terminées....
TomZ is offline   Reply With Quote
Old 24th September 2009, 17:35   #20  |  Link
XYZ123
@TomZ
Library only works on x86_32, but i will post sourcecode soon.(try to get it ready over weekend)
Then you can compile your libbrary for x86_64.
