Old 21st April 2012, 04:04   #1  |  Link
lansing
Will there be quality loss for YV12-> RGB32 -> YV12 colorspace conversion?
if there is, will it be visible or just some mathematical rounding difference
Old 21st April 2012, 15:51   #2  |  Link
poisondeathray
Yes, visibile quality loss
Whether or not you see it depends on many factors including the viewer and the type of content
Deterioration is more visible on things like graphics (like titles), anime , or content that has clear crisp color borders to begin with - there will be blurring
Old 21st April 2012, 16:12   #3  |  Link
sneaker_ger
He's doing YV12-> RGB32 -> YV12, not RGB32 -> YV12 -> RGB32.
Old 21st April 2012, 16:53   #4  |  Link
poisondeathray
Yes, there is still loss
Have you ever tried redoing a DVD menu or titles in an RGB program like photoshop, AE, video editors, ... etc? . It deteriorates noticably, edges becomes blurry, even before using lossy compression. It's due to color model (colorspace) conversion - the color information is upscaled then downscaled.
Other types of content, like fast moving live action, you typically won't notice unless you zoom in and go frame by frame
Old 21st April 2012, 16:59   #5  |  Link
sneaker_ger
There may be rounding errors in the color conversions, but the chroma up- and downscaling can be lossless depending on the algorithm. If I use pointresize(), it's lossless. So it does not have to result in any blurriness.
Old 21st April 2012, 17:10   #6  |  Link
poisondeathray
Are you using ConvertToRGB(matrix="Rec601", interlaced=false, chromaresample="point") , (and back to YV12 using same thing) ?
or using some other chroma resampling method?
If you have time, here is a test video from a DVD menu for you . (The goal was to redo the text animating on, but the reason is not important). It's really an almost worst case scenario, because of thin red text.
Using "normal" ConvertToRGB.ConvertToYV12 routine (and then ConvertToRGB for the screenshot) . It's similar result in other programs which use slightly different chroma sampling methods
Comparisons:
Original YV12 (and RGB for screenshot)
http://i40.tinypic.com/1zofcjp.png
YV12=>RGB=>YV12 (and RGB for screenshot)
http://i40.tinypic.com/348ivbo.png
original .m2v
http://www.mediafire.com/?52xp6d7p5881fvo
Old 21st April 2012, 17:16   #7  |  Link
sneaker_ger
He didn't mention AviSynth or any specific algorithm.
Old 21st April 2012, 17:17   #8  |  Link
poisondeathray
But you claimed it could be done without blurriness, so I'm interested in the how to do it (with any program)?
Old 21st April 2012, 17:23   #9  |  Link
sneaker_ger
Untested:
ConvertToYV12(chromaresample="point")
ConvertToRGB32(chromaresample="point")
Old 21st April 2012, 17:32   #10  |  Link
poisondeathray
Untested:
Well I did test these before (and the other sampling methods), and for a YV12 source it should be:
(and back to RGB , for consistency of the screenshots, I used same default ConvertToRGB() for the screenshot, which uses Bicubic in avisynth 2.6)
http://i41.tinypic.com/15dtlcz.png
Still some blurring - and introduces aliasing
Old 21st April 2012, 17:52   #11  |  Link
sneaker_ger
I don't know where that error comes from. If you upscale using PointResize by factor 2 and downscale by factor 2 again, you get the same result. Either chromaresample="point" does not do what I think it does, or it has something to do with the MPEG-2-chroma-placement. Will try to make a test to reproduce the issue myself, but I stand by my original statement that this is algorithm dependent and it is possible to do it without additional blurriness, but not without color skewing (putting some edge cases aside).
Old 21st April 2012, 17:57   #12  |  Link
poisondeathray
There was some discusion here about whether or not "PointResize" in avisynth was true nearest neighbor
http://forum.doom9.org/showthread.php?p=1569907
On a practical level, this loss occurs, even in other programs that use "nearest neighbor" - so how do it without bluriness or other detrimental effets like aliased edges in any program???
You can use the YV12 mpeg2 clip provided above in the mediafire link as a test example
Old 21st April 2012, 18:04   #13  |  Link
sneaker_ger
Yes, you are correct. I tested it with your sample and it looks horrible, indeed.
Old 22nd April 2012, 02:37   #14  |  Link
natt
yv12->yv24->yv12 can be lossless with pointresample of chroma, provided the algorithm is correct. avisynth's yv12->yv24 with chromaresample=point is rather incorrect.
Consider a set of 4 luma samples in 4:2:0. Place them on a coordinate plane with the top left one at (0, 0) and the bottom right one at (1, 1).
So MPEG1 chroma is (0.5, 0.5), and MPEG2 chroma is (0, 0.5).
Avisynth's yv24->yv12 chromaresample=point uses chromaloc (0,0). Due to the limitations of point resize, only luma cosited chroma is possible. This is ok.
Avisynth's yv12->yv24 chromaresample=point uses chromaloc (1.5, 1.5) for MPEG1, and chromaloc (0.5, 1.5) for MPEG2. This is wrong and makes no sense at all. MPEG1 can be exactly represented at (0.5, 0.5), and MPEG2 can be better represented with either (0.5, 0.5) or (-0.5, 0.5).
Using a correct MPEG1 yv12->yv24 would allow yv12->yv24->yv12 to be lossless.
natt is offline   Reply With Quote
Old 22nd April 2012, 19:49   #15  |  Link
TheSkiller
Thanks natt, I have wondered why RGB<->YV24 conversions were not lossless color wise using chromaresample=point - now I know why.
However, I'm not sure though and can't test it now but if memory serves me right there also was something fishy going on if doing an (interlaced) YV12<->YUY2/YV16 conversion using pointresize, meaning converting back and forth is not lossless as one would expect.
TheSkiller is offline   Reply With Quote
Old 22nd April 2012, 20:19   #16  |  Link
poisondeathray
But Natt was referring specifically to Y'CbCr conversions (YV12<=>YV24), not RGB<=>Y'CbCr conversions like the OP was referring to.
Y'CbCr <=> RGB conversions are lossy for other reasons beside chroma sampling. Y'CbCr and RGB are non overlapping color models. You can have out of range gamut even with Rec1361 wide gamut RGB transfer function. Also there are rounding errors - worse when the calculations are done in 8-bit. So even if you disregard chroma up/downscaling algorithms there are other reasons for loss
In practical terms, many programs use RGB/A internally, but very few use Y'CbCr 4:2:0 , and even fewer Y'CbCr 4:4:4. So it would benefit many people to find optimal way with minimal losses for Y'CbCr <=> RGB conversions. Right now you choose trade offs between chroma blurring vs aliasing and "blocky" color edges.
Old 22nd April 2012, 21:53   #17  |  Link
Gavino
Avisynth language lover
Agreed it can be lossless with the appropriate algorithm, but it's debatable whether Avisynth's behaviour is incorrect (rather than simply not appropriate for this purpose).
It is consistent with the way PointResize works, which is to use, for each output pixel, the nearest source pixel looking above and to the left (hence not strictly 'nearest' neighbour, as it ignores nearer pixels below or to the right).
However, the effect is that YV12->YV24->YV12 using chromaresample="point" introduces a chroma shift.
But, as the original pixels are still preserved in YV24 (just in the 'wrong' place), this can be corrected by shifting them back before reconversion to YV12.
Thus,
ConvertToYV24(chromaresample="point")
MergeChroma(PointResize(width, height, 0, 1)) # mpeg2
# or MergeChroma(PointResize(width, height, 1, 1)) for mpeg1
is completely lossless.
See also posts #284-290 of this thread.
Old 23rd April 2012, 06:16   #18  |  Link
lansing
So this way is the closest to a lossless conversion I can get from a YV12->RGB32->YV12 ?
I'm trying to use neat video with avisynth plugins. I tried to load it as a plugin in an avs, but it requires a converttoRGB32 before that.
Old 23rd April 2012, 10:16   #19  |  Link
Gavino
Since YV12<->RGB32 goes via YV24, this also gives rise to an effective chroma shift as I described above. To avoid this, do the conversion explicitly to YV24 and shift the chroma back before the conversion to RGB32.
ConvertToRGB32()
... # filtering in RGB32
Then the only losses come from the YUV/RGB conversion (rounding, etc, as described by poisondeathray).
Old 23rd April 2012, 15:52   #20  |  Link
lansing
ConvertToRGB32()
thanks for the help to all of you guys
And one more thing, if i ran neat video in virtualdub and output the result as lagarith lossless in YV12, before putting it into avs, will i get the same result as the avs conversion above?
colorspace conversion, quality, rgb32, yv12
