Old 5th June 2008, 06:41   #1  |  Link
Vchat20
Vchat20's Avatar
Debate: Interlaced vs. Progressive
So this has been one mind-bender that has been nagging at me for a while and that has been the battle between Interlaced and Progressive content and the supposed 'need' to deinterlace said interlaced content from the getgo in many encoding situations.
Here's my take on it: If the original content is already progressive, there really isn't much to do there. And there really is no way to 'interlace' it back again since theorhetically you'd just end up with identical frames anyhow.
If the original content was interlaced on the other hand, you are at the maximum of quality in terms of retaining as much information as you can. Deinterlacing inherently loses information even with the best deinterlacing filters. In addition, most playback devices/software at least with good built in filters are capable of doing good deinterlacing on the fly during playback. Many software dvd codecs are a good example of this.
With this all said and done, why do you suppose it has long been such a habit of deinterlacing every piece of content regardless of destination? What are your opinions on the matter.
FYI: This is not saying 'OMFG you must stop deinterlacing', but more of a start of a debate as to why you think this is still commonplace.
Vchat20 is offline   Reply With Quote
Old 5th June 2008, 07:51   #2  |  Link
GodofaGap
I think deinterlacing became popular for three reasons:
- good deinterlacers were too hungry on the CPU to be be used in real-time back then and some new ones are now as well
- some codecs didn't have an interlaced mode (DivX 3.11 for example)
- a lot of times videos were resized to arbitrary sub-SD resolutions.
One method of deinterlacing doesn't throw away any information at all BTW: bobbing.
I agree with you that if your target is DVD on TV then deinterlacing doesn't make much sense. Also remember that a lot of 'deinterlacing' going on now in the AviSynth forum is actually trying to undo bad standard conversions.
GodofaGap is offline   Reply With Quote
Old 5th June 2008, 08:06   #3  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
a lot of editors and directors want a "filmic" look (i don't like that word, but there aren't any others to use), so they deinterlace.
my personal opinion is if you want it to look like film, shoot it to look like film, or just cough up the dough and actually shoot film. a "film look" is not at all a post decision - it must be considered from before shooting starts. the video look comes from more than just the interlace.
as far as deinterlacing everything in the encoding world, it's probably because the majority of codecs don't support it, and a large amount of the delivery methods out there don't support it (you can't bob in youtube or flash).
i think video can look quite good and don't see the point in making something juddery and blurry/jumpy in the name of some impossible (in most video situations) film look.
Old 5th June 2008, 08:46   #4  |  Link
Revgen
When it comes to sports footage, deinterlaced (bob-deinterlacing anyway) is always better IMO. Even if information is lost or none gained at all, the smooth motion that results from deinterlacing is pleasing on the eyes. And since sports footage always has a lot of motion, real-time bobbers are often not up to par and the sharp diagonal lines that make up the court or field can be aliased quite easily using conventional deinterlacers. Using a slow motion-based bobber like MCBob combined with NNEDI often is the best way to make the sports footage look good when it's deinterlaced.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake?
Curly: Burned at the stake!
Moe: Why?
Curly: A hot steak is always better than a cold chop.
Revgen is offline   Reply With Quote
Old 5th June 2008, 13:19   #5  |  Link
J_Darnley
J_Darnley's Avatar
You must deinterlace when watching on a progressive display or you see the combing. When you do it is up to you. You can do it in the decoder, in pre-processing, in the second decoder, in post-processing. I do it because I watch everything on my PC using a progressive CRT monitor on it. If I made a DVD or something to be shown on my TV then I may leave it interlaced.
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 5th June 2008, 19:48   #6  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Right, but you're still at the mercy of your DVD player / TV's processor. Who knows, it might do a dumb bob. Obviously if you're encoding a DVD it's best to leave it interlaced, but if you're encoding a file for playback on a PC connected to a progressive display, I find it necessary to encode 60p. This is one reason I really like 720p!
Old 21st December 2009, 15:06   #7  |  Link
knutinh
Interesting (old) thread. Basically we have a set of limitations. Camera sensor. codec. Display device. pre/post processing.
You will never get a higher field-rate or spatial resolution than that offered by the sensor. You will never get to watch a higher frame/field-rate or resolution than that offered by your display device. And in a bandwidth-limited world, your quality may be limited by the lossy compression, codecs may be more efficient on p than i material.
I tend to see interlacing as an analog 2:1 perceptually motivated compression method. I dont really see its purpose in this digital era, except for legacy purposes. If you want to trade motion/resolution/bandwidth, then use a lossy digital codec that does it intelligently..
-k
knutinh is offline   Reply With Quote
Old 21st December 2009, 17:09   #8  |  Link
Dr.Khron
Dr.Khron's Avatar
I've recently been watching a lot of football at my buddy's house, it looks GOOD on a modern plasma TV.
Am I crazy, or does the live (US NFL) football coverage constantly switch back and forth bewteen interlaced and progressive?
It often seems like you are seeing progessive graphics overlayed on an interlaced video stream, and some video streams seem smoother then others.
Dr.Khron is offline   Reply With Quote
Old 22nd December 2009, 01:35   #9  |  Link
Blue_MiSfit
Yep, it's a real nightmare with live video - espeically when progressive graphics are overlaid on top of an interlaced video stream, with occasional cuts to a (probably) progressive slow-mo camera, and everything else, plus probably some upscaled SD - then toss in commercials!!
ROFL!
Once they start broadcasting 1080p60 this will all go away hehe
~MiSfit
Old 22nd December 2009, 01:36   #10  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Some channels are 720p60, like ESPN, for example.
Old 22nd December 2009, 01:54   #11  |  Link
Blue_MiSfit
Exactly, and how nice is that? Especially considering their craptacular encoders
Is anyone actually broadcasting H.264 in the U.S.? Cable / Satellite/ OTA?
~MiSfit
Old 22nd December 2009, 02:15   #12  |  Link
Ever heard of DirecTV?
Old 22nd December 2009, 02:16   #13  |  Link
kieranrk
~MiSfit
NBC and ABC uplink feeds and probably a few others. Dish as well.
kieranrk is offline   Reply With Quote
Old 22nd December 2009, 11:45   #14  |  Link
Ghitulescu
Ghitulescu's Avatar
While most sources are interlaced and most viewing devices are progressive - it's hard to answer.
NB: some progressive camcorders store their movies interlaced, for compatibility reasons. Probably the best example is Canon.
Old 24th December 2009, 09:20   #15  |  Link
Manao
And even so, what legacy ? Is there an analog 1080i ? No. So there is no legacy to preserve here.
Especially since the tradeoff is actually worse than people think. On the paper, interlaced may sound good : you get the full vertical resolution when there are no motion, and the full temporal resolution when it moves. So 1080p60 and 1080i60 are supposed to be comparable, with 1080i60 saving perhaps 25% bitrate after compression, and reducing the decoding needs.
That's on paper only. As it happens :
  • you don't get the full vertical resolution. Oh, sure, there are 1080 row of pixels, so when the video is still, you're supposed to look at a 1080p video. And you do. Except that video has been downpassed vertically, so you are actually looking at a content that only has 600 or so rows of pixels of actual information.
  • You only decode 30 frames per seconds instead of 60. Yeah, sure, but you get the privilege to decode mbaff. On the paper, it's 'just' a coding tool that doesn't increase computational decoding complexity. But it does. Strongly. So indeed, it won't reach the computational needs of 1080p60, but there isn't a 2:1 margin either.
  • You're sending an interlaced signal to the TV, so somebody has to deinterlace it. Guess what, deinterlacing isn't cheap. When accumulated with the cost for mbaff, I think we reach the computational cost of 1080p60. But I cheat a bit here, because for legacy purpose, you would have needed a deinterlacer for SD content (but not for HD)
Now, I may be biased on the subject, and I might miss some arguments in favor to interlacing. But I don't see which ones.
Manao is offline   Reply With Quote
Old 24th December 2009, 11:52   #16  |  Link
roozhou
And Sony.
It seems Sony's LCD TVs have quite good deinterlacer. I guess Sony will stick to producing interlaced Camcorders because it looks better on their LCD TV than others.
roozhou is offline   Reply With Quote
Old 24th December 2009, 19:01   #17  |  Link
tony uk
why pictures are better in uk
the reason picture is better here is because of the interlaced
content poor people in usa only have NTSC : never the same colour.
merry christmas from uk
tony uk is offline   Reply With Quote
Old 25th December 2009, 07:52   #18  |  Link
Blue_MiSfit
Dish Network can't be broadcasting entirely H.264! My parents still have a receiver from at least 6 years ago that works perfectly. It's definitely MPEG-2 only!
I know they plan to broadcast H.264 in the future, or maybe they're only doing it for HD feeds? I wonder how these companies address legacy receivers.
~MiSfit
Old 25th December 2009, 15:19   #19  |  Link
I don't know about Dish, but in the case of DirecTV, they initially were MPEG2 for everything (after an early MPEG1 phase!) including HD. Then they phased in the AVC HD channels. They required subscribers wanting HD to upgrade their receivers. For a short interim period you could still receive some HD channels in MPEG2 but they were eventually all converted to AVC.
I have an old MPEG2 only HD DirecTV box that I had to eat.
Old 28th December 2009, 22:29   #20  |  Link
Blue_MiSfit
Interesting! I would love to see a proper comparison between Dish, and DirecTV's video quality - maybe with Comcast thrown in for good measure (as I know they still use a lot of MPEG-2 in most areas).
Do you know of such a resource, neuron2?
Also, how would you subjectively grade DirecTV's HD services?
Man - we're getting OT though! Looks like that's my fault .
To get things back on track - has anybody actually seen a 1080p60 broadcast in any form?
~MiSfit
content, deinterlace, interlaced, progressive, quality
