Old 6th October 2010, 14:55   #181  |  Link
zmaster
nvidia user
Midzuki,
zmaster is offline   Reply With Quote
Old 6th October 2010, 16:21   #182  |  Link
Hagbard23
23sKiDdOo!
Hagbard23's Avatar
You can also get a VAQ Patched Version here:
http://www.xvidvideo.ru/xvid-video-codec/
I think it is a more recent build, but i do not know exactly (DS Version is from 1st July 2009 / XVidVideo's Version is from 14th August 2010.
Hagbard23 is offline   Reply With Quote
Old 7th October 2010, 15:33   #183  |  Link
zmaster
nvidia user
Hagbard23,
I compared the results to me more like the image after compression with the aid of modifications from Dark Shikari.
Old 7th October 2010, 16:39   #184  |  Link
Hagbard23
23sKiDdOo!
Hagbard23's Avatar
Hagbard23,
I do not understand you. The russian Builds do contain DarkShikaris VAQ Patch as well. There is no other...
Old 7th October 2010, 19:38   #185  |  Link
zmaster
nvidia user
I get different results after using this version xvidcore.dll and that which is included in Xvid on xvidvideo. But it's does not mean that it's only VAQ.
Old 16th October 2010, 04:27   #186  |  Link
yetanotherid
Banned
Could someone be so kind as to tell me if this VAQ patch is different to the VAQ patch which the version of XviD installed by AutoGK uses?
From the 2.53 release notes:
http://www.autogk.me.uk/index.php?na...article&sid=74
"XviD now uses VAQ if source is not a cartoon (XviD setting in hidden options control's that) or have burnt-in subs."
yetanotherid is offline   Reply With Quote
Old 17th October 2010, 15:24   #187  |  Link
SilaSurfer
SilaSurfer's Avatar
The link provided on first page of this thread doesn't work. Dark Shikari is Koepi's build 1.2.1 VAQ ok to use?
SilaSurfer is offline   Reply With Quote
Old 27th October 2010, 12:41   #188  |  Link
Tuik
I'm using the xvid_encraw from megui (with development server) with the option -lumimasking, the custom matrix done by Didee, SixofNinesHVS.xcm and something like 1900/2000 bitrate (backup bluray to xvid). Also using 3 b-frames.
Is it a good combination?
Tuik is offline   Reply With Quote
Old 27th October 2010, 14:18   #189  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
it depends. we do not share minds so i dont know... good for what?
details pls (for example, if you want to keep 1080 res or downsize to 720 or even lower, compressibility of the movie, etc...)
Old 27th October 2010, 14:27   #190  |  Link
henryho_hk
1900/2000 kbps for 1080p? (and which deinterlacer are you using?)
henryho_hk is offline   Reply With Quote
Old 27th October 2010, 15:16   #191  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
1080p doesnt need deinterlace
Old 27th October 2010, 16:18   #192  |  Link
henryho_hk
No... I mean deinterlaced 1080i .... a bit too lazy in typing ~lol~
Old 6th November 2010, 12:43   #193  |  Link
Tuik
I want to downsize it to 720p and 480p
xvid aq, xvid vaq
