Old 20th February 2007, 17:19   #41  |  Link
Kiriakos
Firstly, thanks for the very usefull programs that you are feeding us with, Pelican9. Really great!
I am wondering, what is wrong with my system and the .srt file that outputs SUPread, looks like this:
1
12:01:14 AM,145 --> 12:01:18 AM,480
Line 1
2
12:01:18 AM,550 --> 12:01:21 AM,042
Line 2
3
12:01:21 AM,152 --> 12:01:24 AM,350
Line 3
4
12:01:24 AM,456 --> 12:01:29 AM,291
Line 4
The time numbers are in a strange format as you can see!!!!
Any ideas?
Thanks again.
Kiriakos is offline   Reply With Quote
Old 21st February 2007, 16:09   #42  |  Link
Kiriakos
1
Line 1
2
Line 2
3
Line 3
4
Line 4
Any ideas?
Thanks again.
Found it. It was the format of the time (control panel>regional settings> etc) on my system. It seams that SUPread uses this setting to form the .srt file.
Another one: It seams that if the movie has over 1000 lines of subtitles, in SUPread you can see in "Image" tab, only the first 999. From there and above, it sticks and shows the 999nth.
Old 22nd February 2007, 10:45   #43  |  Link
Pelican9
Coder
Pelican9's Avatar
Thank for your report, I'll fix it soon.
The used time format is the system's default setting as you described. (The same problem was in EVOdemux.)
Edit:
I've fixed the time format and the other problem with lines above 1000
Pelican9 is offline   Reply With Quote
Old 22nd February 2007, 22:06   #44  |  Link
Deckard2019
Any news about exporting bitmaps ?
Thank you.
Deckard2019 is offline   Reply With Quote
Old 23rd February 2007, 00:55   #45  |  Link
Pelican9
Coder
Pelican9's Avatar
Thank you.
I'm working on EVOdemux...
Off:
... Nehogy már! Te vagy a blade, blade runner.
Old 23rd February 2007, 01:23   #46  |  Link
Kiriakos
You are a king!
Old 24th February 2007, 18:56   #47  |  Link
Pelican9
Coder
Pelican9's Avatar
SUPread v0.23
Changes for v0.23
- New option 'Auto read'
- New option 'Output folder'
- New feature 'Save BMPs'
SUPread v0.23
Old 24th February 2007, 21:06   #48  |  Link
Pelican9
Coder
Pelican9's Avatar
Is there a chance we could use SubRip OCR engine ?
SubRip can take image sequence as Input. Image Sequence comes from DVDSupDecode.
So maybe you could export each image to BMP and create output text file just as DVDSupDecode does ?
Output text file starts with :
And then :
If you want me to test anything, just ask ...
I've created a subrip.txt but Subrip makes an error...
Old 24th February 2007, 21:17   #49  |  Link
Deckard2019
Thank a lot for the feature !
Did you try to resize bitmaps to DVD resolution (720x480 or 720x576) before using SubRip ?
Old 24th February 2007, 21:34   #50  |  Link
Pelican9
Coder
Pelican9's Avatar
I'm trying with an NTSC DVD, so the bitmaps are 720x480...
I cannot create a valid txt, or valid bmp. :-(
Subrip always give access violation error...
Could you send me a valid file?
My txt:
;VTS_01_1.Subpicture.00.sup
FrameRate=23.976
Alpha=FFF0
{107}{218}{VTS_01_0.20_000001.bmp}
{239}{298}{VTS_01_0.20_000002.bmp}
{311}{441}{VTS_01_0.20_000003.bmp}
Old 24th February 2007, 21:41   #51  |  Link
manusse
SubtitleCreator's Co-Dev
manusse's Avatar
Hi pel,
It seems there is no carriage return in the generated subrip.txt file.
Could it be the problem?
Cheers
Manusse
manusse is offline   Reply With Quote
Old 24th February 2007, 21:46   #52  |  Link
Pelican9
Coder
Pelican9's Avatar
Originally Posted by manusse View Post
Hi pel,
Cheers
Manusse
Your version could be quite old...
Old 24th February 2007, 21:47   #53  |  Link
manusse
manusse's Avatar
Downloaded 5 minutes ago.
Old 24th February 2007, 21:49   #54  |  Link
Pelican9
Coder
Pelican9's Avatar
Well, I don't know...
Look at my post, there are CRLFs...
Old 24th February 2007, 22:26   #55  |  Link
manusse
manusse's Avatar
I tried again with the last versions of EVOdemux and SUPread and have still the same problem.
I've carefully checked the file with a binary editor and it seems each line is separated by 0x0a followed by 0x0d whereas notepad.exe puts 0x0d followed by 0x0a. This explains why notepad is confused. Could it be the same for subrip?
Hope this helps
Manusse
Old 24th February 2007, 22:47   #56  |  Link
Deckard2019
Just tried with a PAL DVD. Subtitle file can be found here.
DVDSupDecode generates :
;Subpictures_21.sup
FrameRate=25
Palette=8328
Alpha=0FA0
{1293}{1355}{Subpictures_21_000001.bmp}
{1361}{1425}{Subpictures_21_000002.bmp}
{1460}{1507}{Subpictures_21_000003.bmp}
Supread generates :
;Subpictures_21.sup
FrameRate=23.976
Alpha=FFF0
{1240}{1299}{line0001.bmp}
{1305}{1366}{line0002.bmp}
{1400}{1445}{line0003.bmp}
As you can see, Palette info is in the .txt file. Also, Supread seems to always set Alpha to FFF0 ...
Old 24th February 2007, 22:47   #57  |  Link
Pelican9
Coder
Pelican9's Avatar
I tried again with the last versions of EVOdemux and SUPread and have still teparhe same problem.
I've carefully checked the file with a binary editor and it seems each line is sated by 0x0a followed by 0x0d whereas notepad.exe puts 0x0d followed by 0x0a. This explains why notepad is confused. Could it be the same for subrip?
Hope this helps
Manusse
My notepad works normally with it...
I've tried to change 0d0a but then my notepad can't handle it.
Are you sure? This is definitly 0D0A...
7B 31 32 30 31 7D 7B 31 32 37 32 7D 7B 56 54 53   {1201}{1272}{VTS
5F 30 31 5F 30 2E 32 30 5F 30 30 30 30 30 35 2E   _01_0.20_000005.
62 6D 70 7D 0D 0A 7B 31 33 33 30 7D 7B 31 34 31   bmp}..{1330}{141
36 7D 7B 56 54 53 5F 30 31 5F 30 2E 32 30 5F 30   6}{VTS_01_0.20_0
Old 24th February 2007, 22:59   #58  |  Link
manusse
manusse's Avatar
I've rechecked and I confirm what I've written.
Really strange...
Manusse
Old 24th February 2007, 23:01   #59  |  Link
manusse
manusse's Avatar
00000000:3b 2e 53 75 62 70 69 63 74 75 72 65 2e 30 30 2e    ;.Subpicture.00.
00000010:73 75 70 0a 0d 46 72 61 6d 65 52 61 74 65 3d 32    sup..FrameRate=2
00000020:33 2e 39 37 36 0a 0d 41 6c 70 68 61 3d 46 46 46    3.976..Alpha=FFF
00000030:30 0a 0d 7b 37 32 39 7d 7b 37 35 39 7d 7b 6c 69    0..{729}{759}{li
00000040:6e 65 30 30 30 31 2e 62 6d 70 7d                   ne0001.bmp}
Old 25th February 2007, 09:32   #60  |  Link
Pelican9
Coder
Pelican9's Avatar
Hmmm, interesting.
1:1 :-)
supread, suprip
