3rd February 2005, 21:47 | #221 | Link |
Just checked and Peter last posted about NuEnc at KVCD.NET forums on 31 Dec, so don't worry, there's no new developments that you're missing out on.
I'm quite sure any news/updates about his work on NuEnc etc will be announced here as soon as it's known as well as on kvcd.net |
4th February 2005, 06:40 | #222 | Link | |
also danpos said Peter had already talked about his pc blowing up and he was trying out a 0.21 version he had been sent. make of that what you will.
Narrator: And of course, with the birth of the artist came the inevitable afterbirth - the critic. (History of the World part 1) |
18th February 2005, 13:33 | #223 | Link |
I just found out that Danpos has published a short NuEnc tutorial in Portuguese at
http://www.vmesquita.com/forum/index...12176#msg12176 The nice thing is that he also hosts the latest NuEnc 0.21 test version. I don't know if it is alright with Peter Cheat to post the link since he has not officially released version 0.21, but Danpos has only good things to tell about it. Cheers manolito Last edited by manolito; 18th February 2005 at 13:35. |
18th February 2005, 18:06 | #224 | Link |
BDVD Team
@manolito
Hi, guy! I just want to clarify that question. I was also unsure with respect to host a version not formally released for all, but thinking more over I did conclude that I can to do it for the following reasons: 1-The NuEnc version is a test one (beta), which is aimed at development of encoder (test of options, bug tracks etc); so, in this manner,if more people can to test it, more easy and rapdily the encoder development will go ahead; 2-I did a explicit communication that the download version is a non-official release (which will be provide for the owner, Peter Cheat); 3-As a admiring from Peter's work, I did want divulge it in brazillian community; so, I thought that a new version, with more features and fixes will help in disseminate it. Obviously, I'll like to talk with NuEnc owner (Peter Cheat), but as you've noted, the same is off a very long time. My intentions are the best as possible. If all think that I did a fault, I simply deleted the file from my webspace. I hope have got clarified that issue. Cheers, |
21st February 2005, 20:07 | #226 | Link |
QuEnc compatible command line interface for NuEnc
NuEnc has a slightly different command line interface from QuEnc, and if
NuEnc encounters a parameter it does not know, it simply quits with a "Bad Parameter" message. Result: DVD Rebuilder and DVD2SVCD do not work with NuEnc. Peter Cheat seems to have gone into hibernation, so there is little hope that he might fix the command line interface any time soon. Since I am a little too stupid to modify the NuEnc sources and recompile it I decided to write a small utility that sits between the application and NuEnc and translates the command line parameters so NuEnc can understand them. Download at http://scifi.pages.at/manolito/NuCLI/NuCLI.zip Tested under Win XP with NuEnc 0.01b and NuEnc 0.21. Works with the latest builds of DVD2SVCD and DVD Rebuilder 0.74 (could not test the VIP versions). @danpos I like version 0.21 very much, do you have any idea what Peter Cheat changed since 0.01b? There is no changelog... Enjoy manolito |
21st February 2005, 22:21 | #227 | Link | |
BDVD Team
Re: QuEnc compatible command line interface for NuEnc
Cheers, |
25th February 2005, 15:16 | #231 | Link |
@danpos
I have done a couple of encodes with NuEnc 0.21, mainly low bitrate VHS capture to SVCD encodes, and I must say, I am impressed. I used the settings from your tutorial with the BVCD matrix, and I cannot find any quality decrease compared to the original VHS tape. But I do have a couple of questions, and since Peter Cheat is not available ATM, I guess you are the person to ask: The settings you propose in your tutorial are all optimized for speed. If I want a better visual quality without too much of a slowdown, which setting would be the best to change? MB Decision from Comp Fn to Least Bits or RD, Compare Fn from SAD to SATD, or Search Size from Diamond 1 to 3 or even higher? Or is Adaptive better? I found that Adaptive 4 is about as fast as Diamond 1, which one would look better? I understand that you did test NuEnc's CQ mode, and I'd like to know if CQ mode is VBV and bitrate compliant. In other words, is the resulting stream DVD (or SVCD) compliant by observing the Max bitrate? If so, we could have someone (Amnon82, JDobbs or Tylo) write a prediction tool for NuEnc which would give us a high quality one pass VBR encoder which also happens to be FREE. Cheers manolito |
25th February 2005, 19:40 | #232 | Link | ||||
BDVD Team
MB Decision - Alters how the encoder selects a MC MB. Least Bits=high quality (fast), RD=very high quality (slow). Compare Function - SAD=good(fast), SATD=best(slow) Search size - Adaptive is faster, Diamond is a little better. Larger value corresponds to larger search size. Quote:
Greetings, |
20th January 2013, 02:19 | #236 | Link |
Hi
For anyone interested in NuEnc, and their original variants (NuEnc 0.01b - NuEnc 0.21 - NuCLI), I had solicited to manolito forum member: Binary and Sources Best regards, L.H.V.F. . Last edited by Guest; 25th January 2013 at 14:46. |
