14th May 2008, 16:45 | #1901 | Link |
No menu selection with EVR on XP
Hi Everyone,
I have loaded the files for EVR on XP and EVR is selectable in MPC. It will play the movie, but functions are very limited. I have read through many pages, and have a problem with menu selection at the beginning of a SD DVD. As the mouse pointer is moved over the selection, I get no action on the click event. Also, there is no seek or skip function when clicking the icons. Is there a solution other than using VRM9? Not sure how many of you are using EVR on XP, but I thought to give it a try and compare picture quality. I disabled the external filters because from what I read, EVR will not use a external decoder. WinXP SP2 with EVR files registered C2 Duo 6320 ATI 3850 8.4 drivers 2 Gigs ram MPC HC latest update Any help is appreciated. MAK |
14th May 2008, 17:06 | #1902 | Link | |
If you complain about having to install net framework (get 3.5), you shouldn't. Its going to become a lot more common place in the future. Vista includes framework 3, and is quickly updated to 3.5. Net framework 3 and above have the EVR renderer built in to it, its actually a Net framework based renderer! So it applies for both XP and vista. Once installed, evr custom presenter works just as well on XP as it does on vista. Most of the problems (not all) with evr and other renderers is people don't have their computer updated. |
14th May 2008, 17:23 | #1904 | Link | |
Unfortunately it doesn't help much. With VSync set to "Always on" I still have tearing. It's always at the same place, though, which is at the very bottom of the screen. With 2.35:1 movies the tearing is hidden by the black bars. But with 1.78:1 movies the tearing is very visible... |
15th May 2008, 00:30 | #1906 | Link |
I'm running XP with .net3 installed and both of my EVR settings are selectable.
I have a question though. Is anybody else running FFDShow or CCCP? I thought MPC-HC's ffmpeg based decoder was a better alternative? I assumed that one of the advantages of MPC-HC was to never have to download another codec pack again since it plays pretty much every file I need by itself and Haali's renderer. Plus, its ffmpeg based internal decoder is faster than Mplayer at playing 1080p Quicktime trailers. I think I'll try and compare each renderer when I get home to see overall playback quality and how much RAM it uses up using only the built-in decoder, then I'll post my findings. Last edited by neoufo51; 15th May 2008 at 00:35. |
15th May 2008, 00:48 | #1907 | Link | |
Software Developer
2. Both, MPC-HC's internal H.264 decoder and ffdshow's H.264 decoder, are based on code from "ffmpeg" project (libavcodec) 3. As long as you are using "software" mode, the performance of MPC-HC's internal decoder should be no different from ffdshow 4. The advantage of MPC-HC's internal decoder over ffdshow is DXVA support (hardware acceleration)
15th May 2008, 08:35 | #1908 | Link |
what about this bug?
http://sourceforge.net/tracker/index...61&atid=854651 for me subtitles working only with vmr7 version MPC-HC v1.0.11.0 is ok, but next releases are bugged actually i use VSFilter.dll added as external filter for fix this problem where can i find language files for mpc-hc? and sorry for my english |
15th May 2008, 10:47 | #1909 | Link |
Kid for Today
well if you check the link I gave you, noee can get regular EVR working fine on his XP SP3 box.
he doesn't have CCC installed and we have same graphic card. I've never been able to get non customized EVR to work w/o tearing in the middle of the screen......and I've asked several friends of mine, they've never managed either, whatever on ATi or nvidia. at some point I unchecked "use centered timings" in CCC, and my tearing was gone ?! .....but then after I messed even further with CCC, it came back well the way I see it, this build of EVR works fine on XP. m$ doesn't want everyone to know that EVR can work on XP, so they've released it in a programming package and you have to manually rgvsvr32 it....and that's it, for Vista upward compatiblity. I've ran many tests with the later versions of EVR(from Vista beta SP1 and Vista SP1), and they crap out badly on XP after 45/60 mins......they also include known bugs on XP(floating point bug, etc...) but who can blame non-XP dll's to fail on XP ? I highly doubt that this renderer was programmed in .net language |
15th May 2008, 10:50 | #1910 | Link | |
Solaris: burnt by the Sun
so a .net renderer doesn't sound far fetched to me |
15th May 2008, 11:37 | #1911 | Link | |
ffdshow/AviSynth wrangler
The .Net 3.0 framework does come with bindings for using the EVR renderer from .Net, which the earlier renderers don't. That's why they've thrown in a version of EVR for Windows XP with the .Net 3.0 installer, so .Net applications using it also work on XP. And you don't have to register the renderer using regsvr32 if you plan to use it directly from an application. So you could implement a media player in C# that uses EVR easier than one that uses VMR9 - that's all there is to it. np: John Dahlbäck - Wet Summer (Speicher CD3)
now playing: [artist] - [track] ([album]) |
15th May 2008, 11:38 | #1912 | Link | ||
EVR is definitely NOT written in .net. You can see that if you load evr.dll into a PE file viewer. The dlls it imports clearly show that evr.dll is not written in .net. |
15th May 2008, 12:15 | #1913 | Link | |
Questioning User
And for that is it better for HR to be in TV or PC luma range? |
15th May 2008, 12:49 | #1914 | Link | ||
Kid for Today
it's explained here (babelfish it up, it's in french) : http://www.erenumerique.fr/qualite_d...art-820-9.html MSI videocards are known to have piss poor DVI outputs(long cables won't work, bad blanking timings, etc..) and it's been measured here : http://www.erenumerique.fr/qualite_d...rt-820-18.html your best bet for ATi are Sapphire / HiS and Diamond(in no specific order). I've got my HC3100 projector connected with a DVI/HDMI 8ft Monster cable to the secondary output of my PCI-E HD2600 Sapphire, and the only renderer that gives tearing is non customized EVR(on both DVI outputs anyhow). Quote:
leave it on TV...but it's not used if you output RGB from ffdshow anyhow Last edited by leeperry; 15th May 2008 at 13:11. |
15th May 2008, 13:11 | #1915 | Link |
Questioning User
I have set up autoload presets for SD and HD by differentiating the video size.
I suppose RGB32HQ is output by RGB32 only with high quality YV12 to RGB conversion? My PC can't play the really HQ 1920x1080 BD-rip in that setting. So I set it to use the default colorspaces for that video size. |
15th May 2008, 13:19 | #1916 | Link | |
If this is a hardware problem then how come that I've never ever in my life seen even the slightest hint of tearing when using the Direct3D fullscreen mode? |
15th May 2008, 13:26 | #1917 | Link |
Kid for Today
@madshi:
might be hardware or BIOS dependent. ask your mobo/graphic card manufacturers if they don't have newer BIOS. or try to borrow a card of the brands I mentionned above @iron2000: yes, that's it "HQ conversion". well I've just upgraded my CPU to be able to use RGB32HQ in any given situation |
15th May 2008, 14:31 | #1918 | Link | |
You can read it in more detail here. Regards Piotr |
15th May 2008, 15:29 | #1919 | Link | |
15th May 2008, 15:40 | #1920 | Link | ||
Kid for Today
on that link Avery Lee(?) says :
it all relates. and the fact that HR gives tearing on your system is quite a good clue that there's sumthing funky happening in your graphic card or your motherboard that doesn't handle the transactions properly.....because I've never heard of anybody experiencing tearing w/ HR. I guess your only option is to try with a different video card, and if it still occurs.....try it on another mobo. Last edited by leeperry; 15th May 2008 at 17:00. |
