Old 25th June 2020, 15:36   #121  |  Link
LigH
LigH's Avatar
I can't compare with the "official" builds, as I don't know how the "official" builds were created. I guess they don't contain lavf and ffms which MABS does include. And MABS uses MSYS2 / MinGW with GNU C/C++ in a current stable release (v10.1 at the moment). My latest build is linked and documented here.
I can't use ICL, I don't have any experience with it.
New German Gleitz board
Old 25th June 2020, 18:35   #122  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
It looks like they are using GitLab CI/CD runners to create the "official" builds, and you can see their configuration file here:
https://code.videolan.org/videolan/x....gitlab-ci.yml
Anyway, the "official" builds have libavcodec/libavformat support enabled, but not FFMS. Also, they use GCC 8.2.
Old 26th June 2020, 14:15   #123  |  Link
tormento
Acid fr0g
tormento's Avatar
You can download ICL with free subscription too, if interested.
@turment on Telegram
Old 14th October 2020, 16:37   #124  |  Link
nakTT
Thanks for the sharing.
nakTT is offline   Reply With Quote
Old 7th June 2021, 22:51   #125  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Can someone with the rights on the x264 GitLab merge this pull request?
https://code.videolan.org/videolan/x...rge_requests/6
Old 19th June 2021, 13:54   #126  |  Link
jpsdr
Prayer answered it seems...
https://code.videolan.org/videolan/x...989cb1ecd19cbd
My github.
Old 19th June 2021, 14:13   #127  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Yep, I've got the email the other day: it has been merged.
Time to celebrate, then.
annuntio vobis gaudium magnum: habemus Intra Class 300-480 xD
Old 20th June 2021, 19:39   #128  |  Link
jpsdr
New version build.
My github.
Old 28th July 2022, 20:43   #129  |  Link
chompy
Originally Posted by jpsdr View Post
New version build.
@jpsdr: Will you continue updating your x264 t_mod versions? Thanks!
chompy is offline   Reply With Quote
Old 29th July 2022, 17:14   #130  |  Link
jpsdr
I will when there will be interesting/worthwile commits (bug fixes or encode improvement), as it take a lot of time for me to make the build. Didn't check if there was commits the last 3 weeks, but until there, the commits were not worth spending time.
My github.
Old 29th July 2022, 18:05   #131  |  Link
chompy
Great, lots of thanks for your great work!!
Old 25th September 2022, 11:50   #132  |  Link
jpsdr
New t_mod version for those who are still interested.
My github.
Old 25th September 2022, 13:48   #133  |  Link
mastrboy
Thank you.
(i have a tendency to drunk post)
mastrboy is offline   Reply With Quote
Old 25th September 2022, 14:52   #134  |  Link
kebulek
kebulek's Avatar
Thanks!
kebulek is offline   Reply With Quote
Old 26th September 2022, 00:00   #135  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Nice, thank you, Jean Philippe!
Old 28th September 2022, 18:06   #136  |  Link
chompy
Lots of thanks!!
Old 21st October 2022, 10:58   #137  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Hi there guys, I've just noticed that if I use --asm=avx512 with x264 8bit, it works, however if I use it while encoding with a 10bit profile, it doesn't, it only goes up to AVX2.
Is this expected? Is this because no one wrote AVX512 intrinsics for 10bit?
Old 21st October 2022, 20:37   #138  |  Link
LoRd_MuldeR
Software Developer
You probably mean "assembly code" functions. An "intrinsic" is a function (well, not really a function, just something that can be called like a function) which is built directly into your compiler.
Anyways, as far as I can tell, the only places where the flag X264_CPU_AVX512 appears is in cpu.c and dct.c.
Obviously the code in cpu.c detects the CPU features. It's in dct.c where x264 actually uses the X264_CPU_AVX512 flags to enable (or not) certain function:
https://raw.githubusercontent.com/mi...7/common/dct.c
But, if I read the pre-processor directives in that file correctly, then the X264_CPU_AVX512 flag does not appear in the HIGH_BIT_DEPTH part at all; it only appears in the !HIGH_BIT_DEPTH part.
In other words, there is nothing in the "high bit-depth" code path that gets enabled/disabled depending on the availability of AVX-512 support.
Probably there simply are no "high bit-depth" functions that would benefit from AVX-512 instructions, or at least nobody nobody cared enough about AVX-512 to figure it out
Old 22nd October 2022, 02:27   #139  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Yep, sorry, I meant manually written assembly optimizations.
I see! So it's normal that I don't see it being enabled there as no one actually wrote anything for it in the high bit depth part, so it only works for 8bit. Gotcha.
Gotcha, which is why I couldn't see it being enabled. Thanks for taking a look at it.
Nah, that's very unlikely, I just think no one wrote assemblies 'cause 10bit H.264 is much less used compared to the 8bit flavors (and indeed the only two groups of people who use it are those encoding in intra class to target broadcast hardware SDI playout ports in professional settings and those encoding anime, like fansubbers doing reverse upscale of BDs xD)
Yeah, that's much more likely.
I wonder if Henrik Gramner will get back on this, given that he's the one behind the AVX-512 commits (among plenty of other things)...
Old 12th January 2023, 18:56   #140  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Remember the whole discussion about OpenCL?
I actually tested again but this time on Amazon AWS machines.
m6i.4xlarge 16c/16th AVX-512 CPU Only
1h 24m
m6i.4xlarge 16c/16th AVX-512 CPU + OpenCL GPU
1h 03m
The content is 1h 32min 25seconds and 3 frames long.
The video is MPEG-2 50 Mbit/s FULL HD yv16 25i with PCM 24bit lossless 5.1 audio bobbed to 50p and with the chroma downscaled to yv12 in Avisynth.
x264.exe "Z:\AVS Script.avs" --preset medium --profile high --level 4.1 --ref 4 --deblock -1:-1 --crf 25 --keyint 50 --aud --overscan show --range tv --opencl --colormatrix bt709 --transfer bt709 --colorprim bt709 --videoformat component --nal-hrd vbr --vbv-maxrate 25000 --vbv-bufsize 25000 --output "I:\temp\raw_video.h264"
ffmpeg.exe -i "Z:\AVS Script.avs" -vn -sn -af loudnorm=I=-24:LRA=12:tp=-2 -c:a aac -b:a 550k -ar 48000 "I:\temp\audio.aac"
mp4box.exe -add "I:\temp\raw_video.h264" -add "I:\temp\audio.aac" "I:\temp\final_output.mp4"
adding --opencl saved around 20 min compared to not adding it.
So... yeah, it still makes sense to have it on.
